Question about Sony PlayStation 3 40GB System
The ps 3 is tell me that the hard disk database will be rebuil push ok. When I hit ok it comes back to the same message.
    Genius:
  • 1,269 Answers
You need to reset the unit to factory defaults and perform a system update. If the unit wont allow you to do it, you must contact Sony for them to replace your hard drive
Posted on Jun 15, 2009
My playstation 3 gave me screen gave me a message of " The hard disk database will be rebuilt." Can anyone tell what this means????
Firstly don't worry, your HDD has become corrupted which is quite common if you don't switch your PS3 off properly.
Its difficult to say whether you'll lose any data or not, but if you rebuild the database your HDD should be fixed. If it gives you an option to rebuild the database then choose it.
If it doesn't then access the recovery menu and choose option 3 as described in the thread below.
http://community.eu.playstation.com/playstationeu/board/message?board.id=147&thread.id=28562
Any further questions feel free to ask.
Correct? a nice vote would be awsome
Nov 20, 2010 | Sony Playstation 3 (PS3) Console
Wont start messages comes up saying correct hard disk not found
your hard drive may be dying. or the file system may be corrupted.
before you get a new hard drive there are some tricks to try.
#1 remove the HDD and boot it up without it in, then turn off and put the HDD back in and boot again.
#2 rebuild the file system in the recovery menu
#3 rebuild the database in the recovery menu
To get to the recovery menu you need to press and hold the power button when the ps3 is in standby mode untill you hear a double beep then release. sometimes the ps3 will go back to standby mode before it does the double beep if it does just release the button and press and hold again real fast and wait for double beep.
here is what mine does
ps3 standby(red light) press hold power...........beep...............beep.........standby again, release hold............beep..................double beep ..release power button.
from the recovery consol you can rebuild the file system and database sometimes when they are corrupted it has same symptoms as a dying HDD.
P.S. rebuilding the file system and database will not lose any of your ps3 data, other options will though like the restore ps3 and format HDD.
if the above tricks dont work try updating the firmware, if your at the current firmware you can re-install it from the recovery menu as well using a usb memory stick or a cd with the firmware on it.
if all that doesnt help it looks like its time to get a new HDD, but at least you can upgrade it to a bigger ps3 now. any sata laptop HDD should work. i think a 160gb HDD is only $50ish.
Oct 08, 2009 | Sony Playstation 3 (PS3) Console
Yes my playstation 3 is saying hard disk needs to be rebuilt and it only says ok so i click ok another message pops up and says hard **** not found hard disk data will be deleted and lets you selesct ok or...
you could try to remove the hard drive then boot up, then put the hard drive back in and boot and see if that helps or you can try to rebuild the file system and database.
To get to ps3 recovery console to rebuild the database or the file system(neither will format the hard drive), when the ps3 is in standby mode(red light) press and hold the power button till you hear a double beep.
Most of the time the double beep comes after the ps3 beeps once then twice then turns red again when red again release and press again real fast and hold,... this time you will here a "beep" then " double beep beep" then you release and you will have the options to rebuild the database or the file system. basicly keep holding power button from standby till you here a double beep, if it shuts down try again, once you get the hang of it its easy.
if rebuild database and file system doesnt work then you may have to choose yes on the reformat option but it will wont hurt the ps3 itself just anything you have saved on it.
Sep 22, 2009 | Sony Playstation 3 (PS3) Console
Will not load games
I had a similar problem. My PS3 did not load the disk based games. Those disk based games were not visible in the game menu.
I did not have problems with the normal movie DVDs or Movie Blu Rays. Those were working fine. Also downloaded games were working ok.
In case you have the similar problem, you should try the following steps;
The PS3 has a special Recovery Menu, which you can access in the following way;:
1. Turn off Playstation 3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION 3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION 3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION 3 System
Select option "Rebuild Database".
After PS3 has executed the DB rebuilding operation, the disc games will be visible again in the menu and are starting automatically when inserted to PS3.
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
He hard disk's file sys is corrupted and wil not restore!
Instead of doing the restore first, do the full format matey, then go through restore
Feb 17, 2009 | Sony Playstation 3 (PS3) Console
My PS3's hard disk file system is corrupted
There is an alternate way to restore your HDD. Turn off your system and when u see the red light, hold the power button in front until you hear a total of 4 beeps (1 alone, 1 alone, 2 together). It usually works on second try. it should show a screen and say hook up controller with a usb cord. Then it should show i think 6 options. Choose the restore option. it should work.
Hope it works and wish you all the best!
P.S.- I just got the 80010514 error on my ps3 and my ps3 games dont work anymore :(
Jan 07, 2009 | Sony Playstation 3 (PS3) Console
Start up problems
if there is any way that you can get to your ps3's main memory, either restore your system or open up your ps3 and find its memory and take it out and put it back in.
Nov 20, 2008 | Sony Playstation 3 (PS3) Console
The Hard Disks database will be rebuilt
this is very bad this what is called a sudden power shut down, you can do nothing take you ps3 back to the retailer or call a repair center
Jun 20, 2008 | Sony Playstation 3 (PS3) Console
Open Questions:
Sony PlayStation 3 40GB System Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
