Question about Sansui Televison & Video
TV SHUTS OFF ITSELF AND DONT WANT TO COME AGAIN ON
    Top Expert:
  • Sansui Master
  • 75,157 Answers
Check and replace damaged component/s at its main power supply regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Posted on Mar 25, 2014
SOURCE: LG TV
necesito la pantalla de un tv lcd de 42¨ pues se rompio donde puedo encontrar el remplazo
Posted on Apr 24, 2008
  • 2334 Answers
SOURCE: Polaroid LCD tv - model TLX-04244 Shuts itself off...
The solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
If your TV is less then a year old, still under manufacturers warranty.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Dec 06, 2008
  • 92 Answers
SOURCE: Tv shuts itself off
If the TV were in my shop I would first suspect the PSU is failing as it reaches a certain temperature. Capacitors most likely.
If you have a capacitance tester, then it will be easy, if not.....
The capacitors that have / are failing will generally be "bulged" on the top.
However, it is worth noting that they are only a few pennies each, if it were me I would change them all for equivalents.
I hope this helps.
Posted on Mar 28, 2009
SOURCE: lcd tv shuts off by itself and then turns on by
philips tv turns itself off and on agianevery 10 mins roughly with a gap of a few mins before coming back on. only had a few months
Posted on Dec 28, 2009
SOURCE: Vizio shuts itself off
I have found that turning off the power for awhile will work as a temp fix for a couple of days and then just repeat the process.
Posted on May 28, 2010
Tv Shuts off By Itself
When something like that happens the problem is probably in the power supply section of the receiver.
Jun 20, 2016 | Mitsubishi Televison & Video
We have the RCA HD52w59 projection tv. The tv shuts itself off at different intervals. It takes approximately 1 minute to be able to turn the power button back on, however, I have to do that many times...
A problem in the deflection board. Could be a Cap. Resoldering the deflection board may take care of the problem. You need to call a TV man to do this kind of work.
Best of luck
Nour Sabre
WWW.AAATVSERVICE.COM
Jul 28, 2011 | RCA HD52W59 HDTV Projection Television
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv shuts itself off
The power supply may be going on to protection mode. This is usualy because one of the scan amplifiers may have failed, or something is taking too much current and forcing the power supply to shut down.
Jerry G.
May 12, 2008 | LG RU-52SZ51D 52" Rear Projection...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV LED Flashes then TV shuts itself off
capacitor problems in power supply or a regulater isolate the power suppley by disconecting the line output stage/unplug scan coils for example and run a 60w bulb as a dummy load one wire to earth and the other to rail voltage colecter of line output transister if the bulb glows steady the power supplys fine
Jun 25, 2007 | Philips 27PT81S 27" TV
Televison & Video Logo
88 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
