Question about Bugaboo Cameleon Stroller
Wheel falls off
The black plastic that holds one of the small front wheels in the frame has broken off, thus allowing the wheel to come off whenever the stroller drives over a bump or is slightly raised off the ground. Wheel goes back in and drives fine as long as there is constant contact with the ground. Can this be fixed or replaced?
  • Bugaboo Master
  • 1,629 Answers
Hi Shawna
We would recommend you contact Bugaboo for assistance
Bugaboo Official Site
Posted on May 12, 2014
  • 19 Answers
SOURCE: Chassis won't lock into position
Don't worry, this is normal. once you lock the seat into place, the front bar stays put, even if you hop a curb.
Posted on Jun 28, 2008
  • 19 Answers
SOURCE: Bugaboo Frog Stroller (Folds on it's own)
Don't worry, this is normal. Once you lock the seat into place, the front bar stays put, even if you hop a curb.
  • 12 Answers
SOURCE: Need to fix a Bugaboo Frog wheel
just order new wheels from bugaboo. They cost about $30 bucks each or contact a local retailer to order you some wheels.
Posted on May 12, 2009
SOURCE: bugaboo frog stroller- front small wheels put on wrong way. how do I get them out without breaking them?
get flash light and butter knife... shine light through back of where you have your wheels... use knife to press tab back and pull on wheel.
Posted on Jun 06, 2009
  • 274 Answers
SOURCE: bugaboo frog stroller- wheel put on wrong way
try www.buggypitstop.co.uk see if they can help you
Posted on Feb 12, 2010
Master craft carpet cleaner needs repair Who can handle this
Dear Mirek,
I am thinking you may need to repair this yourself, or have someone do it for you.
Look and see how the other wheel on the other side its held in place. You may need to fashion a clamp device to hold that wheel in, as it may be a plastic part that has broken.
A replacement is very likely not available.
Try online, type your make and model in to your search engine and see if a dealer can help you.
God bless your efforts.
Feb 13, 2017 | Vacuums
How do i replace fog light on picasso xsara 05
Jack up front; remove road-wheel (support Picasso on axle stand).
Remove two large torx screws on lower edge of bumper and peel back wheel arch liner (wedge behind hub).
Remove small torx screw holding black plastic support piece below lamp.
Remove 4 torx screws on holder surrounding lamp, pull back holder and support piece and lift out lamp (minding hands on broken glass)
Note that the body coloured bezel will try to fall outwards at this point.
Fit new lamp and push bezel in at the same time.
Refit all screws in reverse order, refit wheel etc.
(Total time 25 mins)
Aug 16, 2015 | 2005 Citroen Xsara Picasso
How do I replace the front foglight lamp on a Citroen Xzara Picasso?
Mar 27, 2015 | Citroen Cars & Trucks
Remove front tire on lawn mower
Jill,
If the tire has a hole have you considered a Plug?
If thats not an option before you can pull the tire off, there should be a small snap ring holding it in place. please use blocks to block the tires and do the following.
  • Park the lawn mower on a level surface, then place the wheel chocks in front and behind the rear tires.
  • 2Place the jack under the frame at the front of the mower. Raise the mower up and place the jack stands under each side of the frame. Lower the jack until the mower frame sits firmly on the jack stands
  • 3Remove the plastic cap in the center of the wheel by hand; this should expose the snap ring holding the wheel to the axle.
  • 4Pry the snap ring off the axle with the flathead screwdriver. Slide off the washer, wheel and the shim washers from the axle.
    To replace tire follow steps 3 and 4 in reverse order. place shim washers back on and then wheel and then snap ring, etc...
    hope this helps
  • May 29, 2012 | John Deere Garden
    How to remove a bumper on a peugeot 308
    I have just finished replacing the broken grille on my wife's Peugeot 308 (09 reg) wiuth the help of a YouTube video in Russian .... http://www.youtube.com/watch?v=3-KxbwKnvJE ...not that I could understand what they were saying but at least you can follow what they are doing.
    If attempting this, allow a good three hours which is what it took me as there are many bolts to undo and a knack of pushing and pulling fragile plastic lugs. Take your time.
    Removal can be done without putting car on ramps as you will need to put the wheels on full lock to get at the wheel-arch liners.
    Firstly, undo the various screws on the plastic tray underneath the engine which connect to the front bumper skirt. There are three main bolts with washers which are located half way back, one central and one each side.
    Secondly, put the steering on full lock to give you access to the wheel-arch liner for each front wheel. Pull the wheel-arch liner back to reveal a 10mm bolt where the bumper meets the wing of the car. You will need a ratchet with a swivel knuckle and 10mm socket to get onto the bolt head. Undo the bolt and repeat on the other side.
    Lift the bonnet and at the front edge you will see four black flat circles. Using a small flat blade screwdriver, lever up the centre and you can then lift up with your finger which releases the retaining plastic bolts.
