Question about As Seen On TV H2O Mop X5
Supplier of a Sankyo kin39601 pump needed for X5 steam mop
Pump is erratic/failing and needs a replacement.
X5 H2O Steam Mop dripping water from small hole at bottom and not producing much steam
john, I would try cleaning the mechanism with vinegar or CLR to dissolve any buildups you can't see. Rinse, fill up with fresh water and powerup. good luck
Mar 13, 2014 | As Seen On TV H2o Mop X5 5-In-1 Steam...
Kin39601
go on line to the manufactures web site and seek out the parts department. Have your make, model, ready.
Feb 25, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
X5 steam mop, turns on but produces no st eam
Its likely that the tube that supplies the steam to the mop is clogged. you will need to disassemble the mop part and find that tube then push a wire up there to clear it out. Then turn the unit on and keep trying to clear with wire, you may want to wear a glove in case a sudden puff of steam comes out. This problem is common it happens because when you evaporate the water, any dissolved solids drop out onto surfaces inside the unit and make the clogs. The 'Motor' is real hot because the unit is making steam but it can't get out!
Nov 10, 2013 | As Seen On TV H2o Mop X5 5-In-1 Steam...
How can i fix my H20 mop x5 steam cleaner
see this causes, and use the common sense God bless you
nspect your steam cleaner's belts for loss or damage. Damaged belts can cause the brushes to stop rolling or the spray mechanism to stop functioning. To fix a damaged pump or brush belt, first unplug the steam cleaner. Refer to the user's manual to determine the specific location of each belt. Order a new belt directly from the manufacturer's website, or from a local home improvement store, if necessary.
Sep 19, 2012 | Vacuums
IT WILL NOT PUMP STEAM. THE UNIT GETS HOT BUT WHEN YOU PUMP IT THERE IS NO STEAM COMING OUT
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Nov 19, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My shark steam mop is not producing steam when I pump the handle - twice the mop head has blown off when I tried to pump more than the usual allotted time. Any idea what is going on?
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Jul 05, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When pressing steam does not come out. need to replace (part) PUM
heatman101//
Feb 13, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When pressing steam does not come out. need to get pump. Need to replace the oump. Do you sell parts???
No parts, but check the manuals link...
heatman101
My mop would produce steam. It gets hot but when
heatman101
xxxx
Jan 24, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
As Seen On TV H2O Mop X5 Logo
207 people viewed this question
Top As Seen On TV Home Experts
Donni Steen
Tom Chichester
Are you an As Seen On TV Home Expert? Answer questions, earn points and help others
