Question about ASUS A6J Notebook
How do I dissasembale Asus A6J laptop
I have a Asus A6J laptop that coffee was spilt on (while it was off) it has not been turned on since this happened about 7 days I want to pull it apart to make sure it is dry & clean dose anyone have instructions on how to do this, I have a ruff idear but would like to be sure
  • 57 Answers
You should go to the manufacturers website and look for instructions to remove the keyboard. After removing the keyboard you should be able to see evidence on the back side of the keyboard and/or the motherboard of liquid damage. If you see moisture, allow the unit to dry more with the keyboard off. When you feel it is dry, install the keyboard and try to boot the system. If it does not boot you will need a new motherboard.
Posted on Jun 15, 2009
    Scholar:
  • 149 Answers
Short of doing it for you, I would suggest to get a clean area to work on, a place to put all your screws that you will be removing... ideally a tray or drawer for every set of screws. Get yourself a good digital camera to record your process. This helps when you want to rebuild your system back. Above all, work slowly and paying close attention to every step that you take. I can't stress it enough to document your work, you can get lost very quickly doing this. I do this all the time, I have notes, but not for this particular laptop. I would start you off by removing the bezel that covers the power buttons, Normally I would work from right to left, gently prying up the bezel with a small screw driver. The exposed screws will remove the keyboard, be careful of the ribbon that attaches the k/b to the motherboard. You will work your way down to the system, but I would start cleaning the keyboard first. Good luck to you. Keep us updated. -Carlos:
    Problem Solver:
  • 11 Answers
It's called taking screws out.
Hi one of my notebook asus a6j chipset was removed by someone an this chipset placed under realtek chipset and i think its related to keyboard do you know what chipset it is?
The ASUS AJ6 makes use of a Realtek Driver for HD Audio.
It is not likely that someone "removed your chipset" from the notebook. The "chipset" is soldered to the motherboard and is not under any circumstances "easily" removed. The motherboard is designed around the chipset, so even if it were removed the exact same type would need to go back in. This just isn't done. The chipset provides support to allow the CPU, memory, audio and all the hardware inside the notebook to work together.
If the hardware is being reported as something other than what is expected for an A6J, or is being reported as something OTHER than an A6J (meaning the model number on the case doesn't match that which is being reported when checked or scanned); more than likely the motherboard was changed to one that is used in a notebook model one or two up or down from your A6J.
You can read a review for the A6J notebook here along with viewing the hardware specs. I hope this helps and good luck. Please rate my reply. Thank you.
Mar 30, 2011 | ASUS A6J Notebook
Hello How do I remove the keyboard from an Asus A6J A6000 entertainment notebook? Thankyou
1. Place your laptop on a clean, flat surface and remove all power sources from it. Open your laptop screen as far as you can.
2. Use the flathead screwdriver to pop open the hinge cover. Slowly and carefully pry it open from the right side to the left side, exposing the keyboard screws. Using the Phillips screwdriver, remove the screws that hold the Asus A6J Keyboard in place. Keep these screws in a safe place.
3. Gently tug the Asus A6J Keyboard component toward your laptop display. You are trying to pull it out of the slot that is located near the palm rest and mouse pad. It doesn't take much force, but you must be firm. Once you have pulled it out of the slot, you can lift it up and remove it from your laptop.
4. Take the replacement keyboard and slide it into the slot. Once in place, screw it into place with the Phillips screwdriver and the screws you removed in Step 2. Fit the hinge cover back into place by snapping it in from left to right. Power on your laptop and verify that the Asus A6J Keyboard is working.
Dec 11, 2010 | ASUS A6J Notebook
Startup was pink shade and shortly normal now a flash and black screen altho system seems to be operating normally
Sounds like a bad backlight.
http://www.insidemylaptop.com/category/2-asus-laptops/
you'll find it there
good luck
Nov 29, 2010 | ASUS A6J Notebook
I am using windows 7 and camera a6000 is not working
On the ASUS website there is no actual support for Win7 but they do have Vista drivers which most of the time will work with Win7 http://support.asus.com/download/download.aspx?SLanguage=en-us Cheers from Scott
Mar 18, 2010 | ASUS A6J Notebook
No windows xp
You will have to reformat it again. its likely a bad sector has been created on the hard disk, and windows file is probably occupying the bad sector. Try to reformat your hard drive. If that doesn't work, try to reformat it with windows 98 bootable disk. If it doesn't work, get another hard drive and test to see if it will work. If that works, then know you may have lost the MBR (Master boot Record) of your hard drive.
Apr 14, 2009 | ASUS A6J Notebook
Device Driver
make sure you downloaded the right drivers and for the right operateing system and version then run the setup files again.
May 23, 2008 | ASUS A6U Notebook
ASUS A6J Notebook Logo
769 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
