Question about Netflix
Wifi keeps swiching to other network
Goes from local connection to other providers
  • Netflix Master
  • 3,368 Answers
Talk to your ISP or get closer to the signal source.
Posted on Dec 08, 2014
How can i connect my tablet to wifi without a house that dos not have Internet access in county wexford ireland.
Are you trying to just connect to wifi to access a local network or are you trying to access the internet? If you just want to connect to a local network, maybe to access other devices on the network, you would need a router broadcasting the network that all the devices connect to. If you are only trying to get access to the internet, consider purchasing a hot spot device. It will provide cellular type service and will broadcast a wifi signal that you can connect your tablet or other devices to for internet access. Hot spots will cost you a monthly fee for the service and you will have to purchase the device itself. Another possibility is to use your cell phone as a hot spot and tether the tablet to it. Just remember whatever data you use on your tablet will be charged to your data plan on your cell phone. On my nexus 5x phone, it's fairly easy to turn on (settings, under wireless and networks select more, select tethering and portable hotspot, turn on portable wifi hotspot, set a password if you want to). Once turned on, the phone will broadcast a signal that you can connect other devices to for internet access. Some cellular providers don't allow tethering. If that is the case with yours there are some apps that will still allow you to set up tethering such as AndroidTethering or Easy Tether. In the past, I've had some trouble connecting wirelessly using the apps and found that using USB tether options worked better for me.
Aug 11, 2017 | Tablets & eReaders
I am getting a ER05 Msg on my Samsug S5 in Europe. The phone was uncloced to be used in europe. Everything works fine (I think) but Im getting this message
Most likely you have WiFi calling enabled, and the local provider SIM doesn't support it. Turn off WiFi calling, and you should stop getting the ER05 message:
1. While you are in Settings, swipe to Network Connections.
2. Hit More networks.
3. Slide the Wi-Fi Calling Switch to OFF mode.
Aug 03, 2015 | Samsung Galaxy Gio s5660
How do I get my Samsung Android phone to connect to my local wifi network
the button will remain greyed out until 8 characters are typed in. My guess is that your WPA2 password is not long enough. once 8 characters are loaded you will be able to 'JOIN' the network.
Jun 23, 2017 | Samsung GALAXY ACE II X Ace2x S7560...
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
Can't connect to wifi
Step 1Ensure the Wi-Fi and Low Power button located on the top of the device is not in the Off position. This will completely shut off your Wi-Fi adaptor and prevent you from connecting to the network.
Step 2Press the power button on the left side of the device and allow the Pandigital Novel to detect local network connections. If you can't find a local connection, you may be out of range and should move closer to the wireless router until the device detects the network.
Step 3Tap the name of the Wi-Fi network from the provided connection list. If the network has a lock icon next to the name, this means you will need the network security password to log in.
Step 4Enter the security password if prompted, and then tap "Connect."
Step 5Tap the "Next" button to reconnect to the Wi-Fi connection.
Step 6Tap the "Web" button from the main menu if you are attempting to connect to a public hotspot. This will launch the Web browser where you can enter any log in information required to obtain an Internet connection at the hot spot.
Mar 22, 2013 | PANDIGITAL Tablets & eReaders
How to connect throuht wifi to my laptop
hello,
You can connect simply be swiching on the wifi on your laptop serch a network(there are some free hot spots) and click connect
Sep 22, 2012 | Dell Latitude C640 Notebook
When power goes out Wifi will not connect to laptop
You'll need to find a way to power the wireless extender during times that the power is out. Keep in mind, doing so will only allow you to connect to other battery powered devices that connect to your powered network hardware. This includes, but is not limited to the cable or dsl modem and the router that presumably is used to to provide the network connection to your wireless range extender. This could mean that you're only going to connect to LOCAL AREA devices; not the WIDE AREA devices (the internet). Even with the hardware in your area powered by batteries, it is possible that your ISP is unable to provide internet access to you due to network failure, etc.
If you still want to try, you can power your network hardware with UPS hardware that can provide as little as power to allow for orderly shut down during a power failure - to one that can provide power for significantly longer times - depending on the size and number of equipment you want to connect.
I hope this helps.
Jan 20, 2012 | Hawking Hawkin HiGain HWREN1 Wireless300N...
My i pod is connect to my wi fi but will not connect to internet
Wifi allows connectivity for device to device as local area networks. Where connecting the ipod to the computer is a local area network. Also, the computer can use wifi to capture worl wide web connectivity of the internet. The computer requires to have subscription to an internet provider server to make wifi make full capacity observeble beyond device to devcie captures. It is possible to have local and networking across distance with the the wifi.
Feb 08, 2011 | Computers & Internet
How do i swich on the wifi on my dell xps m1210
Hi
Go to Control panel
than Go to Network Conections
than Enable your Wirelss Local Area Conection
After that you will be able to use WIFI wherever a WIFI is enabled
thanks
Jan 04, 2011 | Dell XPS M1210 Notebook
Netflix Logo
12 people viewed this question
Top Netflix Computers & Internet Experts
David Payne
David Payne
L Pfaff
L Pfaff
Are you a Netflix Computer and Internet Expert? Answer questions, earn points and help others
