Question about Sharp AR207 Developer Unit
DEVELOPER CHANGE IN SHARP
HOW TO INITIALIZE
DEVELOPER
please call me 008801819879575
Mar 25, 2014 | Sharp AR-M207 All-In-One Laser Printer
DEVELOPER CHANGE
HI.YOU HAVE TO GO TO THE CODE AND REPLACE NEW DEVELOPER
#*C* AN THAN CODE NEMBER 16
How do i change/refill the developer on a SHARP AR M257 copier?
open frount cover remove toner cartridge. remove blue screw be carefull dont damage drum.developer unit out ,clean old developer and apply new developer .then re install all of them and input code 25-2 and let the copier to run and stop automaticly.
May 17, 2010 | Sharp AR-M257 Black and White Copier
Developer in my sharp ar-5520s mfp
if you want change developer,pullout toner cartridge open blue screw,remove developer unit ,open 3 screws,remove black cover remove old developer and add new
Apr 30, 2010 | Sharp SF 2020 Copier
I HAVE A PROBLEM I CHANGE A NEW DEVELOPER BUT THE RESULT NO TONER
Please specify a copier model:Minolta,Ricoh,etc?
After change the developer you must performed F8 (ATDC automatic toner density control to fixed T/C ratio and initialize the new developer.After this operation perform F5 (AIDC sensor test automatic image density control).Never make a copy before F8.
Aug 01, 2009 | Minolta Office Equipment & Supplies
Sharp AR 407
You will need to get some developer.  Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum.  Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter.  If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
Nov 11, 2008 | Office Equipment & Supplies
How do I change the developer in a Sharp sf2022 copy machine?
- If you have Manual please read carefully and follow the instruction.
- If you know how to change the Toner Cartridge? the same procedure also the developer.
- Developer located at the Toner Cartridge side
Sep 19, 2008 | Sharp Office Equipment & Supplies
Sharp ar5320 developer reset code
The developer doesn't have a reset code.  It uses a calibration program instead with the reset integrated into it.
Even though the copy quality is fine for now, it can change in the next few days.  You should order some developer.
Sep 16, 2008 | Office Equipment & Supplies
Changing Developer
Developer is supposed to be replaced by a technician because all of old developer has to be removed from the machine usually with a vaccum. You have to be very careful how to remove it off of the mag roller so you don't scratch it and you have to leave a finger on it so you don't mess up the polarity of it from the vaccum.
Then there are some service codes that need to be ran to initialize it. This way the toner/developer sensor can be calibrated.
If any step is missed it will effect the copy quality and the developer can be contaminated as well and will have to be replaced.
Aug 06, 2008 | Sharp AR-153E Copier
How do i set aficio 1035 to factory default
SC352 Indicates ID Sensor/Pattern edge detect Error 3. If its a color machine, then it's a Magenta TD ensor failure.
Usually If you need to change the developer roller you should change the developer as well. Once that is done, then you go into service mode and calibrate the developer and initialize the TD sensor.
Did you change the developer?
Aug 02, 2008 | Ricoh Aficio 1035 Copier
Sharp AR207 Developer Unit Logo
22 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
