Question about Frigidaire FDB700BFC Built-in Dishwasher
Frigidaire dishwasher leaks from motor
I have a Frigidaire UltraQuiet III (model number FDB700BFC0) that is leaking water from the vents on the bottom of the motor. Replaced both gaskets and the leak is still there. Any ideas?
    Problem Solver:
  • 50 Answers
This is caused by the cheap bearing's in the motor. Even after I have replaced my $200.00 motor assembly it still leaks. put a small flat dish under it as the leak should be small and when the dishwasher starts making a loud noise the bearings are gone and I do not recommend replacing motor as it is half the price of washer itself. I myself will never buy a fridgidaire again. However if you do replace the motor assembly it is very easy and there is a video on youtube showing you how. good luck
Posted on Jun 26, 2014
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Leaking intake valve on frigidaire ultraquiet III, model: FDB750RCC1
    Hello Dan Wetmore - Do you notice if the dishwasher have deflectors installed in the bottom left and right corners of the tub gasket channel? If so, confirmed that they are properly installed and present. In case that it is not, they may possibly need replacing. However, keep in mind that the springs or hinges may possibly be damaged, gasket not sealing properly or the leak could possibly be coming from the drain motor/pump (which would be more cost effective to repair). I would strongly suggest contacting a professional to move forward accurately.
    Posted on Dec 14, 2012
    Frigidaire ultraquiet III dishwasher not draining
    Will the drain hose drain into a bucket? If so the garbage disposer is probably plugged.
    Feb 07, 2015 | Frigidaire Dishwashers
    Leaking from motor
    Water Inlet Valve
    If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
    Enter your model number to see parts for your dishwasher.
    Help me find my model number
    Center Wash Arm Assembly
    If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
    Lower Wash Arm Assembly
    If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
    Upper Wash Arm Assembly
    If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
    Door Seal
    Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
    Dishwasher Door Gasket
    God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
    May 23, 2013 | KitchenAid Dishwashers
    Frigidaire built in dishwasher leaking water out of the bottom.
    One of the reasons could be door seal or sump seal leaking. But if the leak only occurs at a particular time in the cycle then most likely the wash motor or drain motor seals.
    Need the model number to make a more closer assessment.
    Dec 31, 2012 | Frigidaire Dishwashers
    Dec 13, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
    run it with no soap. if you get no leaks then cut back on your soap. you may need to run washer a few cycles to get rid of excess soap.
    Sep 02, 2012 | Frigidaire Dishwashers
    LG dishwasher is dripping water from vent onto floor
    Good that it is working. Recommend you keep a lose eye on the vent on the bottom of the door panel. This model will probably begin leaking again if it has not been retrofit with a kit that LG developed.
    Please open a new problem when it starts to leak and please provide the Model and serial number when you do. Good Luck!
    Mar 24, 2009 | LG LDF6810ST Stainless Steel Built-in...
    Frigidaire Ultraquiet III
    hi there,
    can you supply me with the exact model # off your d/w please?
    Mar 21, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
    Leaking dishwasher
    Sorry about the delay in time in getting back to your problem if not already resolved heres what you can try. Remove the bottom panel and run through a load, to see exactly where leak is coming from, most common place for leak is through the heater hold down brass nuts. They crack and need to be replaced
    Feb 27, 2008 | Frigidaire 24 in. PLD2850 Built-in...
    Water Leak at vent area in door...
    On this model the vent is open and shut by a wax motor. The vent should be closed tight during the entire wash cycle and the first 6 minutes of the drying cycle. Check the operation, make sure there is not a bunch of gunk restricting it. If you are handy with a meter check the resistance of the motor. It should read approx. 2100ohms. Another reason for leaking at the base is oversudzing. Also check the upper spray arm for cracks or splits shooting water into the vent area. Catriver...post back.
    Oct 23, 2006 | Maytag 24 in. MDB4000 Built-in Dishwasher
    Frigidaire FDB700BFC Built-in Dishwasher Logo
    67 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Robert Roath
    Robert Roath
    Level 1 Expert
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
