Question about MGE UPS Galaxy 3000 UPS System
No output Starting up the ups galaxy 3000 10kva using the normal procedure from bypass to test to normal position q1 on then qf1 on display switches on boards synchronizes then the yellow LED indicating static bypass on but no output to the load ! what could be the problem?
  • 21 Answers
You should start with Rotary switch on "Maintenance Bypass" position and Qf1 open.
Turn Rotary Sw to "Test" position and wait for self test to execute and UPS to turn on.
Once you get the Yellow lamp lit, it is asking for QF1 to close
Once closng QF1, if green LED is lit, turn UPS off by pressing gray button until it ask for confirmation, select Yes and press Return.
Turn Rotary Sw to Normal position, press On button and the green LED will illuminate.
If, after closing QF1, the green LED didn`t lit, turn Rotary Sw to Normal, press On button and wait for green LED to lit.
Thats`it...
if anything is not working well.. please let me know.
Posted on Apr 15, 2014
Testimonial: "The rotary switch was defective and the phase sequence wrong all is now ok.Thanks for your assistance."
3 Suggested Answers
epettingill
  • 175 Answers
SOURCE: when switched the bypass to
You didnt start the UPS correctly because the static switch was not on. The Static Switch has to be on to get a clean transfer of power. Check your static switch
Posted on Oct 27, 2011
mestrada642
  • 21 Answers
SOURCE: internal problem galaxy 3000 ups
The question is not clear... which of the LED`s are lit?? green, yellow, red.is there a message on the screen??
Posted on Jul 12, 2012
My motorcycle won't turn over. Battery is good, horn and lights work. If I turn the kill switch on and off a couple of times or rock the bike, she will start right up
Hi Anon, since your bike does start when it is rocked, we may suspect a problem with the wiring. Your Suzuki has at least three safety switches which prevent starting the engine unless certain procedures have taken place. First we must determine the efficacy of these switches. With the ignition key on, kickstand up, transmission in neutral, clutch handle depressed, emergency shut-off switch in the "On" position, depress the starter button. Normally, the headlight will dim when you depress the starter button. If it does dim and the engine does NOT crank, the problem may be low voltage from the battery or internal starter issues. If the headlight does NOT dim, there could be a problem with one of the safety switches, ie. Kickstand, clutch, neutral etc switches. To determine if one of these switches is defective, use a jumper lead to bypass each.....one at a time. Since the kickstand is most vulnerable to debris, check it first then you must locate the others and do the bypass elimination test. It is not advisable from a safety standpoint to leave a jumper wire in the circuit to circumvent the purpose of a safety switch. This procedure is for testing only. Have a nice day. Herb
Mar 13, 2015 | 2009 Suzuki Boulevard M50
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
When i execute the ON key it recieved the command but the LED 34 which is the ON LED of the UPS won't ON the LED 35 and LED 36 is ON always.
what alarms are shown on the display??
measure voltage of batteries, you have to read 13 to 13.5 volts.
what is the status of QF1 switch and Rotary Sw??
Feb 23, 2014 | MGE UPS Galaxy 3000 UPS System
Apc symmetra px stuck on self test
Place UPS into internal Bypass (Static Bypass) via the display. Then place unit back to Normal from Internal Bypass(Static Bypass). See if that helps. Or shut the unit down completely by placing UPS into Static Bypass first and then place UPS into external bypass mode, switch is located on the bottom front of the UPS. Please follow the UPS Manual to help you understand the procedures. Also recommend doing this after hours, not during business hours.
Jan 15, 2014 | APC Symmetra PX (SYCF80KF) UPS System
When switched the bypass to normal position, voltage failed through the unit; however the QB3 position gives output voltage
Sep 14, 2011 | MGE Galaxy 3000 UPS System
I can't get am or fm reception. I can get output from 6-direct input but can't get radio output.
What happens during normal setup test tones?
