Question about Haier HTF201 TV
Eliminate auto sap
How I can eliminate Auto SAp from my Haier HTF29s32
    Problem Solver:
  • 14 Answers
Usually you go in the menu and all tv got a section you can cancel
or if it still there you got tv problem
Posted on Mar 25, 2014
My printer is intermec PF8T i have i SAP program to print patient information but it cannot print the error is orange ligths was the error.
There are a few things to figure out here from a SAP basis administrator perspective these steps are common. Also I am just trying to help and with SAP there could be multiple solutions. Good luck.
Check SAP MarketPlace for SAP note: 1557674
Here are the steps taken from the SAP Community Network which might help. I would suggest reading the entire link as its informative. http://scn.sap.com/thread/1975158
Step:
run SPAD
to create an output device, choose Output Devices on the Devices/Server Tab
click on Display now you will be in Spool Administration window
click on Change button then Create tab will be appear, now you have to put the following information.
Under DeviceAttributees
put the Output Device name with shortname
Device Type: SAPWIN
Device class: Standards printer
you can put Model/Location/Message as per concern.
Under Access Method
Access Method: G
Host Printer: __default
save
for more information about
Device Type
http://help.sap.com/saphelp_nwmobile711/helpdata/en/d9/4a910f51ea11d189570000e829fbbd/content.htm
Access Method
http://help.sap.com/saphelp_nw70/helpdata/en/4f/9c033cff903105e10000000a114084/content.htm
(1) Choose "S: Print Using SAP Protocol" if a print server with SAPlpd or SAPsprint is used to print barcodes.
(2) Choose "F: Printing on Frontend Computer" if SAPlpd and SAP GUI are used together to print barcodes, SAP GUI sends print job to SAPlpd, SAPlpd is started automatically and forwards the print data stream to the Windows print manager.
(3) Choose "G: Frontend Printing with Control Tech", only SAP GUI is involved in printing barcodes, SAPlpd is not used.
Here are the Intermec drivers:
http://www.intermec.com/support/downloads/index.aspx
Understanding the LED Indicators
LED Meaning
Green (blinking) Auto-Sensing mode
Green (blinking) Downloading font, form, or graphic
Green (solid) Dump mode
Green (solid) Ready mode
Green (solid) Print mode
Orange (solid) Boot mode
Red (blinking) Media jam, overheated print head or stepper
motor
Red (blinking) Downloading firmware
Red (solid) Error mode
Good luck
Dec 27, 2013 | Intermec Office Equipment & Supplies
Sap
Set the MTS option to "Auto SAP". See page 35 of the manual at http://www.docs.sony.com/release/KDL52XBR2.pdf
Jun 11, 2013 | Sony BRAVIA KDL52XBR2 Television
I think that my TV soney braiva xbr has an issue with SAP but some ch. are in spanish some do not have sound How do i reset this tv?
Press MTS/SAP on the remote (under the number buttons) to go between the 3 options of STEREO or MONO or AUTO SAP. Not all channels will have SAP (secondary audio program). Selecting stereo should eliminate any secondary audio.
Mar 24, 2011 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
How do i program cable channel in to my 27" tv ,,only has local channels 2-13 when we use auto program, no other stations lock in to the tv....SAP in left hand corner 27" glass screen flat
You have to make sure the TV is set to cable not air. Will not look for upper programs unless it is set to cable. SAP needs to be off in the setup menu unless you want it on. Secondary Audio Program(SAP) is for foreign languages.
Sep 23, 2009 | Televison & Video
Sound
SAP is short for "second audio program" and is a way to send a second audio track along with the main one. In many areas stations use SAP to provide Spanish or other language sound for movies and other programs. If you have SAP turned on you don't know it until you tune to a channel where it's being used, and then you hear the other sound. Just turn SAP off using the remote control or TV menu.
Dec 18, 2008 | Sony FD Trinitron WEGA KV-36FV27 36" TV
20" RCA television
Greetings de_on,
Per your owners manual I found you should have an option in your Audio menu labeled MTS. You should be able to adjust the MTS by selecting it and press the + key.
There should be three options under MTS: Stereo, Mono, Auto SAP. You would probably want to select Stereo as Auto SAP will engage the Second Audio Programing which will cause other sound problems.
Hope this helps.
Jon
Go Ahead. Use Us.
May 12, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Auto-sap stuck on tv
I unplugged the tivo box and then plugged it back in.  This restarted it and cleared the problem.
May 10, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
Auto SAP
The problem is not a cable one, but a TV function. Pull out your user manual for your TV. My dad just had this happen, and he has a Sony WEGA TV. The auto sap is an AUTO Secondary Audio Program, you need to find the menu to back out of it.
Good luck.
Jan 06, 2008 | Sony KP-65WV700 65" Rear Projection HDTV
VCR Help
SP means Standard Play. Generally that is the Normal speed at which a VCR Records or Plays back a tape. SP is automatic, as it is the Standard setting. If you wish to record more picture than the normal 120 mins on a tape, then you choose LP (Lond Play) oe EP (Extended Play).
Nov 20, 2007 | Sansui VHF6010 VHS VCR
Sound setting
do a set up and turn off sap in the audio setup.auto program again
Oct 28, 2007 | RCA 32F531T 32" TV
Haier HTF201 TV Logo
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
