Question about Intel Desktop Board D945GCPE - motherboard - micro ATX - LGA775 Socket - i945GC
INTEL D945GCPE DISPLAY PROBLEM OCCURED .I CHANGE THE DUAL CORE PROCESSOR AND DDR2 RAM OF THIS MOTHER BOARD AND FIXED TO ANOTHER 946 MOTHER BOARD ITS WORKING.SO 945 BOARD DISPLAY IS NOT WORKING WHAT IS A SOLUTION
  • 883 Answers
SOURCE: mother board problem
sounds like video card driver issue...ensure driver is correct by looking at video card in device manager. Also ensure that system interrupts are being allocated properly.
Posted on Jul 29, 2007
sdgdfh
  • 24 Answers
SOURCE: MOTHER BOARD INTEL D945GCPE MANUAL
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
49
Posted on Mar 13, 2009
ghoff1
  • 167 Answers
SOURCE: How can i upgrade my intel(r) pentium r dual core 2.8 processor.
http://www.mercury-pc.com/p-mainboards-list.php hello, try this link to id the board, as you will see 5 945 mercury mainboards. if you pick the one you have, like 945gcm for example, you can find out the fsb, cpu, memory. if you still need help, reply please rate this solution and good luck!
Posted on May 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: machine is not booting
  • I know what is your problem?May be problem on your HDD you change it then solve your problem.If you are not fix,You need Fox con MX PK g31 chip mother board.It is very adjustable motherboard for pin less p4 HT processor.
Posted on Mar 19, 2010
SOURCE: I brought a new Intel
ggfhfh
Posted on Jan 14, 2011
Intel 946 mother board
You need at least 1GB of Ram Memory, and should have 2GB.
[512MB + 512MB = 1024MB or also stated as 1GB ]
The - Intel 946 - designator you have listed refers to the motherboard chipset.
It is either an Intel 946PL, or Intel 946GZ motherboard chipset,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
You can see the list of processors it supports. Also look at the Front Side Bus speed it supports (FSB), and note 65nm architecture for the processor.
As for office work, or surfing the internet; more Ram Memory will help.
For editing videos, or intense games though, you need a decent graphics card.
Regards,
joecoolvette
Dec 21, 2012 | Computers & Internet
My Ram is 512MBytes and Motherboard Chipset model is i945GZ. Can i use 2GB Ram?????
Hardware Support
The Biostar i945GZ 775 SE supports RAM a maximum of 2GB using its two 240-pin DIMM slots, each can be populated by a 1GB stick. The board supports DDR2 400 or 533. With two identical RAM sticks installed, the board will switch in dual-channel mode operation.For the support of processor, the board can accommodate Intel Pentium 4, Core2Duo and Pentium D, even Celeron D, all with clock speed up to 3.8GHz; and all are based on a LGA775-pin socket architecture. use an Intel Pentium D 820 2.8GHz (dual-core, Smithfield) processor on this board. use the following components to complete the system: CPU: Intel Pentium D 820 (Smithfield) 2.8GHz, dual-core
RAM: Hynix PC2-3200 2x512MB (1024MB) DDR2 400 HD: Seagate SATA-I Barracuda 7200.8 250GB CD/DVD-ROM Drives: HP dvd640, Phillips DVD-ROM
Oct 10, 2011 | Intel Computers & Internet
Im plannin 2 upgrade my RAM..My mother board(Essential series D102Ggc2) supports DDR2 800...my processor is Pentium D 820+ ...my query is: DDR2 800 is supported by Mother board but is it supported by my...
Your motherboard has the follwing memory support : DDR2 533/400 SDRAM 2 slots, Single-channel (2GB2 Max). As long as it is supported by your motherboard there would be no problem since your processor is also supported by the motherboard.
Please refer to the follwoing links from Intel:
1. http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/cs-026580.htm
2. http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
3.http://cip-origin.intel.com/cd/channel/reseller/apac/eng/products/desktop/bdb/d102ggc2/feature/index.htm
Mar 06, 2011 | Intel Pentium D 820 Smithfield 800MHz FSB...