The tuner requires an antenna and a station tuned for reception. But the audio will not be forthcoming from ANY source (*) if you have a switch out of position like, say, Tape Monitor.
* 6-direct bypasses Tape Monitor all other audio processes and sources. Disable IT.
It's in the manual - page 10.
May 23, 2011 | Sherwood RD-6500 Receiver
Symmetra LX "Intelligence Module Fault". Does
First calculate the total load of the UPS and then calculate the total load. One of the Intel Module is Primary and one is Secondary. I can't remember exactly which one is primary. Q1. There will be a LED on the INTELI MODULE flashing RED. That identifies the bad MODULE. Q2. You can remove the MODULE, but I recommend you place the UPS in Static Bypass first through the Display Menu. Also make sure the UPS is in NORMAL MODE or already in STATIC BYPASS, the LED's on the Display should indicate what mode its in. Q3. You can remove the display from the Inteli Module with out harming the load. You just can't do anything with the UPS, as to tell it to Go to Bypass (Static Bypass) or get out of Bypass, check voltages, etc. So order the part first by getting part number on the sticker off the Module, then schedule your shutdown and perform the you maintenance after hours this way you don't affect anything during business. Also don't do the repair on a Friday due to the fact its weekend and APC/Third party UPS companies will charge you a lot to come out in the weekends. FIRST DO THIS PLEASE- GET THE MANUAL FOR THIS UNIT!!!! And READ IT FIRST!! Find in the manual where it walks you through putting the UPS In bypass (Static Bypass). Follow the manual, My way of doing is to READ TWICE, OPERATE UPS ONCE!! This has help me not dump any loads. My suggestion to you is to check if unit is in Bypass (static Bypass due to the faulty module. If it is on Bypass then all you need to do is follow the procedures to place UPS in External Maintenance Bypass. If UPS is in Normal mode but with Alarms and Beeping, then Navigate through the display and find the BYPASS Mode. Then hit enter Yes on the BYPASS MODE, it will ask you again if you want to "Place UPS INTO BYPASS. Hit YES. You will hear it click. Your LED on the display should Light UPS Solid "BYPASS LED ON" AGAIN Please keep referring to the MANUAL. Once your in bypass mode (Static Bypass) then you can operate the External Bypass Switch on the bottom of the UPS. That is the Maintenance Bypass Switch. This isolate the UPS completely and your load never see's the transfer from Static Bypass to External Bypass, Because its a MAKE BEFORE BREAK System. (Make the power before Breaking the Power) Sorry to get down to simple terms, but when I work on a UPS its personal due to the fact you are responsible for the all that is on the OUTPUT of that UPS. Once on External Bypass, You can now do you module swap. Turning the UPS back on, Please follow place UPS back On Line in the UPS Manual. Also in the Diagnostics, off the display of the unit, it also identifies what module is bad including the Power Modules to the Battery Modules.
Nov 03, 2010 | APC Symmetra Tune-UPS technical support -...
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Bypass procedure SL20KHB2
First Press the user menu button
then scroll up or down till you reach on put UPS on bypass? Press C to change to YES if the default is already YES just press the # button then the UPS will go on bypass mode.
Go to UPS bypass panel and turn the bypass switch to (1) ON and Switch the Output on the bypass panel to off. Now you're already on a bypass mode.
if you have any query please drop me an email.
Thanks
Feb 20, 2009 | APC Silcon UPS System
UPS not charging
Sir, Our UPS is not charging at all. After following the procedure for shuting and starting up, it show battery charging 0%. The model is MGE Galaxy 3000 UPS and also cooling fan is going to falt mode .with best regards
Jul 02, 2008 | MGE Galaxy 3000 UPS System
MGE UPS Galaxy 3000 UPS System Logo
132 people viewed this question
Top MGE Computers & Internet Experts
Jax Planet
Jax Planet
Raj Patel
Are you a MGE Computer and Internet Expert? Answer questions, earn points and help others
