Question about Apple Pre-owned A1359 Ipad Keyboard Docking Station
A1359 iphone unlock
Unlock
I forgot my unlock code for my old ipad1 haven't used in in months
If your iPad is disabled, the only way to unlock it is to completely erase and reset it. If you have a backup, you'll be able to restore it, otherwise you'll lose all of your data. There is no way to unlock a disabled iPad unless you use the correct passcode or you erase it. And the following guidance will show you how to unlock a disabled iPhone with iTunes.
Step 1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
Step 2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPad. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Step 5. Select "Restore from iTunes backup" during the setup process. This will load the backup that you created so that all of your data is restored.
http://www.leawo.org/tutorial/how-to-unlock-a-disabled-iphone-with-without-itunes.html
Feb 18, 2017 | Apple iPad Tablets & eReaders
My ipad says its disable wont let me in it so how do i resat it
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by clicking "Back up Now" in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it to reset your iPhone. Once the reset process is complete, you'll be taken through the iPod's initial setup process.
Nov 03, 2016 | Apple iPad Tablets & eReaders
Bottom row of letters has died/is suddenly unresponsive. Can this be fixed?
Your touch sensitive screen seems to be broken. This normally means it needs to be replaced completely.
Aug 21, 2015 | Apple Pre-owned A1359 Ipad Keyboard...
How do i bypass a icloud activation screen on ipad 2 reported lost
Unlock Timeframe: 7-15 working days
iPhone Carrier iCloud Activation (Clean Only) Choose an option... iCloud Activation (Clean Only) iPhone Model Choose an option... Choose an option... iPhone 6 Plus iPhone 6 iPhone 5S iPhone 5C iPhone 5 iPhone 4S iPhone 4 iPad Clear selection
IMEI: Please add IMEI number which contains 15 characters only
Feb 22, 2015 | Apple iPad Tablets & eReaders
How can you unlock your phone
iPhones can only be unlocked through Apple. There are many people who will perform this for you, sometimes for about £15.00. I'd recommend you start with your carrier.
Feb 21, 2015 | V_Wellcome Apple IGN "Take Now: Apple...
I can unlock my iPad its disabled in it say to connect it to iTunes but I want to can I reset it without connect it to iTunes cause I don't have a computer to do it.... If I can reset it to unlock it is my...
Apple can help you to reset your login, when you enter the correct password that belongs to your Apple ID. It will be partially on the screen. If you really messed up, setting up security, and lost unlock code and your Apple ID password. Only Apple can help. For that you have to take iPhone, invoice and prove of your identity (Passport) to the Apple store and hope they will unlock your iPhone. With iOS7 Apple made a very good security system. And while setting up the iPhone and the security, you are warned several times what to do to make sure you and only you could enter the system. Whatever you is told there is no bypass for the Apple security system.Be aware if Apple does reset your iPad, all data now on the iPad will be lost.
Perhaps you even could try this? How to Reset Forgotten Password for an iOS Device
Jul 21, 2014 | Apple iPad Tablets & eReaders
Apple Pre-owned A1359 Ipad Keyboard Docking Station Logo
47 people viewed this question
Top Apple Tablets & eReaders Experts
Yoav Shilon
Yoav Shilon
John mullen
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
