Question about RCA Televison & Video
Hi. my name is christopher.i was searchnig online see if i get any idea how to reset my 55 Rca Home Theater project tv. If anyone Can help me, the tv screen showing a litle burnish, the tv stay on long and after that its show the screen burn.How do i reset the tv, to factory setting. let me no if you have any idea how to fix this.
    New Friend:
    Problem Solver:
  • 6 Answers
Look deeply through the menu and you might find this - most electronic devices have this option. Another option (always a go to with electronics) is to unplug the unit for a period of time. I have seen issues with burn in and I am note sure that a hard reset will remedy this for you - but certainly worth a try. Good Luck!!
Posted on Mar 25, 2014
Testimonial: "Ok thanks alot i will give it a try"
  • 236 Answers
SOURCE: rca d52w15byx1 projection 52"tv
HI, Joe ! You probably have a short somewhere. Where? Possibly in the High Voltage circuit.Maybe the horizontal out put circuit. This is a common signal,especially RCA's, that there is a heavy load on one of the power supplies--- like a shorted transistor or ? Stargazer
Posted on Jan 21, 2007
CO3OV
  • 9 Answers
SOURCE: lg television du-27fb32c reset to factory settings
mute on the remote and menu on tv
service mode and go to factory reset
Posted on Dec 17, 2007
Benimur
  • 6966 Answers
SOURCE: reset older analog tv
Without the original remote, sorry none. You could try pressing on any of the buttons or a combination while plugging in the unit but that is no guarantee it will reset (fully). With your indulgence, I took the liberty of checking your other posts here and here. It would seem that your original concern is that although the TV would appear to be switching to the lower channels (Ch 2-6), the TV programs on those channels would not be displayed. If yes, then I am inclined to think that there is a hardware fault internal to the TV. This would be the tuner block. The reset, even if successful, would not correct this error.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 18, 2008
wyoed1
  • 211 Answers
SOURCE: Picture on RCA TV shrinks to a horizontal line
Sounds to me you have a cold solder joint ( loose solder connection ) on the printer circuit board around or on the vertical chip or on one of the vertical capacitors. You may also have a bad vertical chip or a bad vertical capacitor, but I doubt it since it did come and go. I'de get a soldering iron and some solder and touch up the connections. I will remind you that you need to always excersise saftey by making sure, before removing the back, unplug the TV from the wall, and use care not to come in contact with the large red wire going to the back of the picture tube as the picture tube can be turned off and still store lots of voltage ( up to 35,000 volts). Always stay safe and when soldering, use care not to run solder across places that will make a short.
Good Luck and I hope this helps
Ed Meshechek ( Radio Man )
NC Electronics
Mills, Wyoming
307-266-4675
Posted on Dec 19, 2008
nfandres
  • 168 Answers
SOURCE: RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Posted on Aug 16, 2009
Hi all I have philips pwr 2006/37 complete home
use rca component hi fi cables red white blue purple and video cable to rear of tv .
Aug 30, 2014 | Audio Players & Recorders
Cant get hd sound through home theatre system
Hi,here is my simple solution...
to listen your TV on your
Panasonic Home Theater System
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out "of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
Panasonic Home Theater System RECEIVER corresponding your RCA or Optic or HDMI connection
There you go..Your TV sound is on the
Panasonic Home Theater System Receiver..By this means whatever you watch on the TV (TV tuner, satellite , Xbox ..etc.) ,it's sound will come thru your stereo..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 26, 2011 | Panasonic Home Theater System System
I have an RCA 52 " projection TV thats now 6 years
you have to run theater system eather through your vcr or your dvd player for mor out put jacks and input jacks on older tvs but the thing is your dvd player remote will be your tv remote the same as your vcr remote.
Feb 13, 2011 | RCA P52937 52" Rear Projection Television
Rca television home theater premier 52' went out of focus how do i fix
unplug the TV for 4 hrs. and it will reset to factory settings maybe that will help and then you have to run setup again of course.
Jan 02, 2010 | RCA P52937 52" Rear Projection Television
RCA Home Theater Premiere 36" TV comes on automatically
Only two possible reasons I can think of for this--
ONE: you have looked in the customer menu and there is no item listed as Timer?
TWO: Does THIS SET HAVE THE GUIDE PLUS LOGO ON THE FRONT OF THE SET? IF IT HAS THE GUIDE PLUS--YOU WILL FIND IT IN THE MENU ALSO---
LET me know if it has the guide plus feature and I can tell you how to end the problem--most of these the set will come on at the same odd time and usually with volume up high.
SD TECH
Dec 26, 2009 | RCA P52937 52" Rear Projection Television
Reset button on 52 in rca rear p52940 home theater projection television located
this set does not have a reset button if there is a system lock out unpluging it for 3 or 4 mins will reset when pluged back in
if that does not help try trouble shooting the set ck the ac fuse and so on
Oct 24, 2009 | RCA P52940 52" Rear Projection Television
Can't get it back to tv input - tv connected to 2 direct tv satellites. changed input to dvd mode and now tv mode won't come back up. went to menu to change input and still cannot get tv to come up
You set may be set to Home Theater mode.
I think it is in the advanced menu.
Set home theater to off. This will fix the input on the television to input one, no matter what you do.
I hope that this helps you.
asnowman
Oct 01, 2009 | Mitsubishi WS-55819 55" Rear Projection...
Hook up to tv
hello there. name is ryan lets see if this helps.
typically in a combination unit there is no rca audio ouputs on the tv. reason being is it is a combo unit not meant to be a item within a home theater system. it has the whole home theater built in it. ;) however if there is any audio output jacks on the tv you should be able to wire the surround sound unit up via rca cable output from tv to input on reciever for surround sound
Feb 13, 2009 | GPX DV7500 System
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Rca rt2280 home theater
hi my son lost my tv remote for my toshiba tv, i was hopping my rca universal remote could adapt to my tv but i do not know the codes how to program it does anywhone have a solution thanks.
Feb 12, 2008 | RCA RT2280 System
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
