Question about Waring JEX 328 Health Juicer
No longer turns on
The juicer stopped working in the middle of juicing. Nothing was stuck in the juicer. There was a loud noise, I turned it off, checked it to see if there was something blocking the juicer basket, there was nothing blocking it.Turned it back on and there was the same loud noise and this time, smoke. I turned it off immediately, and disassembled everything...nothing seemed out of place. Then tried to turn it on again and it would not turn on. What is the problem?
    New Friend:
So where is the reset button? i have one that didn't turn on the other day, i just fiddled with the top part and re-locked it and it worked. the next day it wouldn't turn on at all!
Posted on Aug 30, 2014
  • eyecam Aug 30, 2014
    there isnt a reset button only a one time inline fise at 8 amps wired into main line inside machine , size of an aspirin ,costs about $ 8.00 per two , you can get a thermal fuse , when it heats up due to stress blows out cools down and reset its self ?but if you are telling me that you had smoke something might have burned yp. tou can check if you have current coming into the machine if you have a voltage meter and are confident in the know how of electricity ?
  • 95 Answers
Check the motor some juice might have been inside of motor has 2 brushes need to work prpoerly on 110 vac rated at 10 amps or better. clean your machine look for signs inside not on the city streets..
Posted on Jul 07, 2014
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Loud "pop" noise as if
The reset button is actually a circuit breaker in miniature but there may be a thermal fuse to protect against fire in case of failure of the circuit breaker.
If you are game, open the housing again and look for a device you don't recognize that is in series (in line) with a wire; it may be in an insulating sleeve and not immediately visible, appearing only as a thickening of the wire. This could be a thermal fuse.
They are not supposed to open under load but only when the temperature exceeds a limit and these do not reset. Unfortunately, these are now all coming from China and are not very reliable so may open even when the design temperature is not exceeded.
If concealed, you would need a simple multimeter to determine if it had 'opened' by checking for the continuity of the wire stretch.
Blenders in general are 'universal' motors which can use AC or DC and this type employs carbon brushes which do abrade with time and when they have become too short, they can become intermittent and cause such a popping sound too. Brushes are replaceable so you might check Waring's website to see if they offer a fixed-price replacement or brushes as replacement parts.
I would be prone to see the Waring restored since most replacement blenders are from China and have often more than just one problem even when new. One given to us as a present smoked while crushing ice so we retrieved our old Oster from its stash and tossed the oriental wonder.
Posted on Jan 09, 2011
SOURCE: Waring Pro Juice Extractor model #WE100PC - WILL NOT POWER ON!
check bottom of the basket and see if piece is missing or broke.
Posted on Feb 21, 2010
In the middle of juiceing, the machine abruptly stopped.
Some juicers have an automatic shut off in them that prevent the motor form burning out.
When mine shuts off, it invariably means it got backed up and some produce in on the blade or in the shoot..clearing that out and then turning on with mine --the juiceman turns it back on.
On my vitasmix and garbage disposal it has this motor saving feature but there is a little button ypou must hit to rest it. sometimes it comes right back on when the button is hit but sometimes waits as the motor is not sufficiently cooled down and will come back on when a short time passes.
Maybe juicing less stuff at each push will help. Mine tends to do this when I am juicing very rapidly and jamming stuff in or when something extra hard is in there and the motor overheats trying to cut it perhaps smaller pieces might help if the produce is hard or very fibrous.
Mar 02, 2015 | Juicers
Philips Avance Juicer 1871 has just completely stopped while juicing lemons - its been cleaned and nothing is stuck, what should I do? Its only 3 months old.
Push the reset button underneath - this worked with mine when the same happened to me; I only realised it was there after changing the fuse, which didn't fix it. I turned it over and found the button and voila!
May 17, 2012 | Juicers
When i juice greens i am no longer getting any juice from them. is my blade dull?
If you mean green leafy greens, the juicer is
not really designed for them. A sharp blade
will extract some juice from them, but I found
a new blade seems to increase the vibration
issue. Acme works best on carrots, apples,
celery, etc.
Oct 25, 2010 | Acme 5001 Supreme Juicerator Juice...
Was just juicing carrots and the motor stopped , now when i switch on all i hear is a whir sound but I dont think it is rotating at all what should i do to get it working again?
I am having a similar problem, turned it on to juice carrots, it sounded like it was rotating very slowly then the motor just stopped. Would love a fix, i am addicted to my juicer and would be very sad if it was not good. It is only about 2 months old.
Jul 15, 2009 | Jack Lalanne Power Juicer (Stainless...
Juicer blade stops intermittently
you are pushing too hard, this machine likes it slow.
Dec 15, 2008 | Champion 2000+ Household Juice Extractor
Stop running in the middle of juicing
well this is very common with this version, clean inside out, shredded fruits and veggies tend to stick and jam blades.
Jan 09, 2008 | Jack Lalanne Power Juicer (Stainless...
Just stopped working
I am sorry I might not be able to explain in English very well, but I hope it will help somebody.
In my case, the pulp container was a problem.
when you take out the container, do you see the little(very very small )hole that if you push with something like toothpic it makes sound like "click, click"? I guess when we put the pulp container back, the container is supposed to push the safety button ( bottom area), but I think the part of the container that push the button was broken, and it didn't start,so I just put something small inside the hole before I put the container back to the juicer, so it covers the missing part.
Their customer service doesn't help at all, I waited 1h to talk to somebody, and he couldn't help me. so please check that part.
Sep 04, 2007 | Jack Lalanne Power Juicer (Stainless...
Waring JEX 328 Health Juicer Logo
429 people viewed this question
Top Waring Juicers Experts
eyecam
David Payne
David Payne
Tom Chichester
Are you a Waring Juicer Expert? Answer questions, earn points and help others
