Question about Coffee Makers & Espresso Machines
SAECO Odea Go motor turns but machine won't grind coffee
  • 4 Answers
First suspect is the micro-switch that terminates the grinding at the moment there is enough ground coffee for brewing. First check if the ground coffee is available (probably overstuffed the compartment). No coffee; other problem. If coffee is there ->replace the microswitch.
Posted on Jul 04, 2014
  • 74 Answers
SOURCE: saeco odea go
When the grinder stops to work i would turn the grinder to more coarse. this might help if the case is that it has gotten clogged.
Posted on Jul 11, 2008
  • 3 Answers
SOURCE: saeco odea steamer is leaking
This is a known issue with the Odea GO. You need to take it in for servicing to get the rubber seals changed. This happened with our maching after about 6 months.
Posted on Mar 09, 2009
SOURCE: Saeco Odea Giro - disassembly
Hope this can help:
I managed to take mine apart because I was having a lot of leaking steam from the steam wand (as posted earlier). I followed your instructions, and all worked very well. Just to prepare readers, this is what I found. The green seal on the steam end was torn, as previously described. I noticed it start to "drag" a bit during use (daily for the past year), and it must have stuck and torn over time. See photos. I replaced with a part from ACE, see photo. Be sure to lube before re-assembly. Hope the photos help!
BA
Posted on Aug 26, 2009
  • 8 Answers
SOURCE: I have descaled my Saeco Odea and the coffee beans
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
Posted on Feb 13, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
My Saeco Odea Go coffee machine grinder screw rotates with on beans but does not rotate when beans are added. Motor sounds like its working.
There are different possibilities for your problem. First the motor might be damaged and is more weak than before that is why is stop when it need to grind beans. In this case only with replacement motor can solve the problem.
Second probably due to long use of oily coffee or low quality coffee beans or other reason there are coffee grounded in the grinder that become like rubber and does not leave the new coffee to pass through grinding burrs. For this either you have to dismantle the whole grinder and its burrs and clean them with brush or you can use a new magic product that you can fin in eBay it can clean automatically the grinder in 30 second see it at the link
http://www.ebay.com/itm/PULY-GRIND-COFFEE-GRINDER-CLEANER-CRYSTALS-20-GRAMS-PACK-OF-3-PACKETS-/131031511160?ssPageName=STRK:MESE:IT
You can try the above fist and you may solve the problem in minutes if not then you can proceed with the replacement of the ginder burrs or motor.
Jan 10, 2015 | Saeco Odea Go
Hi i have a Saeco Odea Giro Plus, that was broken ceramic baked klay. after replace new it have a problem with my Saeco Odea Giro. The problem is that the bean grinder doesnt grind (I only hear sound of...
you need to change this part ,which is under the ceramic knife. You will have to open the coffee grinder and take out the knives and change the holder to the lower knife. That's your problem. This is the product code 149198350
Apr 22, 2017 | Saeco Odea-Giro Espresso Machine
Saeco odea does not brew. coffee beans will grind, then coffee maker will start flashing all lights, and ground coffee will spit out without brewing. when i change beans to more oily ones, it works without...
Hi...Keep on grinding until the Auto Dosing System readjust the amount of grind to be in the optimum. Normally it takes 3 to 4 grinds. Whenever we change the type of beans, this condition happens, it is not a problem.
Aug 29, 2011 | Saeco Odea Giro Plus Coffee Maker
I have a Saeco Odea Go and my puck in the dreg drawer are really wet and I have water leaking (brown so with coffee) under the dreg drawer. how I can fix it ?
I recently had this problem. I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount.
Jan 12, 2011 | Saeco Odea Go
Saeco odea giro is not grinding enough coffee.. the pad is like half or less than that.. it seems like a pcv problem .. HOw can I reset or reprogram to grind more coffee?
Hi,..These saeco models have a auto adjusting grinder. If the brewunit is heavy or in other words overloading, the machine will reduce the grinding time lesser to produce less ground coffee.If it senses the brewunit is smooth and light in loading (compressing the grounds), it will increase the grinding until it reaches the optimum dose. So it is important to clean and lubricate the brew unit at all times. Hope it will solve the problem. Good luck.
Jun 18, 2010 | Saeco Odea-Giro Espresso Machine
Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
Sep 10, 2009 | Saeco Odea-Giro Espresso Machine
Need to adjust coffee dose for odea go
SEE THE VIODEO AND OTHER LINKS ON TYHAT SAME PAGE:
ALSO:
Saeco Odea Go adjusting coffee dose Questions
May 21, 2017 | Saeco Odea Go
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Coffee Makers & Espresso Machines Logo
137 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
