Question about Garden
Homelite petrol yard broom blower would only go about 3/4 revs with throttle about 1/3 throttle now won't start
Blower wont start now
    Sergeant:
  • 415 Answers
Try rebuilding the carbureator. That should solve the problem. make sure the fuel is good and the mixture is right.
Posted on Apr 03, 2014
SOURCE: leaf blower
One suggestion, unscrew the spark plug and reconnect the high voltage wire. In a very dark area move the plug so that the plug thread touches some metal on the engine. Pull the starter cord. If you don't see a spark, remove the two screws on the handle and see if two wires are attached to the Stop Engine Switch. Remove one wire and bend it away from metal and try to see spark when pulling the start cord. If spark occurs, the Switch is shorted and needs replacing.
Posted on Nov 04, 2008
jj505
  • 195 Answers
SOURCE: Replace starter pull cord
http://www.google.com/search?hl=en&rlz=1T4GGLR_enUS311US311&q=homelite+yard+broom+ut08110%2Creplace+pull+start+rope&btnG=Search
This may guide you
Posted on Mar 16, 2009
SOURCE: Homelite yard broom
I have lost my book on the homelite yard broom. can you tell me the ratio of gas and oil?
Posted on Oct 31, 2008
  • 246 Answers
SOURCE: I have a Homelite Yard Broom gas blower that won't prime/stalls.
Hello sodevine69:
>>From your Description it Sounds like the Fuel Filter in the Tank Requires Changing, the Carburetor Metering Jet is Stuck, the Carburetor Filter/Screen is Restricted and Requires Cleaning/Replacing or the Carburetor Requires Cleaning.
>>The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
  • 15 Answers
SOURCE: yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Posted on Apr 19, 2010
Testimonial: "Thanks will do"
Blower won't start
I would start off by cleaning the carb. Sounds like it's all gunked up. Is it old? Sounds like it needs a full tuneup. Change the plug, put some fresh gas/oil in there, and clean that carb out with cab fluid.
Mar 25, 2014 | Homelite 'Yard Broom' Leaf Blower
I have a Homelite YARD BROOM II 170 mph Blower.what is the oil to gas ratio?
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
Need to know the oil and gas mixture for a homelite yard broom II
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
Jan 31, 2011 | Homelite 'Yard Broom' Leaf Blower
I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
How to adjust a carburetor on a Mighty Lite Handheld Gas Blower model# UT 08520 ?
if you take apart the carburator youll see a screen under the plate on one side once together turn the mixture screws in all the way till you feel it seat or tighten then back out each screw 1 to 1 and 1/2 turns then start the engine the key is to get it to idle once it idles turn the mixture screw the low side it will say l or h below the screw turn it in which clockwise till it runs smooth then back out slightly till it just starts to miss then rev up the throttle and adjust the high side which is towards the filter turn the mixture screw in till it revs to the highest point which I call the sweet spot your pretty close to what you need
Nov 08, 2009 | Homelite 'Yard Broom' Leaf Blower
What is gas-oil ratio for homelite leaf blower
Unless you know better, I would use 40:1. That will give you more oil than needed if it is 50:1 but wont hurt the engine. Do some more checking to get the actual ratio...Lee
Nov 03, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite leaf blover run with choke soon when chokeis off ,cant rev up and die
if he put fuel in it dump it out & put yours in it , if problem persist there are 2 screws on the carberator turn the 1 on the right or th bottom 1/4 turn to the left!
Jun 02, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite yard broom
Aug 31, 2008 | Garden
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
