Question about HP Designjet T2300 Inkjet Large Format Printer - 44" - Color
Trouble motor rotation HP T2300
Troube with rotation motor
What is Error Code:59.A0 for Hp laserjet 400 M401d?
A main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation errorA main motor error occurred. X description: 0 = Motor error 1 = Motor startup error 2 = Motor rotation error HP LaserJet Error Codes 50 59 Looks like a motor error check the fuser unit and drum are seated properly.
Mar 09, 2015 | HP Office Equipment & Supplies
Info guage display
8-bars. That's trouble. Brake solinoid problem or bad controll harness connection.
Nov 07, 2013 | Electric Mobility Invacare Pronto M41...
Hp t2300 error 21.2:13 solution
This would normally indicate "Service station error". I found the following solution elsewhere on Fixya for the HP Plotter T1100, but looks like it is for the technically minded.
"Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel)."
Hope this helps.
Sep 08, 2012 | HP Designjet T2300 Inkjet Large Format...
SHARP-235, lp 6-10 CALL FOR SERVICE CODE...Sep 2010 ... What does error code L6-10 mean on a Sharp AR-235 ... my machine sharp a 235 say call for service lp 6-10 what dos it mean
L6 10 Content Polygon motor lock trouble
Details The polygon motor does not rotate.
The motor lock signal is detected for 6sec
or more after the polygon motor rotates.
The motor lock signal is detected for 1sec
during rotation of the polygon motor.
Cause Polygon motor unit failure
Polygon motor connection harness trouble
or disconnection
MCU PWB failure
Check
and
remedy
Check the polygon motor operation with
SIM 61-1.
Check connector/harness of polygon
motor
Replace the polygon motor.
Replace the MCU PWB.
If the polygon motor isn't working then you will neeto buy a new Laser Unit. They can be expensive if you can get one. To replace it will tak alot of disassembly as well. Might be better and more cost effective to get a new machine.
Oct 22, 2011 | Sharp AR-235 Copier
How do i get my MPC laptop TransPort T2300 Finger Print scanner to work? I tryed runnin my finger across it nothin happend .
Did you enroll your finger print first?
If not, log onto your account, and start the protector suite
go to the passport section, and set up a passport for your account.
Sorry if this isn't very clear, but I don't have the suite anymore, I'm running windows 7 on my t2300
Oct 12, 2010 | MPC Computers TransPort T2300 Notebook
Model # 385,11206300 Having troube getting the
go to sewusa.com they have threading diagrams showing how to use the bobbin winder.
Feb 27, 2010 | Sewing Machines
Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Jun 25, 2008 | HP 530 Notebook PC
HP Designjet T2300 Inkjet Large Format Printer - 44" - Color Logo
26 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
