Question about Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump
Canned motor pumps, single and multistage tripping
Pump tripping within 35 seconds after startup
  • Daryl Gleaton Mar 29, 2014
    You need to replace the G.F.I. breaker it can no longer handle the load. They do fail after several years, especially if in a damp basement or crawl space. Hire an electrician if you are not familiar with electrical wiring !!!!
  • 656 Answers
Replace the GBI breaker it is bad.
Posted on Mar 29, 2014
Vs pump trips breaker. single stage 1 1/2 pump works fine, does not trip
is motor getting hot if so need new motor also check to see if wires on the back of the motor are loose or the wires to the breaker loose if they are ok you need a new pump motor or pump sometimes a whole pump is cheaper than fixing the old one
Jun 01, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Power trips in spin cycle
Pump is leaking water and causing problems. Replace the fault part and clean thoroughly.
Feb 27, 2014 | Samsung Washing Machines
Breaker trips on startup
If your circuit breaker is tripping when you turn the pump on it is caused by a bad motor. The motor probably has a short in it causing the breaker to trip,
Replace your pump and that should solve your problem with the breaker.
There is an outside chance you may have a bad circuit breaker too.
US Parts Center
Sep 02, 2013 | Jacuzzi Home
Goulds pump model BGR75 won't reset. Any tips.
If the motor runs but keeps tripping the overload, the motor is bad or the motor is under a big load. Does it pump water? If not, check the impeller and see if there is anything wrong with it. If it does pump water and the motor trips overload, the only thing left to check is the overload. Check the motor's amp draw and if within specs, replace overload. If amps are too high, replace motor.
Aug 22, 2012 | Plumbing
I have a Polaris PB4-60 booster pump, less than 3yrs old. I turned the pump and left. When I got back 1hr later, the pump was not running. Breakers had been tripped. Each time we reset the breakers and...
If the device that tripped is a ground fault circuit interupter (GFCI) breaker or receptacle then it is likely caused by 5mA or more of leakage current to ground within the motor. If what tripped is a circuit breaker then there are likely shorted turns within the motor. Usually either of this issues requires a new motor.
If you are not wanting to turn wrenches yourselfthen my best suggestion is to bring it to Leslies Pool Supplies and they oftencan put it right for the price of the parts while you watch (they might not have some parts in stock).
I hope this helps.
Sep 27, 2011 | Polaris Pb4 - 60 Booster Pump
The multistage centrifugal pump tripped after openning the discharge valave
Did you prime both stages? That may have caused the problem.
Dec 22, 2010 | Plumbing
Sta-Rite 1HP inground pool pump Every time the pump turns on it trips the breaker, after taking the motor appart and lubing it up I could get it going but once off for a period of time on startup it will...
Any time an electrical appliance trips a breaker there is only several causes:
1 - appliance is pulling more amperage than the breaker was built for.
2 - breaker is faulty
3 - a "hot" wire is touching "ground"
4 - screws (where wire is attached) in the pump or breaker are loose
1 - If the appliance is pulling more amperage than the breaker (or wiring) will allow, then check the appliance to see what amperage it's rated at. If this is more than the breaker will allow, you'll have to plug the appliance into a circuit that will take that amperage. If the appliance rating is within the limits of the wiring & breaker, then check #2, #3 or #4 above. If everything is okay with the remaining possibilities, then you have problems within the pump. Do it yourself'ers usually have a bad time when they open an electric motor. I suggest you take the motor to a electric motor repair shop or seek help from the Sta-Rite pump Customer Service.
Jul 01, 2010 | Sta Rite STA-RITE 1 HP DURA-GLAS PUMP
The compressor suddenly trip off and it runs and after few minutes it trip off again
Compressor tipping is typically due to overheating. A single bimetal disc thermostat (e.g. Klixon brand device) in located within the motor windings within hermetically sealed compressors which will cut off motor current after the local windings have sufficiently overheated.
Unfortunately, by the time this limiter has activated, the compressor motor and pump has typically already suffered mild to major damage.
Compressor overheating is typically a result of low freon. The freon, besides cooling the compressor, also carries the lubricant, so low freon results in a hot compressor with poor lubrication, with some degree of permanent damage by the time the internal limiter has activated.
There are a few other possibilities, depending on system design, but some version of the above scenario is typical.
When the compressor runs hot, this also initiates chemical changes in the freon and oil resulting in acids with further attack both the compressor pump, motor windings and motor bearings, a viscous circle.
Compressor overheating can also be a result of contaminants circulating within the freon or evolving mechanical failure problems within the compressor pump or motor.
Better systems (very few high end residential central AC systems) include OEM or field installed high freon pressure and low freon pressure cut out switches connected to circuits which stop the compressor and keep it off when pressure are well beyond desired.
These are far more effective in protecting the compressor and preventing permanent damage.
Additional protection options are a compressor discharge temperature limit switch (shuts off the compressor if the outlet freon goes well above desirable outlet temps), and a flow switch which sense adequate condenser fan air flow and only allows the compressor to run when adequate air flow is present (a second or so after the condenser fan has started). (Since condenser air flow is what removes all the system and interior heat, the compressor should not run unless airflow is appropriate.)
While all the above 4 safety device strategies are relatively inexpensive, they are not present in the vast majority of residential AC systems sold in the US.
Jan 06, 2010 | Carrier Heating & Cooling
Pump just hums but wont start
Sounds like its frozen and causing a very heavy load on your circuit. If the motor gets hot within seconds, its shot and needs replacing. Have you attempted to turn the motor over by hand ?
Jun 22, 2009 | AO Smith SQ1202 Pool Pump Motor
Flotec FP0S2400A-03 1/3 HP 2,500 GPH Automatic Submersible Sump Pump Logo
Top Flotec Electrical Supplies Experts
 Kenneth
Kenneth
Paul Nielson
Paul Nielson
Are you a Flotec Electrical Supply Expert? Answer questions, earn points and help others
