Question about Canon PIXMA MP970 InkJet Printer
U052 the print head is incorrect install the correct print head
SOURCE: Canon Mp 610 error u052 incorrect print head
Hi I have U051, and U052 coming up, I did what it said to do press ok if that doesn't work turn it off, now it is continuously going to these problems. What do I do.
Posted on Mar 17, 2009
komguy
  • 2306 Answers
SOURCE: U052 prnt head is incorrect install the correct
You can check that it's installed properly, after that all you can do is replace the printhead. They are like a light bulb and burn out when you least expect it. If you printer is less than a year old Canon will replace the printhead, after a year you have to buy a new one. Anywhere from $60.00 to $100.00 The part number is on the side of the printhead, the number starts with QY6, the numbers after that are the actual part number.
Posted on Dec 16, 2009
x404x
  • 51 Answers
SOURCE: My canon MP610 shows an error message U052 Incorrect print head
http://www.buzzillions.com/review/canon-pixma-mp610-multifunction-photo-printer-review-2458903?prRo=0&reviewSortBy=mostHelpfulFirst&prRpp=1
you wont like what you find. lol .
apparently if you call cannon support they going to tell you its a U052 is a temperature sensor error. and not the print head error. someone musta did some bad programming. lol
try returning the cartridge if its not a canon specific cartridge - and get replacement - try that - but i doubt its going to work - i would call about a new one (print head that is - they will also apparently send you a new print head.) as i have read up on
hope this helped x404x
Posted on Mar 01, 2010
Testimonial: "Thanks for your quick response - I thought there was a resetting tool available so I can at least remove the message and get printer going."
  • 63 Answers
SOURCE: Pixma MX860 - Error Code U052
Kindly follow this link: http://support-hk.canon-asia.com/contents/HK/EN/8000138702.html
Thanks
Sachidanand
Posted on Apr 13, 2010
Testimonial: "Thank you. I thought I had already reseated the component, but the graphics of this response were very helpful to insure I did not miss a step - K"
SOURCE: I have a Canon PIXMA MX 860. Why am I getting U052
says code uo52
Posted on Sep 05, 2010
Errr u052 cannot print .
A lot of Canon printer's users come across with the error message, "U052 This type of print head is incorrect." It is a very common error on Canon printers and is fairly easy to troubleshoot.
There are two different scenarios related to U052 kind of error message.One is where the print head is not installed at all and then it is giving the 'U052 This type of print head is incorrect' error message.
And, the second scenario is where the print head is installed nut it is not functioning properly or probably not working at all. The below section will show step by step troubleshooting of both the scenarios.
Jun 19, 2014 | Canon MX882 All-In-One InkJet Printer
Message on printer says "The
The HP D145 uses a special print head cartridge for each ink cartridge. They are not interchangeable.
Apr 15, 2011 | Office Equipment & Supplies
U052 error - The type of print head is incorrect. I have not changed the print head from new, and have done all that was suggested in the on screen help list. It would appear that I have to replace the...
u Can Follow this step :
http://support-sg.canon-asia.com/contents/SG/EN/8200986100.html
if that reference can't solved, in other reference i found this statment
http://www.canon.co.uk/Support/Consumer_Products/products/Fax__Multifunctionals/InkJet/PIXMA_MP_series/MP620.aspx?faqtcmuri=tcm:14-610963&page=5&type=faq#Print%20head%20is%20not%20installed.%20Install%20the%20print%20head.%20U051/The%20type%20of%20print%20head%20is%20incorrect.%20Install%20the%20correct%20print%20head.%20U052
" Print head is not installed. Install the print head. U051/The type of print head is incorrect. Install the correct print head. U052 Follow the directions given in your setup sheet to install the Print Head.
If the Print Head is already installed, remove the Print Head once and then reinstall it."
Nov 17, 2010 | Canon PIXMA MP600 all-In-One InkJet...
I have problem with my mp600, in the lcd displayed error code u52. how to fix it?
This means The type of print head is incorrect. Install the correct print head." U052
The solution is follow the directions given in the Easy Setup Instructions to install the Print Head.
If the error is not resolved, the Print Head may be damaged and may need replacing.
Oct 02, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Nov 21, 2008 | Canon MP610 Photo All-In-One Printer
Code U052
Dear dgthorpe,
This indicates that printhead of your printer faulty. Commonly this problem come with short circuitry problem in printhead so it may harm logic board and carriage unit too. I suggest you to try checking with another printhead first.
Regards,
Oct 10, 2008 | Canon MP970 Photo All-In-One InkJet...
Pixma mp600 error code u052 ,type of printer head is incorrect. Need to know how to remove & reinstall as pre instructions on page 69 of manual
Got the error U052.....with incorrect print head. Has been printing just before. How do I remove the printhead and place it back in. My printer is Canon MP610
Jul 26, 2008 | Office Equipment & Supplies
Code U052
It's most likely an after market cartridge. Try a diiferent one or get the OEM.
Jun 02, 2008 | Canon PIXMA MP810 All-In-One InkJet...
Canon PIXMA MP970 InkJet Printer Logo
15 people viewed this question
old marine
old marine
