Question about Microwave Ovens
Ms143sce My samsung ms143sce is working fine but is not warming replace main fuse becauce it was blown but still not warming what can it be
Microwave continues running whilst the door is shut - samsung ms143sce
Sounds like the timer control is faulty, it will need a technician to advise you on options
Aug 09, 2015 | Samsung Microwave Ovens
Samsung microwave oven Model # SMH9151S. Turntable not turning fan inside (not the exhaust fan) is not working either.
It may be a failed relay on the control board, which I repair affordably.
See my profile picture if you need more help.
Jun 22, 2015 | Samsung Microwave Ovens
Samsung microwave not working
First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
God bless you
Apr 02, 2013 | Samsung Microwave Ovens
Whirlpool over the counter microwave stopped working
SEE THE steps and fix it. and diagrams attached.use the DVOM.God bless you
Line Fuse
Every microwave oven has a line fuse. This fuse is designed to blow if too much current is drawn through the microwave circuitry. The fuse can be replaced, but the underlying issue should still be investigated and resolved. Otherwise the new fuse will blow also.
Main Control Board
If the microwave is not working the main control board may be defective. This is not common. When a microwave stops working the problem is usually the line fuse or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Thermal Fuse
If the microwave is not working the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave is not working the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown2_6_2013_8_43_03_pm.gif2_6_2013_8_43_37_pm.jpg
Feb 06, 2013 | Microwave Ovens
Won't run
see this causes and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Test the switchs door see diagram
Oct 10, 2012 | Frigidaire FMV156DC Microwave Oven
Kenmore microwave 911 41479791 no power?
Sep 24, 2012 | Microwave Ovens
No power. Unit was working fine when it shut down. no power of any kind. Unit is plugged in properly and outlet has power.
has a blown inner fuse or a open thermo (under the oven cavity ceiling or on the magnetron). if it's the main fuse out, you probably have a failed component.
Aug 06, 2011 | Samsung SMH8165B Microwave Oven
My samsung model ms143sce microwave is displaying error 5E or SE what could the problem be switching on and off does not solve the problem
a lot of times its the magnetron in microwaves that causes most errors and malfunctions. you will need a technician to repair this if this is the problem.
Jan 29, 2011 | Microwave Ovens
Kenmore Spacemaker Fuse Blown
its either a 10-15-or20 ceramic fuse and its marked on the side of the fuse or take it to the hardware store they have this type of special fuse.and they can locate the rating for you
Oct 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Samsung Microwave
You may have a blown internal fuse. You''ll need to unplug the unit, remove the outside cover and follow the line cord and you should find the fuse.
Replace it with the EXACT same value that was labeled on the original fuse. You'll probably be able to find a replacement at any Radio Shack store or hardware store.
Replace the cover and plug the unit back in. Hopefully nothing was damaged and the unit will play again.
Please let me know if I can be of further assistance to you.
- Jim
Feb 28, 2008 | Samsung SMH7174BC Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
