Question about HP LaserJet 9040n Printer
Hp 9040 long preheat
Long preheat
What causes paper jam in hp 9040 laserjet copiers
IT all depends on the location of the paper jam. The usual causes are bad feed rollers and fuser units.
Mar 04, 2015 | HP LaserJet 9040n Printer
Hp laserjet 9040 printer shows paper jam but i can't found any paper jam
This can be caused by a few problems.
1. dust in printer: get blower an blow the printer out.
2. Paper stuck somewhere in printer: look as error and where paper jam is in and inspect that part of the printer
3. faulty sensor: replace sensor
Dec 27, 2013 | HP LaserJet 9040dn Printer
In hp 9040 printer print come out but when i have touched it with hand it erased
The fuser unit is not working. if you can rub the toner of net the fuser in not heating up and is probably faulty and needs to be replaced.
bets would be to replace the following
maintenance kit C9152-69004
Dec 27, 2013 | HP LaserJet 9040n Printer
10.1000 error showing in HP laserjet 3005 printer.Waht is the scientific side to resolve the issue?
error refers to memory on print cartridge that cannot be read. Replace toner cartridge.
Nov 13, 2013 | HP Stacker For LaserJet 9040/9050/9500...
Printer error 59.30 HP laserjet 9040dn
This error refers to the fuser or fuser drive motor. Try replace the fuser. If the error remains, try changing the fuser drive motor. That should fix your problem...
May 03, 2012 | HP Laserjet 9040 Printer
Can you supply a roller kit for HP Laserjet 2550L? If so, how much?
We service HP printer and have the roller kits in stock. The kit sells for $26.00 plus shipping. To order call us at: 318-447-9040
Buddy
Corporate Computer
www.ccl-la.com
Jan 05, 2010 | HP LaserJet 2550L Printer
Hp 9040 jams in the morning but works fine rest of the day
You may consider cleaning the feed rollers. If they are plastic, try isopropyl alcohol or if they are rubber, try a rubber roller cleaner similar to this http://www.simplybargains.com/80008.html
Jul 27, 2009 | Office Equipment & Supplies
HP LJ 9040- at first fuser that was orignally
I take it your a tech or have tech ability
in my personal experience Squeeking or noticable squeeking has manily from the Output Assembly
if you can here it from the rear it is the Output assy. glad i could help
Jul 24, 2009 | Office Equipment & Supplies
Want to buy anew printer
15,000 in one day !!!!!!
  1. HP laserjet 9040 $3200
  2. HP laserjet 9050 $3,700
  3. hp indigo press 3500 Call HP for price
You will have to look these up on hte internet to get the specs amd see which one is good for you.
Jul 25, 2008 | Office Equipment & Supplies
HP LaserJet 9040n Printer Logo
16 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
