Question about Acer ICONIA Tab W500PC52G03iss
My Thorn TV keeps switching itself off after only a minute or less, it seems to go into sleep mode or similar, I have no clue how to fix this though
My tv is constantly turning itself off or on standby? The green powerlight on front of set stays on however to restart the set I have to use the powerpoint first, swithching it off then back on allowing me to then turn on through remote control however shuts down again before a chanel is actually viewable! I have no idea how to fix this :(
    New Friend:
Hey there!
I'm experiencing the same issue and nothing is working did you get yr issue resolved?
Posted on Feb 09, 2015
    New Friend:
    Problem Solver:
  • 6 Answers
Just a quick try - make sure that the plug is securely in the wall socket - and the back of the TV, if it has a removable cord. The next suggestion would be to make sure that all timers are off. the last thing to look at is ventilation and to make sure the unit is not right on top/close to a heat source. All basic suggestions, but sometime we overlook the simplist things.
Posted on Mar 25, 2014
Can't get my iPad to turn on! Have tried pressing the button for a long time, still not turning. What else should I do to get started?
In order (stop if one works):
1. Recharge at least an hour from power adaptor rather than USB computer lead.
2. Reset by holding down Sleep/Wake button on top right of tablet while at the same time pressing down home button. Keep both depressed 15 seconds. If slider appears or screen dims, keep pressing till Apple appears.
3. Restart (display not working) by pressing and holding Sleep/Wake button till power off slider appears. Drag slider to right. Wait 2 minutes. Press and hold Sleep/wake button till Apple appears.
4. Recovery Mode. With device powered down, hold sleep/wake button down and drag slider to off position. Then plug USB into a computer (do not have usb cable connected to iPad yet) running latest version of iTunes. Hold down Home button while plugging USB cable into iPad. Keep Home button down until Connect to iTunes appears. If does not appear, start Recovery Mode procedure again. When Lightning cable, arrow, and iTunes appears, release Home. Click OK to restore to factory defaults (erases data). Restore data from earlier backup. (Summary of method from Phone Cruncher site.)
Aug 28, 2017 | Tablets & eReaders
How to get the last password for your ipad if you have forgot
Sadly you cannot, though if you have been backing up your device you can use the options attached below.
If you've never synced with iTunes or set up Find My iPhone in iCloud, you'll need to use recovery mode to restore your device. This will erase the device and its passcode.
  1. Connect your iOS device to your computer and open iTunes. If you don't have a computer, borrow one from a friend, or go to an Apple Retail Store or Apple Authorized Service Provider.
  2. While your device is connected, force restart it: Press and hold the Sleep/Wake and Home buttons at the same time. Don't let go when you see the Apple logo - keep holding until you see the recovery mode screen.
  3. When you see the option to Restore or Update, choose Restore.
    iTunes will download software for your device. If it takes more than 15 minutes, your device will exit recovery mode and you'll need to repeat steps 2 and 3.
  4. Wait for the process to finish. Then you can set up and use your device.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
Aug 03, 2016 | Apple iPad Mini
Why does my nextbook keep asking me if I want to put it in safe mode?
The device went into safe mode because the app that you downloaded was not a safe application. The device does this so that the application cannot cause more problems to your device. Even though the app was downloaded from the app store it was not deemed safe by your device. Here are some tips that will help you to get your device out of safe mode: -Ensure that if you have a case on your device that you take it off being that the case may be holding the volume button causing you to boot into safe mode -Try turning the device off then back on to get out of safe mode -Power off your device, then reboot by holding the power button + volume up key, then in the boot menu select reboot device -This is sometimes caused by the users accidentally tapping safe mode when cutting the device on so simply restart your device Most users have success by simply restarting the device in order to be able to get out of safe mode. Do your best to restart or reboot your device before you have to perform a hard reset to get the app off of your device to no longer go into safe mode In order to hard reset -Power off device -Hold down volume up + power -Release at the boot menu -Use the volume keys to highlight factory reset -Press the power button to select factory reset -After this the device will begin to reset itself -After it resets itself use the volume keys to highlight reboot device -press the power button to have your device rebooted in its factory settings
Apr 20, 2016 | Nextbook Tablets & eReaders
How do I fix table that all function keys are not responding correctly.
This can happen after you restart the tablet or after downloading something. The OS get messed up. Turn off the tablet completely, not just put to sleep. Leave it off for several minutes so the RAM will clear completely (normally takes less than a minute). If that does not work, leave the tablet on (It can go to sleep and that's fine.) until the battery drains to zero. Then charge fully and you should be good to go. Worked for me.
May 01, 2015 | Tablets & eReaders
My windows 8 tablet keeps shutting off on me even though its charging. whats wrong with it?
It may be your power settings. Your tablet may actually be going to sleep, rather than just turning off. Go to your Search and type "power options". "Power Options" should show up for your to click. Open that up and look for a link that says "Change power settings". The images below of similar, but not exact.383ea127-facb-432e-a635-d84ff5f076af.png 3e60e9b0-e71b-4b2b-aec2-482700c2ff67.png
Jul 16, 2014 | Dell Tablets & eReaders
How to fix fujitsu t732 when it won't power on after sleep mode?
take the battery out and unplug it. Wait a minute and put it back, then try
Jul 04, 2014 | Fujitsu LifeBook T732 XBUY-T732-W7D-002...
My lenovo s820 keeps on restarting
The first thing to do is boot it in safe mode and let it go to sleep, then wake it up and see if the problem goes away, If it does then the problem is related to something in the startup programs.
Feb 03, 2014 | Lenovo S820 Android 4.2 MTK6589 Quad-core...
Zeepad 7.0 Jelly Bean can't connect to the wifi
my zeepad will stop or go in sleep mode when on it is there any thing i can do to fix it.
Sep 24, 2013 | ZEEPAD Tablets & eReaders
My Micro Cruz keeps turning itself on. Won't stay off for longer than five minutes then the screen powers up and stays on. I have resorted to powering it off after use which sucks as it looses time, my...
So it's your screen that is coming back on after you press the power button to put it into sleep mode (not all the way off)? Flashing to the new firmware made this issue even worse. I would try a full reset. Back up apps and follow the procedure for resetting the device (press the hole at the top with a paper clip don't use a mechanical pencil...).
Other than this I would reflash or flash to a new rom it seems like you have a defect not a software issue. Flashing to the the updated rom should've fixed any problem that was software based not made it worse. It seems like there is a connection loose and it's triggering the device to wake up from sleep mode. If you feel like you have it in you, you can pull the device apart and try securing all connections but this is not recommended.
Oct 31, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
On sleep mode, would not wake even if i slide the switch and hold it for 20 seconds.
The hard reset takes 45 seconds sliding the button, It also might have run out of battery which puts it into a mode that looks like sleep mode
Mar 11, 2011 | Amazon Kindle Wireless Reading Device
Acer ICONIA Tab W500PC52G03iss Logo
91 people viewed this question
Top Acer Tablets & eReaders Experts
Lawrence Oravetz
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
