Question about Taylor 794-33 Ice Cream Machine Soft Serve Machine
Leaking from primer plug in door - Taylor 794-33 Ice Cream Machine Soft Serve Machine
Can I somewhere donwload instruction of this machine? Don't work chocholate line and leaking syrup machine must be turn off or I can do ice scream and repair on the same time? Taylor Combo 8634 HT
Maybe providing Make and model of your up to nw unspecified ice cream maker someone might find instructions.
Actually, you can find them yourself, using Google search for terms
MANUAL MAKE AND MODEL of Ice Cream Maker.
Oct 23, 2015 | Ice Cream Makers
Ice cream taste like oil...what is fix for this issue?
First of all, you MUST use food grade lubrication because it is not hazardous and wont be detected. Second is that it wont damage any seals on the machine like a petroleum based solvent would. Third is seals around the shaft are leaking.
Jul 20, 2015 | Taylor Soft Serve 8756 Three Phase Water...
Why would our Model 702-27, be kicking the breaker. Tried changing plugs, but as soon as the breaker is reset and then the machine is turned on it kicks. The machine is full of product, and was runn
What breaker? The GFI on the wall plug?
If so,liquid may have entered the device and tripped the gfi breaker at the wall plug OR the main panel that provides power to that wall plug.
Nov 10, 2014 | Taylor 702-27 Tabletop Soft Ice Cream...
Pump loses prime causing ice cream to spit out.
If it is "spitting" you might want to check all the components from the mix container all the way up to the door where ice cream is dispensed. Check for leaking mix hoses as well as broken or clogged diaphragm (inside fitting in mix cabinet). Refer to the manual to find the diaphragm.
Aug 26, 2012 | Taylor 2009 Model 8756 Soft Serve Ice...
Frigidaire Electrolux Frost Free Freezer
Sounds like you need to check if the unit went into a defrost cycle and made any ice build up inside the cabinet "slushy" and the water leveling itself and running down plastic liner parts to a place where it can escape underneath.
Jul 31, 2012 | Electrolux Frigidaire 16.7 cu. ft. Upright...
Blue liquid leaking from ice cream attachment
I have been debating as to whether to buy one of these ice cream units but it appears it would be a big waste of money. I wonder how to track if Kitchenaid has made improvements to fix the flaw in the unit.
May 03, 2012 | KitchenAid Kitchen Aid KICAOWH Ice Cream...
Shake side stuck up but not drowing because that white spinner stayed down i suspect the spinner need to be changed all this happend few days after brushcleaning so not lubricateing issue
Could be a number of things;Check freezer door properly installed,improper lubriction of draw valve,the dispensing mechanism is out of alignment,draw valve binding on door,the solenoid plunger is binding in coil body, draw solenoid set too high or the drive spinner has disengaged from the spinner blade assy.Check the last thing.
Jan 27, 2011 | Taylor Ice Cream Makers
NOT FREEZING PROPERLY
If your outer bucket is leaking down the liquid brine solution it won't freeze properly. The rival buckets are bad about leaking. You might try pre-conditioning the outer bucket before making your attempt at freezing. Just fill the bucket to the weep hole with water and let it sit for about half an hour, then pour out all but about 4 inches of it and start adding ice and salt.
Jul 04, 2010 | Rival 8550-X 5 Quart Ice Cream Maker
My barrel on my white mountian ice cream is leaking from the seams of the wood. it is only one year. its not allowing the brime to come from weep hole
The wood will shrink when it is dry. It will swell up and close the seams if kept wet. Place the barrel in a container and fill with water inside and out to get the seams to swell and close before you use the freezer to make ice cream.
Jul 19, 2009 | White Mountain F69206X 6 Quart Ice Cream...
Taylor 794-33 Ice Cream Machine Soft Serve Machine Logo
51 people viewed this question
Top Taylor Ice Cream Makers Experts
Dennis Boxerman
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Taylor Ice Cream Maker Expert? Answer questions, earn points and help others
