Question about Homelite 'Yard Broom' Leaf Blower
Blower won't start
Blower was only going 3/4 revs with throttle about 1/3 open now won't go
  • 63 Answers
I would start off by cleaning the carb. Sounds like it's all gunked up. Is it old? Sounds like it needs a full tuneup. Change the plug, put some fresh gas/oil in there, and clean that carb out with cab fluid.
Posted on Apr 03, 2014
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Homelite petrol yard broom blower would only go about 3/4 revs with throttle about 1/3 throttle now won't start
Try rebuilding the carbureator. That should solve the problem. make sure the fuel is good and the mixture is right.
Mar 25, 2014 | Garden
1993 festiva replaced the throttle body gasket now will not accelerate at temp
I have a 1997 ford E 150 customize mark 3 van have driven back and forth to work 5 years ran great Christmas Day drove down to the garage and back up to house and now it will not start turns over has spark will not fire
Jan 07, 2014 | 1993 Ford Festiva
Engine wont rev up
the fuel system is blocked up
perhaps the plug is bad
and the air filter will need replaced
or the fuel tank vent is also blocked up
Nov 28, 2013 | Stihl Br 500 550 600 Backpack Blower...
2004 trial blaz. 4.2 eng. ran fine, but service eng. light on, i put 2 map, & 3 coolant sensor in, after each, coolant sensor the blaz, won't idle, when ac. is on, down rd. with ac. on, ok, but tac...
Hello: Remove the ducting going from the air cleaner to the throttle plate, clean the carbon off the throttle plate and the throttle body bore. Do not spray excess carb cleaner into the throttle body. Hold the throttle plate open with your hand and spray carb cleaner on a soft rag and clean off carbon. When finished key on engine off for 10 seconds key off for 10 seconds do this a total of three tines.
Jun 27, 2011 | 2004 Chevrolet TrailBlazer
Echo PB413H running rough
Hello:
From your Description it Sounds like the Exhaust is Restricted or the "H" Mixture Screw Resuires Adjusting.
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is the Instruction File for Setting the Air Mixture Screws. Any Input is Appreciated. The Procedure is the Same for 1 or 2 Mixture Screws, Just Use the Instruction File and Skip Over the Section with the Missing Mixture Screw ( Usually the H Mixture Screw).
>>Now Setting the Air Mixture Screws:
>>****Turn the Idle Air (L) and Main Air (H) Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Set the Throttle Full Open, Start the Engine.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/4 or 1/2 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog DOwn Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
>>Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required.
>>Now Set the Idle Air (L) Mixture Screw so there is No Hesitation when Rapidly Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 15, 2009 | Echo Inc. 44 CC, Carb Certified Backpack...
Do not have basic setting for 2 speed jet so engine revs up and down instead of constant speed.
>>Turn the Main Air (H) Mixture Screw Clockwise Until Proper Revs are Obtained. **Carefully Use your Finger and Move the Governor Arm to Rev the Engine (on Chainsaws and Trimmers Use the Trigger to Rev the Engine) Until you Reach Max RPMs (on Chainsaws and Trimmers, the RPMs are Not Set to MAX. Set to Max and then Reverse the Setting Screw 1/2 or 1 Turn. If the H Mixture Screw is Set too High; the Engine will be Starved for the Oil in the Gas and Damage the Piston and Jug/Cylinder) and the Engine is Running Proper at Full Throttle Up a Grade and for Chainsaws and Trimmers they Do Not Bog Down Under a Load. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs.**
Good Luck
Respectfully
jbridger (John)
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
I have an echo gas powered leaf blower, model pb251. it will start and idol, but wont run any faster than that, and throttle cable seems to be ok.
I just fixed my Echo PB 2100 with the same issue. It would start, run, all throttle openings OK but would not rev-up. It was a dirty/clogged screen on the muffler. Scraped the thick tar off then used Lacquer Thinner to soak it clean. Blower works better than ever now....
Apr 02, 2009 | ECHO, Inc. PB-251C Handheld Blower
2000 v6 5 spd nissan xterra idles high when in gear and rolling .
From the service manual:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
NGEC0549
PREPARATION
NGEC0549S01
1) Make sure that the following parts are in good order.
I Battery
I Ignition system
I Engine oil and coolant levels
I Fuses
I ECM harness connector
I Vacuum hoses
I Air intake system
(Oil filler cap, oil level gauge, etc.)
I Fuel pressure
I Engine compression
I EGR valve operation (If so equipped)
I Throttle valve
I Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
SEF976U
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
SEF977U
4. Perform diagnostic test mode II (Self-diagnostic results). Refer to EC-644.
SEF217U
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
BASIC SERVICE PROCEDURE VG33E
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment (Cont’d)
EC-616
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
SEF978U
3. Turn off engine and disconnect throttle position sensor harness connector.
SEF975R
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
SEF371S
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
GI
MA
EM
LC
FE
CL
MT
AT
TF
PD
AX
SU
BR
ST
RS
BT
HA
SC
EL
IDX
EC-617
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
SEF972R
' GO TO 2.
4 CHECK BASE IDLE SPEED
With CONSULT-II
1. Read idle speed in “DATA MONITOR” mode with CONSULT-II.
PEF356V
700±50 rpm (in “P” or “N” position)
Without CONSULT-II
1. Check idle speed.
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
Mar 25, 2009 | 2000 Nissan Xterra
Homelite 'Yard Broom' Leaf Blower Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
