Question about Canon Office Equipment & Supplies
How to refill canon PG645 - Canon Office Equipment & Supplies
Reset ink level on canon mg2120 after ink refill
The following procedures may be used to reset the Canon printer ink level monitoring following the installation of a refilled Canon 30, 31, 40, 41, 50, 51, 210, 211, 240, or 241 integrated ink cartridges. In most cases, the error/alert will need to be cleared to enable printing. Ink waste container reset procedures are also provided below.
NOTE: for multi-cartridge installation, the procedure(s) may need to be repeated twice.
For PGI-5, PGI-9PBK, CLI-8, PGI-220 CLI-221 PGI-225 CLI-226 PGI-250 CLI-251 Cartridges: These are new Canon cartridges which have an embedded chip on each cartridge. If you just refill the ink, the printer will still reads the cartridge as empty. You have two choices:
Purchase a "refillable cartridge" from www.asapinkjets.com
BCH or other sellers. These refillable cartridges have an auto-reset chip (non OEM) and will reset automatically.
Use a chip resetter (e.g., search Canon + model number + resetter on eBay). Follow the instruction below to refill your original cartridge, and use the resetter to reset the chip.
Inkjet Cartridges and Toner Refills
Aug 29, 2012 | Canon PIXMA MG2120 Inkjet Photo All-In-One
Does ink refile is possible in canon ip 2770 printer?
Yes, Canon ink cartridges can be refilled. Most Canon cartridges can be refilled up to 12 times. Canon cartridges consist of a sponge and an open ink reservoir, so they can be refilled using a syringe.
Nov 14, 2010 | Office Equipment & Supplies
I HAVE 10 PRINTERS OF CANON LBP 2900B & SO HOW CAN I REFILL MY ALL CARTIRDGES & I REFILL MY SELF CAN YOU HELP ME CAN YOU SHOW ME ANY VIDEO CLIP SO I EASYLY I REFILL MY CARTIRDGE THANKYOU
Click on the link below to know how to refill the Toner by yourself.
You have to be careful when doing it yourself.
Click on the video to watch how to refill the toner
How to Refill Video
Hope this solves the problem
Nov 06, 2010 | Canon LASER SHOT LBP-2900 Printer
How to refill toner for a canon lbp?
hi
go to following link you will find your solution
http://en.kioskea.net/s/How+to+refill+toner+on+Canon+LASER+SHOT+LBP-2900+Printer
Oct 26, 2010 | Canon LASER SHOT LBP-2900 Printer
Is there a cheaper way to replace the Canon MP240 ink cartridges by using a generic source?
I would not recommend using generics for the PG-210 CL-211. Canon builds these style cartridges with what we simply call a "digital fuse". Basically there is coding on the cartridge that turns the cartridge off once the printer believes it to be empty. For this reason we do not refill these cartridges in our shop, nor do we suggest refills at all. If you would like to use refills, Canon printers that take the 221 series cartridges refill well and are reliable. But make sure you only use refills of Canon original cores. Internet "compatibles" commonly don't fit right, or have communication errors.
Jun 09, 2010 | Canon PIXMA MP240 All-In-One InkJet...
How to refill canon 38 cartridge
You can't refill the cartridge that's in your printer because your printer remembers the serial codes in the electronics of the cartridge to reject refills. I own a Cartridge World ink refilling store and I have started suggesting that customers buy Canon originals because we have had so many returns.
Dec 31, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Where do you get refill ink for canon fax phoneL80
The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
Dec 16, 2009 | Canon FAXPHONE L80 Laser
I NEED TO KNOW HOW TO REFILL INK FOR A CANON MX310 #41 COLOR.i DON,T KNOW IF YOU PRY THE TOP OFF OR IF THERE ARE SOME REFILL HOLES SOMEWHERE.SHIRL85@EMBARQMAIL.COM
Your printer uses the following cartridges:
canon-pg-30
Black Pigmented
canon-cl-31
Color
canon-pg-40
Black Pigmented
canon-pg-50
Black Pigmented canon-cl-41
Color
canon-cl-51
Color
ou find the refill instructions for your cartridges in the book at the link below:
Download Inkjet Refill Instructions
You can also buy refill kit here: inkjet refill products.
You also need to reset the cartridge after refill, see: Reset Ink levels for canon mx310 - FixYa
Mar 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Refilling cartridge
check this video it is very easy with no special equipment
http://www.youtube.com/watch?v=iMiTopIVMxM
Sep 22, 2008 | Canon LASER SHOT LBP 3300 Printer
253 people viewed this question
old marine
old marine
