Question about Intel Dell Inspiron 15r N5010 Laptop Motherboard Y6y56
Overheating dell laptop
Overheat
Laptops tend to overheat when air flow is not good. To prevent it from overheating make sure you have the fans cleaned, there are plenty of tutorials out there on how to do it, or just go to your local shop and ask them to do it. if all else fails you may need to acquire a fan base, they are pretty cheap and can make a huge difference!
Posted on Mar 25, 2014
Dell latitude d430 overheating
First check that the fan is working properly by F12 at powerup to get into the Dell diagnostics.
Open task manager and close any unnecessary processes running in background
Delete all unnecessary applications
Uninstall unnecessary programs (Games, crapware, toolbars, etc.)
Let me know if it helps you.
Use system utility tool like RegInOut to remove unwanted files, fix registry and windows errors which cause of overheat problem
Jul 01, 2013 | Computers & Internet
Gateway nv59c66u
If it didn't overheated in the past, then your laptop might overheat because the ventilation system doesn't work properly anymore.
Check if the ventilation is blocked in any way. Just to be sure, blow some air through the cooling fan vent (on the left side of your laptop). If dust comes out, then continue doing so until there is no dust. Also, if your laptop had this condition for a long time, then you should replace the thermal paste or thermal pad on your processor because it might have dried out and it isn't efficient anymore.
Another reason would be a faulty component. For example, if your laptop overheats near the battery and the battery itself overheats, then the battery is the culprit and should be replaced or removed until a replacement is avaible (for example, this issue was common in Dell laptops rendering the battery useless after a short period of time).
Also, high work loads make laptop computers overheat. If you play a resource demanding game for a long time your laptop will overheat for sure.
For better feedback, describe when does your laptop overheats and where (as a whole or a certain area).
Jun 13, 2013 | Computers & Internet
Dell Studio One 1909 overheating
Where do you feel the heat coming from? what does it do when it overheats? How long are you using it when it overheats? Is the overheating new since you have owned it? Has it been dropped? Please give as much information you can. Not that I can help maybe someone else can.
Sep 17, 2012 | Dell STUDIO ONE 1909 ALL IN ONE CORE 2 DUO...
Powers up but does not stay on
This usually happens when your laptops gets overheated. Avoid using laptop keping on beds, pillows of laps. Always keep it on a flat surface facilitating amble air flo. Also dont use the laptop always plugged to the power adapter. It again overheats the base. Change and discharge the batteries, this increased the battery life too.
Mar 28, 2010 | Dell Latitude D600 Notebook
Will overheat and shut down during game play
This is a great peice of software that will cure your problem with overheating on a Dell laptop. You still need to clean out the heatsink and fan to get optimal performance. Share it with your gaming buddies that have a Dell laptop.
http://i8kfangui.software.informer.com/!
Dec 09, 2009 | Dell Studio 1537 Laptop
Overheats and shuts down after about 20 minutes
Usually when a CPU overheats it shuts down and after it cools down you can re-boot it again.
Continual overheating will eventually cause the CPU to fail.
The overheating is usually caused by blocked vents and or dust build up on the heatsink and/or fan. Remove this dust from the heatsink and fan and this should fix your overheating problem, unless you have a faulty fan, in this case you will need to replace the fan.
Feb 18, 2009 | Dell Inspiron 2650 Notebook
Flashing red and green battery light dell 6400
Ok, probably not the battery. With Dell machines, once they overheat to a significant level, it locks an overheating code into the bios, so you will have the light codes at start up. I've had three C840 machines with an overheating issue come through my shop. In order to get the machine working again, you will have to fix the problem that caused the overheating, then there is a download at Dell's site to clear the code. If the initial problem isn't fixed the code won't clear. On the machines that I worked on, 1- had a hair wound in the fan and the other 2 had bad fans one burned up the processor. I believe the 6400 and the C840 is basically the same machine. It's been a while since I worked on those machines so I can't remember exactly where the clearing download is at Dell's site, I do remember reading several forums at Dell on the subject. I hope this approach helps a little more than my last. If you have any more questions please ask.
Jul 09, 2008 | Dell Inspiron 6400 Notebook
Connection overheating
If it is the external adapter that is overheating and stopping after a while yes, replace it immediately. Fact that power adaptor is overheating means that there is a short inside the adaptor, this may damage the laptop, then change it as soon as possible.
If the laptop itself is overheating, check if the cpu fan is working, and eventually replace it.
regards
Mar 19, 2008 | Dell Inspiron 2200 Notebook
Overheating laptop during normal use
There might be a dust clump blocking your heatsink's airflow.
Jan 02, 2008 | Dell Inspiron B120 Notebook
Intel Dell Inspiron 15r N5010 Laptop Motherboard Y6y56 Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
