Question about Martian Passport SmartWatch
I got water and my smartwatch and now it wont turn on
Was out in the rain about three days ago and the watch now wont turn on what do i do?
How do I set the DAY of the week on my new watch, Akribos XXIV Women's AK560RD Quartz Multi-Function Genuine Leather Watch ?
There are three positions for the crown. You can pull it out all the way to third position and turn up or down Each of those turn one sub-dial. then you can push back one position and again up or down. Each of those turn another sub-dial hand.
Sep 17, 2015 | Watches
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Handleiding
mcdevito75 here, I think you mean handleing, or takeing care of your Casio watch. First look on the back cover to see if it says shock proof or water proof, if it does you have a liitle lee way in handleing your watch, what I men is, you can wear your Casio even if you do heavy work and even in a moderate rain. However most Casio watches should not be worn if your out in a driveing rain or if you do extra heavy work, such as use a sledge hammer, or heavy tools, keep your casio dry, and once every other daye wipe it clean with a soft dry cloth, also do not rest your Casio on it"s crystal (Glass) when you take it off.
Jun 16, 2010 | Casio G3011 Duplex LCD Watch
Setting month, date, and day of the week on non-digital watch
Try pulling the stem out. Turn the stem in the counter clock wise direction and see if that changes the date/day
Dec 21, 2008 | Watches
Aquatech Sport Chronograph Watch
quickly press the bottom-left button twice.
then, press the bottom-right button once, and then the top-right button once. this should add 1 to the day. keep pressing the top-right button until u get the right day, the press the top-right button again.
now, how do u change the time format back to twelve hr. ?
Dec 20, 2007 | Watches
Alarm
hold adjust button down at same time press mode and start/stop button until it beeps.
hope this helps!
Nov 09, 2007 | Timex 1440 Nylon watch
Pulsar v182 (804892)
I have the same watch and the same problem. The solar battery is depleted. You need to recharge the watch like you did when it was new. The instructions can be found through the following link: www.pulsarwatches.com.au/manuals_pdf/108_1.pdf
Oct 28, 2007 | Watches
Pulsar Mens Wrist Watch
I have a similar solar modle Ive had since 1995 , about 4 years ago it started loosing time and the second hand started double ticking. I sat it down out side on a cool summer day for the hole day in the bright sun and never have had a problem since. knock on wood! It was also runover by a car last year and still works good. I wont ever get ride of it. Hopefully this helps u guys out
Jan 30, 2007 | Pulsar PXF216 Wrist Watch
Martian Passport SmartWatch Logo
Top Martian Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Martian Watch Expert? Answer questions, earn points and help others