Machine is not booting
Mar 19, 2010 | Intel D946GZIS Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
I am from INDIA... i want to buy i IBM
Hi Friend,
Check below the model numbers of the intel dual core mother boards avaliable and the
address where u can buy it in Chennai,
1.Intel Atom 330 Dual Core (2x 1.6Ghz)
a.Intel D945GCLF2 mini-ITX
Features are:
  • Dual Core Atom CPU
  • TV-Out (S-Video)
  • 4x Rear USB 2.0
  • VGA, Serial and Parallel
  • 1x DDR2 533/667 RAM
  • 1 x Gbit LAN
  • Realtek High Definition Audio
  • Power: 24 Pin ATX, P4-connector
  • RoHS compliant
b.ECS P945GC
Feature are:
  • custom design board using mini-DTX form factor up to 170×170mm.
  • Intel 945GC and ICH7 chipset Intel Atom 330 CPU dual-core 1.6 GHz, 2×512KB (1MB) of L2 cache
  • FSB 533MHz system bus support up to 1×2GB (DDR2 533/400)
  • Integrated Intel Graphics Media Accelerator 950 ( GMA950 )
  • 2 X SATAII and 1 x IDE channel (for 2 IDE devices)
  • VIA VT1708B 6-channel High Definition audio CODEC
  • 10/100 Fast Ethernet LAN using ATHEROS AR8012 10/100 Mbps PHY
C.Jetway NC92-330-LF
Features are:
  • INTEL®945GC + ICH7 Chipset
  • Support INTEL®Atom Dual-Core 330 CPU
  • Built-in INTEL®GMA 950 Graphics Core
  • Supports 1x Gigabit LAN
  • Integrated ALC662 HD Audio CODEC with 6-CH
  • ITX Form Factor(170mm x 170mm)
  • Support Daughter board Expansion
D.Foxconn 45CSX / 45CTD (soon to be release)
Features are:
  • Intel® AtomTM dual-core 330 processor mounted on board
  • 533 MHz (FSB)
  • DDR2 533 MHz x 1 DIMM, Max. 2GB
  • 1* PCI
  • 2* SATA II
  • 5.1 channel HDA, Realtek® ALC662
  • 10/100M LAN, Realtek® RTL8100C
  • 6 USB 2.0 ports
These are available in India with Prices and best in India Industry
Intel Dual Core Price list in India
  • Intel E2140 Dual Core Processor - 2100/- Indian Rupee
  • Intel E2160 Dual Core Processor - 2450/- Indian rupee
  • Intel E2180 Dual Core Processor - 2800/- Indian Rupee
  • Intel E8500 Core 2 Duo Processor - 8200/- Indian Rupee
  • Intel 2200 Pentium Dual Core 2.2 GHZ -3400/- Indian Rupee
  • Intel E4600 Core 2 Duo Processor - 4990/- Indian Rupee
Address
Address:88/150.Nelson Manikam Road,Dharma Tower Ground,Floor7&8,Choolaimedu,Chennai-94
Landmarks : Near Nungambakkam RailwayStation / Loyala College /Metha Nagar Bridge/Opposite to Bank of Baroda/Mobile Store/ Indian Terrain Ready made
Contact Number:98402 72809
For future assistance kindly contact fixya
Regards,
Ayyasam
Jun 26, 2009 | Abit AS8 Motherboard
Apr 29, 2009 | Intel Computers & Internet
PLEASE PROVIDE A MOTHER BOARD MODEL WHICH SUPPORTED DDR2 RAM & 1.8 GHZ DUAL CORE CPU
Depends on what processor your using as the basic of all motherboards are either for Intel processors or AMD processors. They are designed different. Then you can take it from there to a reputable computer hardware online store. Hope that helps.
Mar 10, 2009 | Foxconn Computers & Internet
Mother board problem
Jul 28, 2007 | Intel Motherboard
Intel Desktop Board D945GCPE - motherboard - micro ATX - LGA775 Socket - i945GC Logo
22 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
