Renault Senic . problem with the gear.2 phenomenas. 1. during driving the car start to shake. than a bulp turn on with denotation of a coil. another event. during turning to thr right, there is a jump, the same light turn on and sometimes one more light like an engin. I already replace the throttle
SOURCE: renault megane classic 11 engine vibrates with loss of power when started
famous froggy electrics again ,renault garage to get ECU sorted ,buy a new car its cheaper than paying garage
SOURCE: RENAULT LAGUNA MARK 1 IDLING PROBLEMS AND
I have the very same problem - Were you able to solve it ?
I've
cleaned the Idle control valve several times and it seems to help
overall but definitely not the cause ! - I think it might be the Coolant
temp. sensor - have you tried changing that ?, did it work ?
Thanks mate - please let me know at [email protected] if you find a solution
SOURCE: My right indicator on my 1.2 T reg renault clio
hi, this sounds like you have a bad earth at the rear lights, remove both rear light clusters and check for any signs of corrosion, give all connections a clean and a little tweek, this should cure your problem
