Medpro card not detected - Computers & Internet
Iocean x7 phone sim card not detected
Hi if you found a solution to the problem? I have a similar problem-after a few falls not read my sim card
May 02, 2013 | Nokia X7
Ram not working
Step 1:
A memory slot is a slot in your motherboard where you place your RAM (Random Access Memory) card. In layman's terms, the RAM is the "temporary memory" that the computer utilizes whenever it is turned on. If the computer cannot detect a RAM card installed in one of your memory slots, you have to troubleshoot the problem immediately.
Ensure that the problem is with the RAM slot and not the memory card. Turn off the computer, unplug all devices connected into the ports of your computer and open the computer casing. Refer to the manual of the computer to know the specific steps to follow in opening the computer casing. Remove the memory card from the RAM slot. To do this, unlock the card using both hands. Pull the card away from the slot to remove. Inspect the RAM card for any apparent physical damages. Wipe the card with a clean cloth to remove dust. Also wipe the memory slot in your motherboard. Place the RAM card back into the memory slot. Press the card into the slot until it clicks into place. Close the computer casing, connect the cables back into their respective slots and turn on the computer. Turn on the computer and see if the memory is detected. If the computer does not boot up, the RAM card is not detected by the computer. Assuming that you have two memory cards installed in the computer and the computer boots up, check if the second memory card is detected by the computer. Click "Start," right-click "Computer" and then "Properties." Under "System," check the amount of "Installed Memory (RAM)." If the RAM is not detected, the RAM slot or the RAM card itself may be malfunctioning. Place the RAM card into another memory slot in your motherboard and see if the card is detected. If it is detected, the other memory slot is malfunctioning. Do not install any RAM card into it to avoid further damage. If it is not detected, the RAM card may be malfunctioning. Insert another RAM card into the slot. If the RAM card is detected, the slot is malfunctioning.
http://www.youtube.com/watch?v=wGp5AiyJInI repair memory slot
Feb 23, 2013 | Computers & Internet
NOKIA 2700C MEMORY CARD NOT FORMMATED SHOW PC NOT DETECTED MEMORY CARD WHAT CAN I DO PL HELP
Use a card holder to connect the memory card to the PC and if this is not detected check it out on another PC. If not detected then the card is defective. If not you can right click and format the card after removing all the files from the card.
If the card is not detected it is damaged and you can try if there is a free replacement from the dealer.
Sep 05, 2011 | Nokia Classic 2700 Cell Phone
I have a blackberry curve with a 2gb memory card but now when I want to access the memory card it shows there is nothing on but I have music and pictures on the memory card
Hi
Firstly check whether u have inserted memory card correctly . If that is correct then check whether the phone is detecting the card. I think blackberry has an option to check it .
If the phone is detecting the card then check for the free space it is showing on the card . If it is showing the correct space and not showing the contents then switch off and switch on the phone after removing the card .
If the phone is not detecting the card then check the card using a card reader there also if it not getting detected then you need to check the card whether it has some physical problems. If the card is getting detected on the card reader check your phone with some other card and even after that if the same situation exists then you can take your phone to a service center
Oct 27, 2010 | Electronics - Others
Not detected
try to fix the card in your neighbour system, if not detect replace the card, if detect replace your pci card
Oct 19, 2010 | Creative Labs Sound Blaster Live! 5.1...
Data recovery from undetectable micro sd card
my card is corrupted and now my computer did not detect my card i have many things in that and i don't wanna lose all that
Feb 10, 2009 | RCA OPAL M4001 MP3 Player
I lost My Sound Card CD and i want to download the same cd via the Internet how can i do it.
Aug 12, 2008 | Creative Labs Sound Blaster Live! 5.1...
IP phone to IP phone through an IP trunk Issue
Is this an IP office? If so, maybe try to untick the "direct media path" box in the extension tab.
Jul 07, 2008 | Avaya 4610SW IP Phone
SD Card Recognition
Perform the following procedures when your digital camera does not detect the SD card. 1. Restart the camera Turn the main power OFF, or open the battery cover or SD card/battery cover to remove the battery. Make sure the SD card is fully installed. Then, turn the main power ON, or insert a battery again and close the battery cover or SD card/battery cover until it latches. 2. Initialize the SD card Format the SD card with your camera. Formatting procedures varies depending on the camera model. See the Camera User Guide supplied with your camera for the instruction to format the SD card. When formatting the SD card, slide its tab upward to cancel write protection. It is impossible to format the SD card while it is write protected. 3. Check if your camera detects other SD cards (If you own multiple SD cards.) If your camera does not detect the SD card after performing the procedures 1 and 2, check if the camera detects other SD cards. If it does detect other SD cards, the SD card that wasn't detected may contain some problem.
Aug 31, 2005 | Canon PowerShot SD110 / IXUS IIs Digital...
CF card problem
Perform the following procedures if your camera does not detect a CF card. 1. Restart your camera. - Set the camera's power switch to and remove the batteries. - Open the CF card slot cover to make sure the CF card is securely set in the card slot. - Insert the batteries and turn the power switch . 2. Format a CF card. Format the CF card with your camera. Refer to the Camera User Guide supplied with your camera for instructions on formatting your card. 3. Check if your camera detects other CF cards (If you own multiple CF cards.) If your camera does not detect a CF card after performing the procedures 1 and 2 above, the card that wasn't detected may have a defect.
Aug 29, 2005 | Canon EOS-20D Digital Camera with 17-85mm...
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
