Question about ClearOne 910-156-220 CHAT 150 Cisco, Connects to Cisco telephone models 7940, 7960 and 7970, Built-in speaker function on the telephone is typically half-duplex with limited microphone and speaker range and performance, Offers true full-duplex audio, three mi
0004F23D7900 No dial tone red light flashing
Uniden phone light WON'T flash red light when I have pulsing dial tone VM messages.
The pulsing dial tone usually indicates a message on the service provider's server, not on your phone. Contact your provider to find the procedure to access these messages.
Aug 15, 2016 | Uniden Lands Phones
A red light is flashing in the corner of the handset. How do i shut it off?
If your charge light is flashing and you have no messages on your answering system, you may have voicemail. Voicemail is provided by your telephone company and they would be able to assist you with retrieving those messages.
Once you have listened to the new messages, the blinking light will stop. You may also be hearing a stutter tone before your dial tone when turning on your handset. This is also indicating you have a new voicemail message.
Sep 15, 2015 | Uniden DECT 6.0 Cordless Phone ID
Why does dial tone go beep beep beep?
It is called a stutter dial tone and usually means that you have messages on you voice mail.... But its is sounding like a motor boat, and sounds like your in a tunnel while talking. You may need to call your local repair. Could be a bad line card.. as long as its happening on all your phones..
Aug 15, 2015 | Lands Phones
I have 2 problems. 1. The orange message light will not stop flashing no matter what I do. 2. Some how the system was switched from touch tone to dial tone. I can't seem to that switched either.
Resetting the voice message waiting indicator
When you receive a new voice mail message, the new message LED on the top of the handset flashes. In the event your message waiting light gets out of sync with your phone company's
voice messaging system, you can manually reset it back to the "No messages waiting" state.
1. Press and hold FiND on the base for five seconds.
Note: The handsets connected to the base will start to beep, however, keep pressing for five seconds.
2. A beep sounds and the message alert tone is reset.
Changing the dial mode
Your phone can communicate with the telephone network in two different ways: tone dialing or pulse dialing. These days, most base networks use a method called tone dialing, so your phone comes programmed for tone dialing. If your phone company uses pulse dialing, you will need to change your phone's dial mode. If you don't get a dial tone or can't connect to the telephone network, please follow the steps below to modify your phone's settings:
1. Press MENU/SELECT.
2. Select the Global Setup menu, and then the Dial Mode submenu.
3. Scroll to highlight Pulse.
4. Press MENU/SELECT. You will hear a confirmation tone.
If you ever need to change the dial mode back to tone dialing, follow the same procedure, but select Tone in step 3.
Finally for future ease of use, here is a link to the user manual were I copied the above information from:
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DECT1580-3om.pdf
Jul 21, 2011 | Uniden DECT 6.0 Cordless Phone ID
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
The red light is flashing. when you go to get a dial tone then are 7 or 8 fast beeps then a dial tone. the answering machine says there are no messages
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Dec 04, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone doesn't ring, no dial tone.
Try switching the battery wilth a know to be
good battery
Dec 01, 2007 | Motorola Mobility MA 361 Cordless Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
Voice mail
Do your Dial tone sound different. Your phone listens to the dial tone. if you have a new voice mail your dial tone changes.and your phone does the flashy thing accordingly. Contact your phone company.
Aug 18, 2007 | Motorola Mobility 5.8 GHz Digital Cordless...
ClearOne 910-156-220 CHAT 150 Cisco, Connects to Cisco telephone models 7940, 7960 and 7970, Built-in speaker function on the telephone is typically half-duplex with limited microphone and speaker range and performance, Offers true full-duplex audio, three mi Logo
22 people viewed this question
Top ClearOne Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a ClearOne Lands Phone Expert? Answer questions, earn points and help others
