Question about Ricoh Office Equipment & Supplies
Richo fw760 jamming
Richo fw760 jaming pj07
Fixya review
This is not a 35mm camera. Please post your question in the copier section
Dec 07, 2013 | Photography
My richo d420 displays functional problem!!! What should i do????? pls. friend help me quickly.
IT'S AUTOMOMATIC JAMED, YOU HAD TO GO SP MODE IN ORDER TO RESET IT. PRESS CANCEL BUTTON, FOLLOW KEY 1, 0,7 THEN PRESS RED BUTTON SIMUTANEOUSLY FOR SEVERAL SECONDS IN ORDER TO ENTER SP MODE.
IN THE SP MODE, YOU SWITCH OFF THE MACHINE THEN LATER SWITCH ON .......WAA LA THE MACHNIE WILL FUNCTION AS NORMAL BUT IF STILL PERSIST , THEN SOMETHING MUST BE CHECKED INSIDE THE MACHINE BY TECNICIAN
Sep 15, 2013 | Ricoh Office Equipment & Supplies
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
In richo 1045, paper is contineus jam in the upper side of fixing unit
Clean oe change the upper fuser roller,fuser roller cleaning roller and clean the lower pressure(red) roller.
Jun 03, 2010 | Ricoh Aficio 450 Copier
Paper keeps jaming in my Richo MP 1600 in the b section
ALL 5 SHOULD BE CONTACTING THE HOT ROLLER.GENTLY LIFT THE FRONT UPWHILE PUSHING BACK INTO PLACE. WORST CASE SCENARIO IF YOU CANT GET IT RESEATED
SNAP IT OFF. THEY ARE INEXPENSIVE IF YOU CALL FOR SERVICE THEY WILL REPLACE ALL 5 ANYWAY
May 18, 2010 | Ricoh Aficio 150 Copier
Richo is200e scanner ADF thinks there is paper in the ADF and asks to clear the originals before trying to scan. We have checked the ADF for paper jam and tried cleaning the unit but it will not clear the...
These scanners will collect alot of paper dust. You need to remove the ADF cover and using compress air and or a vaccum blow out the jam/original photosensor's, I believe there are 4 sensors. Power OFF then ON and try it..
Mar 22, 2010 | Ricoh IS200E Flatbed Scanner
Richo Aficio 2015 I have a richo 2015 machine which has a reading of 1,08,700(number of print out taken)but lately the paper gets folded inside just above the drum. The matter does get printed on the paper...
The pressure roller is inside the fuser section of the copier. If there is a flat spot on the roller, you will get those results. It's better to rebuild the whole fuser unit including the bearings and heat roller. That will stop that jamming from happening.
Jan 26, 2009 | Ricoh Aficio 2015 Copier
MF5750 All-In-One Laser Printer DOES NOT PRING indicate paper jam I check and there is no paper jamed in the printer. It starts as it will pull the paper to copy document and then indicates in the display...
It starts as it will pull the paper to copy document and then indicates in the display that the paper is jamed.
Can anyone explain what the problem my be?
Please assist me.
Jan 19, 2009 | Canon imageCLASS MF5750 All-In-One Laser...
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
32 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
