Question about Samsung Galaxy Camera EK-GC100 3G White Android unlocked Camera
Setting punt adj
Is their a method to set punt
Armitron 45/7030
Hold the set button and press mode button
Press adj to change seconds
Press mode
Then press adj to change hour
Press mode
Then press adj to change minutes
Once you are done, hit set
Nov 04, 2013 | Watches
How do I set the clock on my iLive I Pod/CD stereo?
SETTING THE CLOCK1. Press the Power Button to turn the unitoff.2. The Power Indicator Light will illuminate red, indicating that the unit isin Standby Mode.3. Press the Mem/Clk Adj Button.4. The Hour will begin to blink.5. Press the Skip/Tune Buttons to adjustthe hour.6. Press the Mem/Clk Adj Button to set thehour.7. The Minute will begin to blink.8. Press the Skip/Tune Buttons to adjustthe minute.9. Press the Mem/Clk Adj Button to set theminute, and finish setting the clock.
Feb 23, 2012 | Audio Players & Recorders
Bottom right button is light, not EI. top left is adj button left is mode top right is st/stp. I can't set time and date and can't turn off my alarm
hi..
El stands for
To set the time
  1. Press and hold [ Adj button ] till the digits on screen starts blink.
  2. Now Press [ Mode Button ] repetitively to cycle through Hour -> minute -> Seconds
  3. Press [ ST/STP button ] to adjust the value. Each press will increase the value.
  4. Press [ Adj Button ] again to save the changes
To set the alarm
  1. Press [ MODE Button] till it displays Alarm Time.
  2. Repeat steps 1 to step 4 as described in 'To set the time'
  3. Different watches have different procedures to active the alarm. Common method is pressing a button briefly.
    Since model of watch is not specified, Try pressing [Adj Button] or [ST/STP Button].
Mar 18, 2011 | Watches
Need instructions for setting my armitron wr165 , 45/6967 watch.
This model is not available on Armitron's website, but after working through a similar digital watch, I came up with the procedure.
Basically, hold the MODE button for 2 seconds until the alarm flashes then press SET to get to the minutes. Press ADJ to change the numbers. Press SET again to change the hour.
Here's the full date/time set:
SETTING THE TIME AND CALENDAR 1. Press and hold 'MODE' for two seconds. Alarm Modeappears. Release 'MODE', then press 'MODE' again. Seconds and the TuesdayIndicator flash. Press 'EL' to zero out the Seconds. 2. Press 'SET'. Minutes flash. Press 'ADJ' to advance the Minute. 3. Press 'SET'. Hours flash. Press 'ADJ' to advance the Hour. 4. Press 'SET'. The Months flash. Press 'ADJ' to advance the Month. 5. Press 'SET'. The Date flashes. Press 'ADJ' to advance the Date. 6. Press 'SET'. The Day of the Week flashes. Press'ADJ' to advance the Day of the Week. 7. Press 'MODE' to end set sequence and return to thetime.
Nov 07, 2010 | Microwave Ovens
Wharfedale NE-571 How do i set the time on it i bought it second hand
Hold MEM/C/ADJ in power off/Standy mode until you see the clock display flash.. let go of MEM/C/ADJ using the forward/backward buttons above the volume dial select 12/24 hour press MEM/C/ADJ again.. you will see the left bank of digits flash.. press forward or backward to select your hour then press MEM/C/ADJ again set the minutes and then press MEM?C?ADJ again and your done!! ;)
I phoned ARGOS spares and got them to email me a copy of the instructions.. if you want me to forward a copy of the PDF to you let me know at darkmyble2006@hotmail.com.
Sep 01, 2010 | Audio Players & Recorders
What buttons change time display
How do I set the clock?
A5
There are several methods to set the clock, depending on the model.
Method 1
Press and hold the BAND and DISPLAY buttons to display the clock
Press and hold the BAND and DISPLAY buttons until the time display flashes
SEARCH left to adjust the hours; right to adjust the minutes
Press BAND button to store the time
Method 2
Same as Method 1, except press DISP to store the time
Method 3
Press ADJ
SEARCH left or right to select clock and press ENT
SEARCH left or right to select the hour or minute
Turn rotary knob clockwise or counter-clockwise to set the correct time
Press enter to store the time
Press ADJ to return to the previous mode
Method 4
Press and hold the BAND and FUNCTION buttons to display the clock
Press and hold the BAND and FUNCTION buttons until the display flashes
Search left to adjust hours; right to adjust minutes
Method 5
While the display is showing the clock, press and hold the CLOCK knob until the minutes flash
Press the CLOCK knob to adjust the minutes
When the CLOCK knob is released for 5 seconds, the hours will flash
Press the CLOCK knob to adjust the hours
When the CLOCK knob is released for 5 seconds, the time will be stored
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
A5
Method 1
Method 2
Method 3
Press ADJ
Method 4
Method 5
go to this web site for any thing about ur stereo
http://www.clarion.com/us/en/support/faq/Audio/index.html
Feb 18, 2010 | Clarion Car Audio & Video
Cant set the time on this one at all
Setting the clock - must be done in standby mode.
Press PROG/CLOCK ADJ button . Either 12H or 24H will display.
Choose your preference by pressing the >>| button, then press PROG/CLOCK ADJ button
Press>>| button for HOUR setting, then press PROG/CLOCK ADJ button to store
Press >>| button for MINUTES setting, then press PROG/CLOCL ADJ button to store.
Oct 02, 2009 | iSymphony CR8CD CLOCK RADIO MUSIC SYSTEM...
Don't know how to set alarm clock or timer - have set clock OK
To set the Time all you have to do is hold memo/c.adj while on standby, the screen will flash 24hr if you press tune it will flash 12hr pick weather you want 12hr or 24hr and then press memo/c.adj to set the hours press tune then hold memo/c.adj to get to the minutes and then press tune to get the minutes set
May 03, 2009 | Audio Players & Recorders
Armitron WR165 watch - changing time
When you're in the regular time mode press "set". The secons should blink. Pressing "mode" brings you to the hour spot (hour should blink). Press "adj" to change the hour. To set the min., press "mode" again and the min. spot should blink press "adj" to change. Keep pressing "mode" then "adj" until all necessary time components are set correctly. Press "set" to get to regular time mode.
Aug 15, 2008 | Watches
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Samsung Galaxy Camera EK-GC100 3G White Android unlocked Camera Logo
32 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
