My hiti photo printer s420 is not displaying menu option
The photo printer skips operational menu to pc printer option without selecting
  • 105 Answers
SOURCE: printing to 4 x 6 paper
Hello oyam26,
For any paper mismatch issue, first thing you do is try to set the paper type to plain. This will fix the issue in most of the cases.
gud luck
Posted on Nov 05, 2008
rustysheriff
  • 344 Answers
SOURCE: how much is it?
Product no longer available, could try ebay for a used one.
Posted on May 04, 2010
nonontech
  • 4737 Answers
SOURCE: Dear Sir, Photo printer wizard will
There are mainly three possibilities causing this issue.
1. Ram i.e. Memory
2. Connection between the Printer and the Computer.
3. Spooler.
First of all, try to print the pictures using a Pdf Printer, i.e. PDF Creator or similar applications. This will help us find out if there's Ram (memory) issue. Download and install this (Click Here), open the link and click "Download Now!" button. This application is called "PDF Creator". It's not actually a program, but a Virtual Printer which prints documents as Pdf files. [If you have other similar application, you need not to download this.] Once it's installed, it should show up as printer "PDFCreator" in the "Printers and Faxes" folder. Run the windows "Photo Printing Wizard", select all the pictures of the album and select the PDFCreator as printer, you'll be prompted to save the file somewhere, save it on the desktop, it should run the process several or few minutes depending on the number of photos/documents. Do this several times and make sure there's no error or problem, if there's problem, then I would recommend you to install additional or another Ram and try again.
But if there's no problem printing this way, then Uninstall and Reinstall the printer's drivers and softwares. You may need to restart your computer for the changes to take effect. After this is done, try printing the photos again, but first as Pdf file as mentioned above not directly to the printer, otherwise you'll loose Ink and Papers.
I would also recommend you to try with another Cable, i.e. printer's USB cable.
Let me know if you need further help.
Good luck.
Thanks for using FixYa.
Posted on Dec 07, 2010
realrajput
  • 75 Answers
SOURCE: driver of hiti photo printer
GO TO DIVICE MANAGER
GO TO DIVICE PROPERTY WHOSE DRIVER ARE NOT FOUND
COPY DIVICE ID CODE
http://devid.info use this site download all driver
Posted on May 16, 2011
SOURCE: My HiTi Photo printer 640
softwear inttall
Posted on Jul 23, 2011
My printer hiti s420 writes check sum error sdram and show code 197378
Your printer would need a reset and/or repair
http://www.hiti.com/english/Support/FAQ_Detail.asp?lid=&FaqId=279&skey=
hope all electrical outlets and other devices connected to the HiTi are grounded well and you eliminate any static discharge when using the printer.
Mar 31, 2016 | HiTi S420 Photo Printer
How do i fix error code 128
pls change the printer main board
Feb 15, 2016 | HiTi S420 Photo Printer
My printer show Yellow light & Driver not loaded Windowxp pl.give me anserd detail.
start
Printer & Faxes
if HiTi S420 is listed, right click it
properties
advanced
new driver
(follow on screen instructions & point to where the driver files are located)
Oct 04, 2015 | HiTi S420 Photo Printer
USB NOT WORK
contact the manufacturer thru their website and ask tech support .
May 21, 2015 | HiTi S420 Passport ID Photo Printer
New drivers required for HITI Model 730 for VISTA
1. Go to: http://download.hiti.com/index.asp?sidd=&frid=
2. Under the "Driver, Firmware, System Patch and User Manual" section, select the driver that suits your operating system from the "Step 1" drop-down menu..
3. Select your exact printer model from the "Step 2" menu under the same section.
4. Click "Next" to proceed to the download page.
Nov 04, 2009 | Hi-Touch Imaging Technologies HiTi 730PS...
22 people viewed this question
k24674
jasbo
jasbo
