Question about KitchenAid KUDE70FXSS Builtin Dishwasher
Won't complete cycle
Starts, after 10 mins. drains and stops
Dishwasher will operate only 10 min before stopping cycle
Check for places food could get stuck and clog the workings, including the drain hose.
Nov 24, 2013 | Kenmore 24 in. 16302 Built-in Dishwasher
I've been having isses with my Miele Incognito dishwasher. Water comes into the unit but cycle won't start. Technician on the phone said to take an 8mm wrench and try to loosen the circulting
your circulation pump is stuck. there is nothing you can do with a wrench, your tech is mistaken. the only thing you can do is to drain all the water out. after the drain cycle, stop the machine and turn it off. remove the triple filter in the bottom, and bail as much water out as possible. soak it up with a sponge or paper towels etc. now put a quart of water in the microwave and heat it to boiling. pour the hot water down in the sump area of the dishwasher and let it sit for 10 mins. try to start a cycle after 10 mins. ( you can leave the filter out for now) if it works, you are done and you just saved 800 dollars. if not, try that proceedure 3 more times in a row. if it still does not work after 3 times, you will probably have to replace the circulation pump.
Mar 27, 2012 | Miele 24 in. Incognito G643SCVI Built-in...
My Maytag Neptune FAV6800AW top load washer only runs for the first few minutes of the cycle, it will not spin..it just stops..we've tried two cycles, the quick wash...it starts at 33 mins and then stops...
I'm and owner and will try to help. Are you handy and do you want to try a DIY fix?
From the wash times is sounds like the washer is agitating the wash load (tumblers are rotating the wash basket load) is that correct?
If so see if the machine will complete a Spin Only cycle with no clothes in the wash basket. Set the Spin setting to Spin/Hang dry seting and start the cycle. It should take about 10 min complete. Does the Spin Only cycle complete with no clothes in the wash basket?
Some handy links if you are going to DIY.........Service Manual for reference.
Sep 17, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.
Good deal your machine is a Series 11.
“”Washer has stopped at 26 min with water in the drum. Will not spin or drain. Just sounds like it starts running then stops and repeats.””
I believe this is the start of a Spin Cycle of that Wash Cycle which Wash Cycle did you have selected?
Are there any error codes to the LED display like dC or uC?
If you stop that wash cycle with the wet load and do a Spin Only cycle will it complete with no error code?
Does the wash tub bang around in Spin Only cycle with the wet clothes load?
Standing by for some feedback and I will try to help.
Here is the Service Manual and parts look up. Can you let me know if you want to try to DIY the fix?
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Rich
Apr 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Beko WMA765S fills, stops, then drains and stops
i would think about replaceing the timer
Sep 09, 2009 | Washing Machines
Bosch dishwasher doesn't drain anymore
I would check the pump if its clear but not pumping down correctly check the drain hose if that's also not clogged then look into replacing the pump.
Jul 04, 2017 | Bosch Integra® 500 SHX46L Built-in...
KitchenAid KUDE70FXSS Builtin Dishwasher Logo
60 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
