Question about Ricoh Office Equipment & Supplies
Richo fw760 jaming - Ricoh Office Equipment & Supplies
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
My richo d420 displays functional problem!!! What should i do????? pls. friend help me quickly.
IT'S AUTOMOMATIC JAMED, YOU HAD TO GO SP MODE IN ORDER TO RESET IT. PRESS CANCEL BUTTON, FOLLOW KEY 1, 0,7 THEN PRESS RED BUTTON SIMUTANEOUSLY FOR SEVERAL SECONDS IN ORDER TO ENTER SP MODE.
IN THE SP MODE, YOU SWITCH OFF THE MACHINE THEN LATER SWITCH ON .......WAA LA THE MACHNIE WILL FUNCTION AS NORMAL BUT IF STILL PERSIST , THEN SOMETHING MUST BE CHECKED INSIDE THE MACHINE BY TECNICIAN
Sep 15, 2013 | Ricoh Office Equipment & Supplies
Witch is better Gestetner DSm745 or richo 1045 or richo 2045 any one help me pleas
dsm 745 has more modification than1045 more comfortable less disputes little problem. technicians can see this difference there are more details but i expressed that dsm 745 is recently than 1045 good luck
Jun 27, 2011 | Gestetner DSm745 Black and White Copier
Paper keeps jaming in my Richo MP 1600 in the b section
ALL 5 SHOULD BE CONTACTING THE HOT ROLLER.GENTLY LIFT THE FRONT UPWHILE PUSHING BACK INTO PLACE. WORST CASE SCENARIO IF YOU CANT GET IT RESEATED
SNAP IT OFF. THEY ARE INEXPENSIVE IF YOU CALL FOR SERVICE THEY WILL REPLACE ALL 5 ANYWAY
May 18, 2010 | Ricoh Aficio 150 Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Richo 3310 fax
What is the model? There are not all the same for the service mode. And what is the reset code for?
Aug 28, 2008 | Ricoh FAX3900L Plain Paper Laser
22 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
