Question about Uniden DCT5285-2 Cordless Phone
Fading in and out
My second handset when talking to someone it fades in and out till you cant hardly hear the person on the onther end.
 the volume is turned up high.
4 Suggested Answers
  • 34 Answers
SOURCE: Uniden Phone 5.8 Ghz- I hear a spanish radio station
depening on your location if you have no interuption from other freqency from other leaking environment you r hanset may have a manufacture sorftware or hardware problems if you try another hand set wiht same problem posible a decfive ..
Posted on Oct 01, 2007
Beni S-P
  • 1006 Answers
The microphone in handset is broken!
Posted on Nov 16, 2007
SOURCE: I can hear but the person I am talking to cannot hear.
try cleaning the mic' without openning the phone -
from the outside by an old touth brush...
that will do the trick
if you can open the screws without any damage
than pull out the mic's cover
it is probebly full of moist
Posted on Jan 24, 2010
  • 3530 Answers
SOURCE: Hi, We recently purchased this phone
Welcome to Fixya
There are four ringer volume settings for this phone (off, low, medium and high). With the phone on standby. Press the UP arrow te make the ringer volume louder. Press DOWN arrow to make is softer. If you want to adjust the earpiece volume, while on call, press UP and DOWN arrow to select the volume that you want.
Thank you for using Fixya!
Posted on Feb 28, 2011
0 characters
1 Points
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Phones
This question is in regard to the KX-TG5631 Panasonic Cordless phone. Callers tell me that my voice fades in and out while we're talking, to the point where they can't hear me at all. On my end, I can...
It is possible that the mic hole is blocked and the voice do not detect properly to be processed.
clean and check if not the mic might be faulty , use a new one and test as this is inexpensive. if not the preamplifier of the mic or the amplification stages of the mic is faulty.
A good signal test can prove corrrect.
Sep 20, 2010 | Panasonic KX-TG5631 Cordless Phone
Hi! For the Motorola L401 (with 4 handsets: since
Try it on Different Sim . It is the problem occoured in almost all motorola phone .This is because of crystal talk technology use in motorola .This problem occured mostly in Airtel sim in india
Sep 11, 2010 | Motorola Mobility L401 Cordless Phone
Hard to hear on one of the handsets
we have the same phones, the volume can be adjusted using the key pad but only slightly the hearing overall with this phone is not so great you end up straining half the time to hear the conversation
Sep 04, 2009 | Panasonic KX-TGA101S Cordless Handset
Jul 22, 2009 | Uniden DCX640 Cordless Expansion Handset
Handset volume on Panasonic KX-TGA101S is too low
CLICK HERE for the user manual.
and HERE for the Base Unit
Pg 13 of the second manual designates how to adjust the handset volume.
The quick answer is to press TALK (or while talking to someone)...
Then, using the middle round button... press up or down to adjust the volume.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jun 03, 2009 | Panasonic KX-TGA101S Cordless Handset
The sound from my speaker fades in and out, but the handset works fine.
Since this problem just started, I would first check to make sure there is nothing stuck inside the mic's port. Also, if you have a fan on in the room, that can also cause your speaker to fade in volume.
I say both of these because if the phone thinks you're saying something, your speaker will fade in volume. Whether you're talking or it's just air noise, the volume will fade.
May 22, 2009 | Vodavi 30-Button XTS Telephone
2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
1. move closer to base
2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
go to page 21 of the manual ("" if you don't have it) good luck!
Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
Uniden DCT5285-2 Cordless Phone Logo
19 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
