Question about HP DesignJet 5500PS InkJet Printer
Print head printhead replace option again and agian diffrent printhead
    New Friend:
  • 10 Answers
The carriage does not accept one or more of the printheads. Typical causes are dirty contacts on the printheads or carriage, defective printhead(s), or a defective carriage.
If parts are replaced or fixed in any of the steps listed below, attempt to verify printer functionality by turning the printer on and printing internal test prints. If functionality is verified, no additional parts should be replaced.
  1. Turn the printer on.
  2. Allow printer to complete initialization.
  3. With the printhead icon highlighted, press ENTER.
  4. Select Replace Printheads and press ENTER.
  5. If the message "Printheads still functional" appears, select Yes to continue testing the printheads.
  6. Open the top cover.
  7. Open the carriage cover and remove all of the printheads.
  8. Turn the printer off.
  9. Clean the electrical contacts on the carriage and the printheads using a lint-free cloth dampened with water.
  10. (for this step I suggest using the erraser on the back of a regular pencil instead of a cloth and water)
  11. Allow the contacts to dry.
  12. Reinstall the printheads and close the carriage cover.
  13. Close the top cover.
  14. Turn the printer on and attempt to verify functionality, as instructed in Step 19.
  15. If the error reappears, replace the affected printhead(s).
    NOTE: If the printhead error icon is a question mark, each printhead will have to be tested separately, as the printer is not sure which printhead is causing the problem.
    1. Following replacement of the suspect printhead(s), attempt to verify functionality (Step 19).
    2. If the problem persists following, replace the carriage and trailing cable (refer to pages 8-36 to 8-46 of the service manual).
    3. Following replacement, turn the printer on.
    4. Make sure the printhead alignment completes successfully and that no error messages appear on the front panel.
    5. Print a troubleshooting plot (as instructed below) to ensure the print quality is acceptable.
      1. On the front panel, select the printer icon and press ENTER.
      2. Select Utilities and press ENTER.
      3. Press the UP and ENTER buttons simultaneously.
      4. Select Yes to enter the Service Menu.
      5. Select Service Utilities and press ENTER.
      6. Print pages 1, 2, 3, 4 and 5 to prove printer functionality.
Posted on Mar 25, 2014
ctf1800
  • 4402 Answers
SOURCE: Printhead
sounds like a cable is off or broken.
Posted on Apr 24, 2008
SOURCE: HP D135 - replaced printhead - still doesn't print in that color
try this link : I followed the directions and fixed the problem. the instructions that came with the new printhead weren't really complete.
Here's essentially all I did for my fix - Opened the printer top, turned the printer off. Removed the "bad" printhead, cleaned the metal contacts on the printhead and printer with windex. Closed the printer. Turned it on. waited for it to reset. Opened the printer. Turned the printer off again. Installed the printhead. Closed the lid. Plugged the printer in again. When it was ready I accessed the HP toolbox and alligned the printheads and cleaned the printheads. It worked. Here's a link with photos.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa02107&lc=en&cc=ca&dlc=&product=64986
Posted on May 01, 2009
  • 161 Answers
SOURCE: I replaced all my printheads. Also Both the black
call the manufacture or tech support. Maybe there is a printhead reset on the printer??
Posted on Sep 26, 2009
  • 5 Answers
SOURCE: I have the error: The following printhead has a
take it out. Shake real hard over a sink. Worked with mine after spending 30 minutes with support...
Posted on Dec 19, 2009
SOURCE: Black And Yellow printhead problem on 2 of our
how can i change my black ink to print blue ink the black has run out
Posted on Mar 19, 2010
Printhead pixma ip 1000
wipe out print head connection point with arosel and instal head again
Dec 28, 2013 | Canon PIXMA iP1600 Printer
My printer is telling me to reseat M-Y printhead, what do I do?
Hello pls go to the menu option & chose the option of replacing the head then pull out the M-Y head & Reseat them & calibrate the print head ,problem will be resolved if not then replace the print head .
