Question about Sharp AR-M207 All-In-One Laser Printer
DEVELOPER CHANGE HOW TO ENTER SERVICE MODE AND INITIALIZE NEW DWVWLOPER
    Problem Solver:
  • 7 Answers
HI.YOU HAVE TO GO TO THE CODE AND REPLACE NEW DEVELOPER
#*C* AN THAN CODE NEMBER 16
Posted on Oct 16, 2014
DEVELOPER
please call me 008801819879575
Mar 25, 2014 | Sharp AR-M207 All-In-One Laser Printer
Bizhub 750, i put new developer, is there any setting that i have to do after this job?thx
After you change the developer enter in service mode press Utility key- Meter count- Details-Stop-0-0-Stop-0 -1press Counter select Special(optional)parts counter select Developer and reset the Developer counter value by pressing C.After reset the developer counter enter in Imaging Process adjustment mode select Drum pecularity mode and select Cartridge installation mode press the Star button.The process duration is 2-4 minutes.Whwn thw ok appears press Exit and return the copy mode,make a test page.
Mar 24, 2014 | Konica Minolta Dv710 O2xk Black Developer...
I have an error code C-2557 on this Biz 350 with the finisher, without the the finisher m/c works fine
C-2557 ATDC sensor malfunction.Enter in the service mode press following keys:
Utility-Metercount-Details-STOP-0-0-Stop-0-1-press 00000000 press Enter in Tech. mode select Printer than select ATDC gain and read the ATDC current value.If the value is situate 150-160 increase the value to 164-174 (to change the value press C and entering the new value)return in the copy mode turn OFF the copier open the rigy door than close and turn ON the copier and make a few copies.If the error persist discrease the ATDC value and make some copies.If the code persist change the developer .Before change the developer reset the special parts counter I/U counter,developer.After change the developer perform F8 and verify the new value to ATDC gain and notice.
Feb 19, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub 211 machine trouble service call(C0F32)
either u have to change the developer or if ur a rep then enter service mode and change the gain value.but better to change the developer and charge it
Aug 10, 2011 | Office Equipment & Supplies
COF32
developer gain problem .if ur a rep then u can adjust the gain in the service mode.it is tricky but possible .otherwise u have to install new developer and initialize it.this will solve ur problem
Jun 01, 2011 | Konica Minolta Di1610 Copier
How to change devolper
Remove the waste bottle then the drum unit from the front of the machine.**Cover the drum unit so it is not exposed to the light.
Remove the Developing unit and empty the developer from the dev unit into waste bag. Once all the developer is removed...take the new bottle of developer and pour it all into the dev unit. Replace the plastic cover back onto the top of the dev unit. Re-install the dev unit back into the machine, then replace the drum unit back into the machine then replace the waste toner bottle. Close the front door. Enter the copier adjustment mode on the keypad by pressing "user preset,Orig size(Ledger), and Multi-copy key #3 in sequence.
Then press Multi-copy key #8 , then press the Print key.
Now select th code "09" and Press Print.
The machine will run for approx 2 minutes to initialize the new developer. Press Clear/stop and User preset to escape from the service mode. You are done.
Jun 07, 2010 | Panasonic FP-7750 Black and White Copier
BizHub 250 Malfunction Code C2557 - HELP!
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Nov 11, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
RICOH AFICIO MP 2000
you must clean developer and drum section. after that you must put new developer and initialize it. After that place in correct toner.
Oct 15, 2008 | Ricoh Aficio 1027 All-In-One Laser Printer
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Rico afficio 450
Dev. initialize should only be done when replacing dev.otherwise it will not add the correct amount of toner to the dev.Replace developer and run sim.2-801 in service mode.
Jul 19, 2008 | Ricoh Aficio 450 Copier
Sharp AR-M207 All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
CheckitRight
CheckitRight
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
