Question about Sharp KB-6015K 1000 Watts Convection / Microwave Oven
Drawer slips Open only
How to reset dacor mwo30s warming drawer
If for some reason you don't still have your owner's manual, you can find it here.
Nov 30, 2013 | Dacor MWO30S Millennia Series Warming...
Tip
Troubleshooting KitchenAid oven, range and microwave error codes
Here list of Kitchen Aid range and oven codes.
4 Digit Failure Codes
F1 - E0 EEPROM communication error
F1 - E1 EEPROM checksum error
F1 - E2 UL A/D error
F1 - E4 Model ID error
F1 - E5 Calibration shifted
F1 - E6 Latch signal mismatch error
F1 - E9 Stack overflow
F1 - E3 Wiring harness cavity size does not match stored value
F2 - E0 Shorted touch pad
F2 - E1 Keypad cable connection error
F2 - E5 Cancel key drive line open
F2 - E6 Cancel key drive line open
F3 - E0 Oven temperature sensor (RTD) opened (upper oven on double oven models)
F3 - E1 Oven temperature sensor (RTD) shorted (upper oven on double oven models)
F3 - E2 Oven temperature is too high (Cook mode)
F3 - E3 Oven temperature is too high (Clean mode)
F3 - E4 Oven temperature sensor (RTD) opened (lower oven on double oven models)
F3 - E5 Oven temperature sensor (RTD) shorted (lower oven on double oven models)
F3 - E6 Drawer sensor open
F3 - E7 Warming drawer sensor shorted
F4 - E1 Meat probe malfunction - shorted
F5 - E0 Door Switch
F5 - E1 Self clean latch will not lock
F5 - E2 Latch during CLEAN error
F5 - E5 Self clean temperature not reached within 45 minutes.
F5 - E6 Door is open, but latch is locked
F5 - E7 Self clean latch will not unlock
F6 - E0 Return line not connected
F7 - E1 Common switch wire defective
Two digit codes:
F0 ERC Board failure
F1 ERC Board failure
F2 Oven temperature is too high
F3 Oven temperature sensor open
F4 Oven temperature sensor shorted
F5 ERC Board failure
F7 Function key stuck on ERC
F8 ERC Board failure
F9 Oven door lock failure
Microwave and Microwave combo error codes:
F1 - E3 or F1 - E4 Electronic control malfunction
F2 - E0 or F2 - E1 Keypad connection error
F2 - E3 Keypad held down too long, or keypad is shorted.
If you get an error code, try first resetting the code:
1. Disconnect power for about two minutes.
2. Connect back power.
3. If code re-appears, test and eventually replace faulty part.
Regards.
on Mar 27, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Drawer tries to close and then opens
I would suspect that a foreign object may have gotten in the pathway of the drawer, the drawer actuator is out of adjustment, or one of the door sensor switch is damaged, defective, or off its mount.
The service manual is at our site here.
You can order Sharp parts from Encompass here.
Nov 02, 2012 | Sharp KB6024MW Insight Pro 24" Built-In...
The freezer part is working fine ,it seems as tho the refrigerator part is warming instead of cooling
The freezer is actually where the cold originates and is passed through into the refridgerated area.
Open the fridge doors and check that the air passage is not blocked by something stored against it. It's probably on the top shelf and looks like a louvre vent. There may be another down by the crisper drawer
Aug 14, 2011 | Microwave Ovens
Sharp Insight Pro microwave drawer KB6024MS not working
The drawer often stops working when it is abruptly stopped while opening and forced closed or vice-versa. To fix, simply do the following:
1) Push the draw all the way closed
2) Push the "Setup" button repeatedly until the "Open/Close ...?" appears.
3) Hold the Start Button until the time reappears in the display.
4) Repeat steps 2 & 3 three more times
5) Unplug the Microwave for 30 minutes.
The drawer is now reset. The drawer will now open electronically (automatically) either by pushing the open button on the panel or by pulling the drawer handle slightly.
Feb 05, 2010 | Microwave Ovens
Sahrp microwave drawer doesn't automatically
It will have a one year warranty.
I would contact Sharp for their nearest authorized servicer.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online.
Nov 27, 2009 | Sharp Microwave Ovens
Bosch range front glass smashed
open the oven door and look on the sides where the door meets the oven. also slide open bottom drawer and look where drawer meets oven. hope this helps!
Aug 29, 2009 | Bosch HMB402 Microwave Oven
Everything on my microwave works except it stopped heating food
I found this on another blog and it worked for me.
Model #KB6024MK, this is a Sharp microwave drawer that would open and close properly, but when started would not heat. These drawer units will sometimes close properly, but not enough to actuate the interlock switches to power the magnetron. A quick test is to turn the unit on and press in on the drawer handle while it is running. If you start hearing the low hum of the magnetron, the interlock assembly is out of adjustment. Removed the left side panel and gained access to the switch mounts to do a quick adjustment so when the drawer closes, the switches close properly to allow operation. It may take more than one adjustment to make it work properly so test it several times before reinstalling the side panel. It should work properly when the drawer auto closes and should not require any manual manipulation from the user.
Dec 06, 2008 | Microwave Ovens
Sharp KB-6015K 1000 Watts Convection / Microwave Oven Logo
11 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
