Question about Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle
IGNITION PROBLEME I HAVE A YAMAHA MAXIM XJ 1100 1982 I BUT A NEW BATTERIE,IGNITION SWITCH,FUZE ARE GOOD,BUT STILL KNOW POWER AT ALL WHAT COULD BE THE PROBLEME
  • 867 Answers
Make sure the battery cable going to the engine block is not corroded , as this is an older bike.clean screw and connector with wire brush, put vaseline on them.
Posted on Jun 15, 2009
Missing ignition start switch for 1981 yamaha xj650 maxim, what's the amp required to start it? Having trouble finding the right momentary switch to install
Starting doesn't go through the ignition switch it goes through the starter solenoid and the ignition switch controls that solenoid only about 5 amps.
Apr 04, 2017 | 1981 Yamaha XJ 650
1983 Yamaha XJ 700 Maxim headlight stays on with the key in the off position
Hi, Ser3 you may need a new ignition switch for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
can see clearly now the H4 in
The Ultimate Relay Switch Sensor and Diodes Guide
Maximum Maxim Service Menu
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Feb 14, 2017 | 1985 Yamaha XJ 700 X Maxim
1985 yamaha maxim distributor
Hi, Anonymous and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
85 xj700 maxim starter button not working
1985 yamaha maxim won start
Yamaha XJ700N Service Manual
Apr 06, 2014 | 1985 Yamaha XJ 700 X Maxim
Remove replace ignition switch
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
1986 Yamaha Maxim XJ700 ignition switch help needed Fixxit
82 750 maxim ignition switch
Nov 19, 2013 | Yamaha XJ 700 X Maxim Motorcycles
1985 Yamaha XJ 700 S Maxim with the key off all power stays on bike keeps running
Hi, Anonymous you may need a new ignition switch for this scenario you will need your service/owners/ manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Oct 07, 2013 | 1985 Yamaha XJ 700 S Maxim
Yamaha xj 750 manual
XJ700 Suddenly won start at all Electrical Problem
http://meiguohosting.com/How-to-fix-start-problem-for-your-1986-Yamaha-XJ700X-Maxim
Sep 04, 2013 | 1985 Yamaha XJ 700 X Maxim
Socket size need remove spark plug
Hi, Anonymous for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Maximum Maxim Resource for 1985 86 Yamaha 700 750 Maxim Models XJ700X and...
DOWNLOAD Yamaha XJ700 XJ 700 MAXIM Service Repair Workshop Manual Download...
Aug 26, 2013 | 1985 Yamaha XJ 700 X Maxim
1985 Yamaha xj700 maxim x running lights work but panel and headlight do not come on the start switch does nothing.
Hi, Anonymous you may have a faulty ignition switch for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Apr 17, 2013 | 1985 Yamaha XJ 700 X Maxim
How to tell the difference between maxim and maxim X
Hi, Sherryallbee for more information about your question and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha XJ 700 Maxim 1985
Yamaha XJ 750 Maxim 1986
Mar 31, 2010 | 1985 Yamaha XJ 700 S Maxim
Harley Davidson Harley-davidson Motocyclette Hardwood Motorcycle Logo
159 people viewed this question
Top Harley Davidson Toys Experts
ray gallant
Mark McGinty
Mark McGinty
Charles Ma
Charles Ma
Are you a Harley Davidson Toy Expert? Answer questions, earn points and help others
