Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Fridge temp at 48 degrees even though I have it set for 34 degrees. Sounds like fan struggling. Happened 3 months ago but was fine until now. Is this compressor issue or motherboard? Thanks for your help as this is only 3 years old. GE Profile
  • 58 Answers
The fan surge is caused by the motherboard & will require replacement.
Posted on Jun 15, 2009
Danby DWC2727BLS temperature does not go lower than 60 degrees
am having the same problem, and same circumstance. Did you find a solution?
Jun 11, 2012 | Danby Silhouette® DWC276BLS Wine Cooler
Freezer 8 degrees, fridge 48 degrees. Fridge fan was replaced and worked ok for a month.
Sounds like both are about 8 degrees over optimum, if your thermometer is accurate. Can your freezer keep ice cream hard?
Usually, one control affects the temps of both chambers, and the other affects the balance between them. Your balance seems ok, so if you're unable to set it to run longer/colder overall, and your ice cream is not firm/hard, this could indicate a more serious problem. Airflow is important, so you should avoid loading in such a manner that restricts airflow within either side, and verify that fans run when door switches are actuated.
May 18, 2011 | Samsung RS265LABP Side by Side...
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
FAN NOT TURNING IN FRIGE COMPARTMENT AND TEMPERATURE READING ON DISPLAY IS WRONG.
I'm not an expert, but I did notice on other posts that the fan sometimes freezes up causing problems like this. Other people fixed it by defrosted their fridge for 24-48 hours, and this allowed the ice to melt and allowed the fan to start turning again, and all was fine . . . until it happened again in a year's time.
Supposedly, set the temp at 4-6C to stop this.
Jul 19, 2008 | Samsung RB1955VQ Bottom Freezer...
SAMSUNG RS253BAWW NOT WORKING
the ice maker wont cycle untill the temp of the ice is around 10 degrees so if the freezer is at 15 or 20 due to some other malfunction then you will see the maker full of ice but it wont harvest and make another batch. so you could have a sensor bad, control malfunction, refrigeration issue, compressor, defrost system malfunction(you mentioned ice build up)
May 08, 2008 | Samsung RS2534 Side by Side Refrigerator
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Refrigerator part wont get cold
Yes sounds like the freezer fan isnt working. Do you hear it?
Dec 01, 2007 | Refrigerators
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
368 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
