Question about Gemini Sound Products Gemini Cdmp-6000 Audio Mixer
Where is the fuse located for the gemini 6000
Where is the fuse compartment located? I need to check the fuse been running the mixer for about 2 years now and forgot to check and replace fuse
My gemini cdmp 6000 cue button is stuck it will not come out of cue. i need to hold cue button down in order for it to play
You need to take it to the shop and get the switch replaced. It shouldn't cost more than an hour's labor/bench charge and the cost of the switch. Depending on your market probably $75-100.
Jul 14, 2015 | Gemini Sound Products Gemini Cdmp-6000...
I dont know how to set up a mixer Gemini 3610 to my laptop and my powered speaker i want to know what cables i need
There are several possible solutions for this. The cheapest and easiest is to do the following:
Solution 1:
1. Get an RCA stereo plug to 3.5 mm plug. This will go from your mixer to your computer. This will not be the highest quality, but will work.
2. Get an XLR cable of the length you need. I would guess a standard one with a male connection on one end and a female on the other. Connect this to your powered speaker. Also, this is a guess as you didn't include the type of powered speaker, so I can't tell you for sure which cable to use.
Solution 2:
1. An alternate idea for better sound quality would be to run a D/A converter similar to this one: http://www.sweetwater.com/store/detail/USBMix/It would give you a much higher sound quality for everything. You would run from your Gemini to this. From this device, you would run a USB cable to your computer, and a 1/4" cable to your powered speaker.
Jul 19, 2012 | Gemini Sound Products Gemini Cdm-3610 Mp3/...
Help my gemini cdmp-6000 service manual
You can download the user manual for Gemini cdmp-6000 from here.
Hope this helps, please rate and leave a comment if the solution was helpful, thanks!
Nov 03, 2011 | Gemini Sound Products Gemini Cdmp-6000...
My cdmp-6000 always hangs and resets.... what causes it? and what maybe the possible solution?
I can give you some questions to verify possible problems:
1. Is the mixer, and ALL connected equipment powered from the SAME receptacle? If not, ground bounce can be causing damaging transients. This OFTEN requires running power back from where amps are to the mixer using an extension cord.
2. Are ALL audio interconnectsusing balanced lines where possible?
3. Is humidity 40% or greater? If not, possible static discharges from rugs, clothes, etc. may be causing transients that reset the unit.
4. Are stage lighting equipment run from a separate source to avoid transients from dimmers and switching?
5. Is the power all have three wire cords and the building have grounded receptacles?
If your system satisfies all these the next step I would suggest is a high quality power conditioner.
May 07, 2011 | Gemini Sound Products Gemini Cdmp-6000...
Hi, There is a problem on my CDMP 6000 left player pitch control. When pitch control is switched on and adjusted to +/-, it does not get set at that value but keeps fluctuating. Also, the pitch control...
You MAY have contamination in the slider.You could try putting a little CRC226 into the slot and work the control. Use ONLY this product CRC226 available at Home Depot in the electrical dept/
Apr 30, 2011 | Gemini Sound Products Gemini Cdmp-6000...
GEMINI CDMP 6000 5 mounth old 10 times used ( home used ) . Left unit play correct audio CD but right unit have problem with play some tracks from the same audio CD. In Macedonija ( EUROPA ) we dont have...
A call to Gemini is in order here. Given your location, try asking if they will send you a replacement drive. It is common for the drives to contain special uncoding that will prevent a generic replacement drive from working properly. Since this unit is so new, it is likely that the company will replace the drive for you.
Dan
Nov 27, 2010 | Gemini Sound Products Gemini Cdmp-6000...
Gemini Sound Products Gemini Cdmp-6000 Audio Mixer Logo
19 people viewed this question
Top Gemini Sound Products Music Experts
Vito Vacirca Jr.
Colin Stickland
Colin Stickland
Are you a Gemini Sound Products Music Expert? Answer questions, earn points and help others
