Question about Timex Indiglo Analog Watch
Turn off alarm for Acqua Indiglo
Timex Indiglo Acqua - How do I turn off the Alarm as it won't go past the hour and minute stage. I have tried all of the fixes I could find to turn off the alarm and have been unable to do so. Could this be a battery losing power or just me not getting the instructions right?
SOURCE: Alarm on timex indiglo won't turn off
It's just a cheap watch, one hit with a hammer and the alarm stopped.
Posted on Jan 19, 2010
love wr30m
SOURCE: Timex Indiglo WR 30M
to turn off hourly chime on the times wr 30m, simply press (in any mode, i just use the regular clock mode) the start/stop button (top right hand button) once (for about half a second).
  if you don't hear anything, you've turned off the hourly chime!  if you hear two short beeps, you've turned on the hourly chime.    turning the chime off/on is cyclic.  if you press once and hear nothing, it's off.  if you press again, you'll hear two beeps and the hourly chime is now on.    a lot of times that button hits my wrist (i wear it on my left hand) by accident, and that's how the chime turns on and off.  i hope this helps someone.
Posted on Dec 30, 2008
  • 8 Answers
SOURCE: need setting instructions for date,alarm,etc on my timex expedition
http://assets.timex.com/manuals/index.html
Here is the link for all Timex watches and the appropriate manuals.
This should provide you with the information you require, if you have an issue not covered there I will try to find you more specific information.
Posted on May 27, 2009
  • 18 Answers
SOURCE: Timex Triathlon Alarm Chronograph User Guide
i suggest you reset your watch
Posted on Mar 05, 2010
mcdevito75
  • 1970 Answers
SOURCE: Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Posted on Aug 18, 2010
Jan 18, 2010 | Timex Expedition 84601 Wristwatch
Timex 1440 sports wach chime disable
Press the mode button until the Alarm apears. Press the Start/Stop button to turn the alarm on/off and remove/add the chime. Whew! I had to figure this out after my 3 year old turned the chime on!
Aug 30, 2009 | Timex 1440 Nylon watch
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Acqua Indiglo watch
Can't understand instructions
Aug 31, 2008 | Watches
Aug 12, 2008 | Timex 27191 Wristwatch
Acqua Indiglo water resistant watch with alarm 30m
Press and hold the MODE button (bottom left) for approximately 3 seconds.
When the Alarm set time starts flashing, press the MODE button once more. Now the seconds for the watch time should be flashing.
Use the START/STOP button (top right) to move bewteen items and the SPL/RESET button (bottom right) to change the item.
Moving between all items, it will take you through: seconds, minutes, hours, month, date, day of the week. Simply press MODE when your settings are complete.
Jul 25, 2008 | Watches
How to set
in order to unset the military time on the watch you must hold down the two top buttons until the the 12 hour format comes back. in order to turn off the alarm you must hold down the two right buttons until they beep..and then the alarm will go off
Jul 12, 2007 | Timex 1440 Sports Aggressor 56014 Wrist...
Timex Indiglo Analog Watch Logo
409 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
