B4 remote. rthe tv is not responding to remote, nothing on the dstv box happend, when i remove batteries in remote B4 there is a light on at tv , if i press anything it goes off but the remote is not moving, i think it is on tv2 but i only have one, how do i reset the remote thank you please help im 73 and my only p[leasure is the dstv
2 Suggested Answers
SOURCE: Hi, My DSTV decoder is
press the shift button, its stats flashing than press the info button (tv1) works every time
Posted on Feb 08, 2011
My beyond platinum B4 remote showing green light and not responding
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
Oct 30, 2015 | Platinum Televison & Video
I hav a loewe concept l32 tv whn u turn on by remote or manually tv turns on then switches off just b4 picture comes on
It sounds that the back-light ivnerter has the fault. Contact any service technician before confirmation.
Dec 02, 2013 | Olevia LT32HVE 32 in. LCD Television
DSTV Beyond Platinum model B4 remote not working
it is stuck on 2nd tv which i do not have, how can i return to one tv only
thank you
Oct 22, 2013 | Televison & Video
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I have a Motorola DCT6416 PVR. Dog layed on remote and de-programmed. I can't find the program code to fix my remote control.
are you sure its not something simple like the remote is in the wrong mode. what lights up on the remote when you push buttons?
what isn't working? the cable box not responding? the tv not responding? nothing?
RCN's motorola code is 002 (actually i think the new remotes may be different), TV code could be anything.
FYI: battery cover on remote sometimes has directions for code search
hope something here helped
Apr 19, 2011 | Motorola Televison & Video
HI i have a JMB LCD TV MODEL 42883 today it started turning its self, on and off standby,the standby light is flashing on and off i`ve even tried taking out remote battery but nothing works sometimes...
hi I have a JMB LCD TV MODEL 42883which has only worked for one week b4 the screen was cracked by accident everything else is perfect.would solve one of your problems your having with your tv.will sell it at reasonable price.07719651554 if interestd
Mar 01, 2011 | Televison & Video
No lights come on and nothing happens when i press the starter
the yellow or yellow and white wires have come apart under tank simply remove tank follow the wires from right hand switch block should be a black connection block and yellow and yellow and white wires are the old type bullet connectors check for corrosion green deposits reconnect wires yellow to yellow and yellow/white to yellow/white id use some electrical tape to insulate further also helps to stop them working loose again when handle bars are turned switch on the ignition b4 putting tank back on press start button it will start trust me lol
May 19, 2010 | 1997 Suzuki GSX 600 F (Katana)
Where is the starter motor located on mitsubishi carisma?
hi from uk to locate starter motor follow the positive + lead from the battery and when you reach other end of lead it is connected to the starter motor solenoid which is connected to starter motor starter is usually secured to engine/g/box by thee bolts ? b4 you commence removing starter you must !disconnect the battery earth/negative lead ! if you radio is coded ?ensure you know its code b4 disconnection of battery ?
Mar 14, 2010 | 1997 Mitsubishi Galant
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