Aug 11, 2011 | HP Designjet Z6100 InkJet Printer
Hello, Does not print yellow
its ok. kodak printers have inkjet printheads that have nozzles in them. take out cartridges and printhead and reseat them again,from home center ,clean the printhead.if the does not resolve the issue,call kodak @ 1800 421 6699 . kodak replace printheads for customers free of cost.
Jul 22, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
How do I clean the HP designjet 110plus printhead
You need to go to the hp download site and download the System Maintenance Utility Software. Its free, but you need it before you can clean the print heads. also, for some reason it works best when hooked to the network, not directly to Computer.
Mar 06, 2009 | HP Designjet 110plus nr InkJet Printer
Printhead (R), Check Printhead - Canon IPF5000
that confirms Right Print head is may be Out of Ink or near to low ink level.
check whether there is any option to Disable Alerts in printing preferences..print settings >> printer settings
Feb 18, 2009 | Canon imagePROGRAF iPF5000 InkJet Printer
Poor picture printing
Do not try to clean print head again and again, it consumes too much of ink.
Try reseting print head and then calibrate it.   after then check nozzles and align prinhead.   Now u can try cleaning printhead last time.
If it does not fix your issue , your printer needs to be replaced  (In case printhead has already replaced within 30 days)
MS
Dec 22, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
Printerhead need replacing
Printheads are very sensitive and HP sets a "Time" limit of about two years for # 11 printheads regardless of how much you print. ( This is bunk from HP of course!.) But the prinheads do not expire!! They just show their health and that the printhead has exceeded the warraty period ( regardless of how much you print) .
Remove the printheads from their socket and fill a 8- 12" dish with 1/4" high of warm water. Set the printheads in the water in the same position they are set in the printer (vertical) You may need to place a wooden spoon of a block behind the printheads to keep the heads in position, as they will tilt backwards.
Leave the printheads to soak for about 15minutes.
Remove the printheads and slightly press them on a folded kitchen paper towel .It should show two lines of the same color of the printhead (cyan, yellow, etc) If the two lines are not of the same length (about 1/2" long) then repeat the soaking for that color. Be sure to dry the printheads properly
Install the printheads in the printer socket vertically so the contacts are properly set.. If not you may get a message to "Install (color) printhead". reset it again and run at least 15 pages with color information. It should print ok!!
If any print heads is damaged then the only option is to replace it with a new one.
It may be that the ink line from the cartridge to the printhead is clogged and ink is not flowing. This may require to run a large print job of about 50 or so pages to force ink into the clean printheads.
The terminal strip behind the printhead that makes contact with the pins in the printer are very delicate and if removed two to three times may not make a good contact and render the printhead unuseable.
Good Luck!!
JoeA
Dec 05, 2008 | HP Business InkJet 2800 Printer
Only half of the 6c nozzle check pattern working
That issue usually indicates a bad printhead. I had to fix a lot of i9900 printers, and after cleaning the printhead there still was no change. Other models do that too when the printhead starts going out. This is an expensive printhead, but easy to replace, as you know. Link below to some options:
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p3984.m570.l1313.TR0.TRC0.H0.Xi9900+printhead.TRS0&_nkw=i9900+printhead&_sacat=0
Jun 09, 2017 | Canon i9900 InkJet Photo Printer
Red and Yellow not Printing at all.
Did you use third party carts?
If yes, buy original brother ink carts and do the cleaning cycle again. If you are lucky the printhead isnt clogged due to the third party ink which has not the additives and glycerin needed for the printhead to run without probs.
In case the head is clogged there is nothing more what you can do. Sorry!  A replacement might costs more than a new mfc 440cn!
Oct 16, 2007 | Brother MFC 420CN All-In-One InkJet...
HP DesignJet 5500PS InkJet Printer Logo
183 people viewed this question
Ben Johnson
