Question about Sony PSP (Piano Black)
Psp is froze
My psp is froze. The power button is on and nothing. I tried taking out battery and memory stick and still nothing. What can I do? Can I reboot it somehow?
    Sergeant:
  • 321 Answers
If you have OFM go to http://forums.afterdawn.com/thread_view.cfm/688507 follow the instructions about 5 comments down and make sure ur using xp, vista may not work. comment back if you need help
Posted on Jun 18, 2009
When i turn on my psp the green light will come on but the screen won't come on and then a few seconds later the green light will shut off completely.
Hi tokyo_grl,
First you have to figure out what is causing the problem. Try the following steps.
1. Remove anything that is connected to the PSP, including the
Memory Stick, battery and any UMD games.
2. Plug the charger into both the wall and the PSP system, then wait for at least 30 seconds before turning the psp on.
--If the PSP turns on, your problem is not with your PSP, but with an accessory that was previously attached.If it does not turn on, your PSP is in need of a repair.
3. Next, unplug the power adapter from the PSP, and firmly place the battery into the PSP.
4. Plug in the Power Adapter once again, and wait at least 30 minutes for the PSP to begin charging, then try and power on the PSP system.
--If the PSP does not power on with the battery plugged in, but it did with just the charger, you need a new battery. If it powers on, do the next step.
5. Place the Memory Stick inside the PSP , and turn on the power. If the PSP does not turn on, but it turned on without the memory, you need a new memory stick.
If your PSP did not turn on during step 2, your PSP is bricked and indeed needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 16, 2011 | Sony PlayStation Portable (PSP) Console
Why when i switch on my psp he cannot read my memory card and he will not turn on?
Hi p_demain,
If your PSP did not turn on during step 2, it needs to be repaired by a qualified technician. I hope everything works out for you. Good luck.
Jul 15, 2011 | Sony PlayStation Portable (PSP) Console
How to reformat Sony PlayStation Portable (PSP) Console?
To do a factory restore on the PSP just hold the power button up until the system fully powers off. Once the system is fully powered off hold all at once start + select + square + triangle, while holding these four buttons turn on the PSP, once the PSP is on let go of these buttons, it should take about a mintue or so for the PSP to load back up. You should see the settings you first saw when you first turned on your PSP.
To reformat the memory stick just go to settings > System Settings > Format Memory Stick,
be aware by doing this you will lose all the information stored on your memory stick, including music, pictures, games, etc.... Hope this helps, best of luck, don't forget to rate :)
Feb 02, 2011 | Sony PlayStation Portable (PSP) Console
Hi recntly my psp was working fine but last week when I try to power on my psp nothing happens. I tried removing the memory stick and still no power on. Next I tried with no memory stick and no battery...
if you are facing problem in psp then just don't worry........... you can fix it with the help of repair guide you can download it and solve your problem easily...........
i will give you the link to download i hope it will solve your problem
Click Here to download
Dec 05, 2010 | Sony PlayStation Portable (PSP) Console
Any idea hw to restore psp games
Backup up your games on a PC. Then Format your memory stick and put the psp games back in the memory stick if this does not work try formatting your psp by entering the recovery mode HOLD R + HOLD POWER...
Go to advanced/advanced config/format flash 1 and reset settings
if this also fails try using another memory stick on your psp
Feb 18, 2010 | Sony PlayStation Portable (PSP) Console
Psp wont boot up with pandora battery
u should probly get a hack data on the memory stick and insert the memory stick with the battery make sure that only the hack data is on the memory stick
Jul 17, 2009 | Sony PlayStation Portable (PSP) Console
Memory stick unreadable by psp
try formatting the memory card via a card reader..
thats all i can think of
good luck!
May 30, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
PSP Will not start
What hapenned to all your PSP's is that they 'bricked'. When your PSP is installing an update and you interrupt the process, the data where the PSP's operating system (=firmware) is stored got corrupted (=broken). In very rare cases this can happen when you play a game and something goes wrong due that game. When your PSP is bricked the green lamp is on but the screen stays black.
Now straight to the point..The solutions:
1.If your PSP 'bricked' because you interrupted a system update (Powered off while updating, canceling update..), then you can only help it by re-installing the firmware correctly. NOTE: This is unsupported by Sony and is something you do on your own risk, for a usual PSP user it is a complicated process and i suggest you should let someone with experience do it. If you still want to attempt it, for example here's a tutorial for making a 'pandora battery' : http://www.youtube.com/watch?v=ZKFnuCfTPZo
To find more information about this subject you could seach on google for tags like 'psp pandora mod custom firmware jigkick'
2. If your PSP suddenly doesn't start up after or while you played a game, then you have a chance that you can recover your PSP without too much hassle. Simply let your battery run empty. After it's empty, remove the battery and let your PSP 'rest' a day without battery. After that, reinsert the battery, first fully charge it, and THEN start your PSP up (after your battery is fully recharged). If you have luck you might have your PSP working again.
3. Contact Sony and explain the situation. Explain that you did nothing wrong. If your PSP is still under warranty they should help you..
Good luck and if i helped you please leave feedback! Thanks
Sep 02, 2008 | Sony PlayStation Portable (PSP) Console
Psp not working
This problem occurs when there is some problem with the firmware, it can be happen If you turn off the system or remove the memory stick during an update. If an update is cancelled before completion, the system software may become damaged. if so, you''ll have psp with blank on screen. try remove all plugin MS, Umd, etc, then press bright button of psp. if isn't work you need pandora battery to downgrading your firmware. hope this help.
Oct 29, 2007 | Sony PlayStation Portable (PSP) Console
Sony PSP (Piano Black) Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
