Question about Edimax Computers & Internet
Edimax bonjour bonjour service
What is "Bonjour Service" and how do I get rid of this which is on my advent file
http://apple.stackexchange.com/questions/45765/do-i-really-need-bonjour-on-windows
May 02, 2014 | Malware Remover Computers & Internet
Tip
How can I get my Windows PC to see my printer(s) on my Mac OS X network?
I am sure this question has arisen more than once, as to just how to locate and use the network printer in your Mac OS X network,so you can print from your Windows PC. After all, the Macs you have in your network print with no problem, why not the PC?
But nothing seems to work, that you have tried. So what to do?
Well, the answer comes with a simple yet very effective technology implemented by Apple Inc., just to address this issue.
It is a zero configuration networking protocol known as Bonjour.
Bonjour formerly known as Rendevous, was implemented from the Zeroconf (Zero-configuration) service delivery protocol and first introduced by Apple in its software with the release of the Mac OS X 10.2 Jaguar system.
In lay terms, what "Zero Configuration Networking" means to you, is that you do not have to be computer geek or guru, to simply install or configure this software, because it was designed for the most part to automatically discover computers, devices, and services on local IP networks.
The "local IP network" being described here, is your own network, whether it is in your home, home office or anywhere you have a network setup.
What makes Bonjour so efficient, is that it can work with PCs in order to work with devices connected to Macs. To use it, all you need to do is install the software to your PC. Macs with Mac OS X versions from 10.2 to 10.6, of course, already have Bonjour as a built in feature.
So how do I use Bonjour to discover printers on my Windows PC(s)?
It really is a simple as 1 -2-3.
1.) Download Bonjour - You can simply search for it by name through
Google or your favorite web search engine, or
click the link below to install in on your PC.
Download and Install Bonjour for Windows
2.) Install Bonjour - Simple enough, install it once the download is
complete. In the example below, I use my Epson
NX415 printer as a network printer on a Mac OS X
network, that needs to be discovered by a Toshiba
Laptop with Windows Vista Sp2 also a part of that
network.
3.) Launch Bonjour to discover the printer(s) in your network -
a.) Introduction Screen:
You will be very satisfied when you see how little
effort you have to put into discovering the network
printer on your PC with the Bonjour Printer Wizard.
**Note: Keep in mind, the network printer must be properly
connected, turned on and functional, otherwise Bonjour
will not discover your networked printer with your PC.**
b.) Printer Discovered:
Printer in Mac OS X network, if working and turned
on... Should be discovered by Bonjour right away..
c.) Printer Driver not needed:
A really nice feature with Bonjour:
You really don't need to have the print driver software for the
discovered printer. Bonjour will identify the printer, its
location on the Mac OS X network and will use a
Generic/Postscript identity due to a print driver for the
PC not being needed.
d.) Summary of discovered network printer:
Final screen for the Bonjour Printer Wizard. Just click
the Finish button and that is all it should take.
Done!
Now open any document run a test print..
on and get to printing with the newly discovered
Mac OS X network printer on your PC.
Now, that you know, no more guessing, on how to find
that elusive Mac OS X network printer for your PC.
Happy Printing!
Regards,
Mactechtrainer
on Feb 04, 2010 | Office Equipment & Supplies
Cant connect the wifi edimax wireless br-6228ns
Here is the manual on to set it up.
http://us.edimax.com/edimax/mw/cufiles/files/download/manual/transfer/Wireless/BR-6228nSnC/BR-6228nSnC_UserManual_v1.zip
From the manufacturers website.
Try setting it up according to the manual. If you need help you can contact the manufacturrers technical help here. Support Services
Aug 01, 2013 | Edimax Network BR-6228NS Wireless N 150M...
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
How to enable Bonjour on windows XP
Go to start, run type services.msc
click on Bonjour service and either set to auto or start it depending on what you want.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 22, 2011 | Computers & Internet
Why i can't connect to internet using edimax?
probably it is not configured properly to provide you the IP that is the DHCP service not started in your router so you are not being able to connect internet
May 07, 2010 | Edimax 4 Port Wireless AP Broadband Router...
Does not bridge LAN and Wireless
ya need to check the ip add setting of acces point , as well as ssid , channel n region too. once ya log into the the routers configuration page , check that yor comp is getting the ip of same range/class from yor router, it might be liil different in the last number , no worries till then.... n assign the same ssid , region and security setting - like the secuirty key for wless to yor wless comps also. n calso check your comps are on dynamic ip settings. however if ya want to use the staic ip , then give yor comps a staic ip in the same range as yor router' range. n check the wzc service of yor windows xp or above system. it should be enable n running n should be usingthe same security key for wirless connection. or chat with me on samrat101, yahoomssgr or msn messnger samrat
Jul 10, 2006 | Edimax BR-6114Wg Router (BR6114WG)
Computers & Internet Logo
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Rommel Balcita
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
