Question about 2wire 2700HG-B Router (2700HGB)
Hi Sir, I have changed to a ISP who are using motorola cable modem for internet. I would like to setup home network using 2wire 2700hg router. How could I bridge the 2 devices ? Many thanks & Regards
  • 87 Answers
Does either of these devices have an "uplink" port? if so, you may be able to connect a cat 5 cable. If not, they may not be able to bridge.
Posted on Jun 16, 2009
Hot to make my gateway 2700hg-d modem/router
you just need to things for ATT your user name and password that you registered to them. Then you need to get inside the 2wire by using the IE or Mozilla. On the address bar, type in 192.168.1.254. Inside you will see there setup then just follow the prompt but if you got lost on the process just call att dsl
Mar 07, 2010 | 2wire 2700HG-B Router (2700HGB)
I have a 2wire 2700hg-b router and cant find the drivers for it
you dont need a driver for your 2wire modem. 2wire modem only need two things Username and Pw of your ISP account. so call your ISP for assistance
Jan 28, 2010 | 2wire 2700HG-B Router (2700HGB)
Can i use my 2700gh-b dsl 2wire wireless modem as wireless router to time warner cable? If so, how? I'm a newbee. Please help! Thanks in advance.
This Router designed for DSL internet. It wont work for cable internet. Best thing is to trade in with a normal access point or wireless network router. Like Linksys, Belkin, Netgear etc
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
How to connect 2wire 2700 HG-B router to voice modem motorola
that 2wire only works with DSL services, if you are using cable internet then no it wont work. If the surfboard digital voice is just a VOIP router then yes, plug the surfboard into one of the ethernet ports on the back of the 2wire.
Jun 06, 2009 | 2wire 2700HG-B Router (2700HGB)
Can't use 2wire router for cable internet
You probably only need to change the connection information inside the 2wire. go to the 2wire homepage using "192.168.1.254/setup" or "192.168.0.1/setup" it asks you for a keycode. Get the keycode that says its for DHCP, doesnt matter who the provider is on this page.
http://www.2wire.com/index.php?p=268
Mar 27, 2009 | 2wire 2700HG-B Router (2700HGB)
Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Feb 28, 2009 | 2wire 2700HG-B Router (2700HGB)
Home Network sharing issues using 2wire wireless modem
Did you manually assign the IP address to your shared devices? If so, the Linksys and the 2wire have different IP schemes.
2wire Gateway IP address:
192.168.1.254
255.255.255.0
Do an ipconfig /all on your computer and compare it to the ip scheme on your devices.
Feb 07, 2009 | 2wire 2700HG-B Router (2700HGB)
How do i sync windows vista with my router?
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
if you are still having trouble configuring your device, try to call supportrix and use supportcall as your promo code for 1 free technical support.
Jun 10, 2008 | 2wire 2700HG-B Router (2700HGB)
2Wire 1701hg gateway- Broadband Access problem
hi! have you used this other identical 2wire modem before? if this other 2wire modem (is it the same 1701hg?) well you may need to configure the settings first. also 1000 series modems usually have 3 lights on it; power, broadband link, and local network. if these 3 lights are on, you may need to access the modem's user interface. assuming that all lights are green, on your computer directly attached to the 2wire, open up any browser, type in gateway.2wire.net. it will give you the network at a glance page. click on run system setup wizard, type in the system password. on the ppp authentication page, please check if it has your username & password (this is the one that you set up on your internet acct w/ your ISP), the next screen will establish a connection. (please tell me if you've got any error messages...)
Apr 06, 2008 | 2wire 2700HG-B Router (2700HGB)
2wire 2700hg-b modem
if you have posted the correct model, you cannot connect a modem to this router as it has it's own built in modem, so in effect the routers modem will not configure properly, remove your modem and try again as there is no reason why the key code numbers should not work, unless you have caps lock on when you should'nt or visa versa
Nov 19, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire 2700HG-B Router (2700HGB) Logo
73 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
