Question about Antamedia DHCP Server
Install error. it is showing Failed to set data for 'Blob'.Please provide me solution.
Intex usb
Hi i am using aircel 3g sim with Intex data card from last 6 months, But when i try to connect today, m getting error that shows "Dial Failed, Do you want to retry". Please somebody help me to solve this issue,, I tried uninstalling the datacard software and installing it but that does not work for me...
May 06, 2013 | Computers & Internet
My N8 is recently not connecting to the internet. It shows the following messages when I try to connect it through my AIRTEL connection : Connection failed Connection Unavailable and Network Error -...
Bro first delete all the setting from ur cell phone ask for new setting 4m ur operator.after saving settings pls switch off d phone & start it after few seconds and now try connecting to net
Jan 20, 2012 | Nokia N8 Cell Phone
"Packet Data Authentication Failed" what is
The error msg "packet data authentication failed" is displayed when connecting to internet via cell phone, even after having the original configuration settings provided by the supplier set to default. The problem can be solved by the following method or else contact the service provider. >Delete the old settings and then by switch off the phone. >Remove the sim card and reinsert it, after some time >gett the new settings and set it to default. Hope this helps. I had the same prblem. Even after calling cc, nothing helped. I tried all things but failed. Then unfortunately, i entered the url of the sp in the access point setting manually and wow it worked. I did this by using uninor.
Jun 17, 2011 | Nokia 2626 Mobile Phone
I have micromax q75 i am using wifi but youtube video not play on my mobile error showed failed to connect
Thats configuration errorGo to video player settings and configure streaming settings then it will show error Failed to buffer huh I dont know after that
Nov 29, 2010 | YouTube Videos
Error using new pc studio with my samsung s3500.
Dear Sir,
Please download you Pc suit again. :)
Thanks. :)
Dec 13, 2009 | Samsung S3500 Cell Phone
Tally 5.4 error
try to configure your configuration setting. change the data source where you data saved.
Exp (from program files, configuration setting) :
;; Tally eis 5.4 workstation specific parameters file
[Tally]
; Specify location of Data files
Data = D:\data tally\Tally 2\DATA
;; Specify list of companies to preload
; ** TO STOP DEFAULT LOADING set the following line to NO
Default Companies = Yes
Load = 0001
;Load = 0002
; Specify list of TDL files for user defined reports and changes
; ** TO STOP LOADING TDL FILES, set the following line to NO
User TDL = Yes
;TDL = <TDL file 1>
; Specify location of TALLY.SAV (saved configuration of Tally)
Config = c:\TALLY
; Specify Color details of local monitor
Color = Yes
a bold letter is the source of data that you must change.
Jun 22, 2009 | Computers & Internet
''Connection Error & Message Sending Failed''
Try doing a Factory Reset. (PLEASE DO IT ON YOUR OWN RISK - FACTORY RESET WILL DELETE EVERY THING OUT OF YOUR PHONE)
Dial *#7370# now it will ask restore original device settings,yes,it will ask for password its-12345, your phone will restart, all the data on our phone memory will be deleted,and it will be like when you first bought it.
But i don't think so that gonna help you out that much. It seem to be issue with the network. Try using some other Mobile service provider. See if problem still remain their on your mobile.
These kind of error message comes when you have WEAK NETWORK.
Dec 28, 2008 | Nokia 6680 Handheld
Re-installing xp
A cyclic redundancy check (CRC error) is an error checking program that is used to verify data and can be caused by hardware or software. The most common causes are bad CD disk, hard drive or memory. To run diagnostics press and hold the <Fn> key while powering the system on. This will run the Dell Diagnostics. Examine the Windows CD and see if there are any scratches or smudges on the media, try another CD disk if you have one.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 13, 2008 | Dell Latitude D600 Notebook
Computers & Internet Logo
64 people viewed this question
Top Antamedia Computers & Internet Experts
David Payne
David Payne
Are you an Antamedia Computer and Internet Expert? Answer questions, earn points and help others
