Question about Black & Decker 12-Cup Programmable Coffeemaker
Turn off beep alarm on CM2020B
How do I turn the beep alarm off on my CM2020B coffee maker?
Just bought my Black and Decker coffee maker(2 days ago). Model CM2020B, 12 cup. The digital display for the clock does not light up. Is it supposed to?
As you can see from this photo, the B&D Model CM2020B digital display screen is supposed to light up when the coffee maker is plugged into a working electric plug. You couldn't control/operate the machine if it did not. The machine is useless without it. Bring it back to the seller.
Jun 14, 2014 | Black & Decker TCM700 Coffee Maker
Cuisinart coffee maker, how do I get the alarm NOT to beep when coffee is done being made?
Julie, I know EXACTLY what you mean. I hate getting screamed at in the morning "YOUR COFFEE'S READY!!!". Frig, i have small kitchen, you don't need to yell at me Cuis'. I couldn't even find the place where sound was coming from in order to cover it up.
Did you find a quieter machine? If so, what was it?
Mar 03, 2012 | Cuisinart DCC-1200 Coffee Maker
I turn on my Mr. coffee maker and it just beeps and won't brew any coffee. What could it be?
Tried to clean it, everytime you press the brew button it just beeps and if we try to set it to clean it sounds like it tries to turn on but nothing happens.
Apr 27, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Need To Turn Off Beeping After Coffee Brews
on my 12 cup kitchenaid coffee maker, i can press and hold the Auto button to enable/disable the alarm
May 15, 2009 | KitchenAid Pro Line Coffeemaker Coffee...
How do I turn the beeping off on my Kitchenaid Coffee Maker when it's brewing?
There is no programming function that allows the beeping to be turned off on a Kitchenaid Coffee Maker.
Apr 01, 2009 | KitchenAid KCM511OB 10-Cup Coffee Maker
Cannot turn off alarm.
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
Hope this will help you.
/Mirran
May 09, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Turn off beeping alarm when the coffee maker is done brewing
you can't ,its up in the top behind the controls.
you have to take the pot totally apart.
only a trained tech should attempt this.
Mar 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Coffee maker beeping
Is your grinder in and the lid down? My coffee maker (grind & brew) started beeping after I cleaned it and turned the left knob clockwise with the grinder still disassembled. There's a little button that is depressed when you close the lid with the grinder in there (I'd guess it's a safety feature). I pressed down that button, and the beeping went away.
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Black & Decker 12-Cup Programmable Coffeemaker Logo
74 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