    Looking at the top of the panted front bumper where it attached to the front of the engine compartment, you will see several small slots along the width of the plastic which you can place a small flat bladed screwdriver into and push down gently whilst pulling the front panel forwards in a rocking motion to release the plastic lugs. The whole bumper assembly should then start disconnecting from the car. It is helpful to have a second person to gentle prise away the wheel-arch sections from the car body. The whole front bumper section should then fall away but be careful as the wiring for the front fog lights will still be attached. Take hold of the lamp holders and turn through 90 degrees to remove the bayonet fittings. Pull the bumper assembly clear of the car and place on a fabric cloth/mat to avoid scratching the paintwork.
    Re-fitting is a reverse of the above.
    Feb 23, 2012 | Cars & Trucks
    I accidentally mixed up the left and right front wheels when assembling the stroller. How do I get them off to re-install them correctly?
    Hi
    Perhaps you can find one or two small pieces of plastic (underneath) you can push back in untill the bracket can slide over and from the tubing.
    Hope this helps, for I don't actually have Britax in stock.
    Apr 21, 2011 | Britax B-Nimble Travel System Stroller -...
    There is a loose part rattling within my transparency hood which prevents it from working - how can I repair this ?
    I just had this problem too. What has probably happened is that the belt/wheel assembly within the upper lid has broken loose from its plastic housing. It is normally retained in place by two weak plastic posts, each having a plastic extrusion that holds the metal housing for the wheel in place. Just minor stress can apparently snap off the plastic extrusions. (Nice quality workmanship, Epson.)
    Unplug the upper lid and remove it. Unscrew the 5 retaining screws and then use a small flathead screwdriver to carefully pry the bottom of the unit away from the rest of the housing. Stabilize the wheel mechanism so that you can rotate the whole unit around in order to grab the broken plastic pieces and small spring without allowing the wheel mechanism to crash into things. Superglue the two broken plastic pieces to their proper mated location on the lid, and wait about half a day for a solid bond. Then fit the wheel housing over the two plastic pieces so that the thin silver bar is pointed toward the back of the lid. (Do NOT place the spring over the thin silver bar yet.) Fit the orange belt properly around the wheel. NOW, push the wheel housing carefully toward the front of the lid until there is slight tension in the belt. Squeeze one end of the spring over the thin silver bar and push the spring completely into its recessed plastic trough while compressing it. Reassemble, and you're done.
    Sep 01, 2010 | Epson Perfection 4990 Flatbed Scanner
    Wheel snapped off gracco pushchair
    I have the same problem on both front wheels of a Graco pushchair I inherited. I took the wheel assembly off and had a friend weld steel washers onto the end of the frame and then I pushed the barbed plastic pivot in. It worked for a bit but damage to the plastic barb causes the wheel assembly to fall off without much encouragement. Now looking for Plan B. It may involve more welding and modifications. Not sure what Graco parts cost but would imaging getting them to South Africa where I live would be prohibitively expensive. – MH
    Aug 29, 2010 | Graco Quattro Tour Travel System
    Removal of 2008 Prius steering wheel -
    with a small flat screwdriver, remove the 2 by 2 inch black plastic covers behind the steering wheel. one of them has a hole for the cruis control lever.
    loosen but dont remove the two torx screws behind these covers.
    allow the airbag to fall out into your hands.
    carefully raise the two yellow retainers on the airbag wires, then pull the wires away from the airbag module.
    then squeeze and pull the black horn wire from the airbag.
    to replace the steering wheel, unplug all the wires you see and remove the 19mm nut holding the wheel.
    then by hand wiggle the steering wheel toward you.
    Mar 24, 2009 | 2008 Toyota Prius
    My quinny buzz front wheel keeps getting stuck half way and i end up trying to push the chair with the front wheel sideways which is impossible. i have been advised to clean the front wheel out as it gets...
    First remove the front wheel assembly from the pushchair by pressing in the two buttons on the sides and pulling it out.
    Now look more closely at the assembly - on one side, just where it bends at an angle you will find a small hole, a couple of millimetres across. Take a small screwdriver or some other thin object and push it into the hole a little way, which presses a metal catch inwards, releasing the swivel assembly. While continuing to push this in pull the swivel assembly apart - grasp the wheels in one hand and the L-shaped plastic housing in the other and pull them apart.
    Now clean all the surfaces with a piece of strong cloth.
    When all the surfaces are very clean, take a can of TEFLON SPRAY and spray it onto all surfaces that rub against each other, before reassembling the wheel unit. Silicon grease is a cheaper alternative, but the teflon spray is supposed to be the best for lubricating all moving parts on the Buzz. Whatever you do, don't use WD40.
    Hope this helps! Dan.
    Nov 11, 2008 | Quinny Buzz Jogger
    Bugaboo Cameleon Stroller Logo
    Top Bugaboo Baby Gear Experts
    Jennifer Rock
    Jennifer Rock
    J.D. Browning
    J.D. Browning
    Jerry Greenberg
    Jerry Greenberg
    Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
