Germ Guardian EV-9-102 UV-C Air Sanitizer Logo
A
Anonymous Posted on Mar 25, 2014
Bulb replacement; how do you replace the bulb
I need UV replacement BULB , I cant find one online
There are a few things you can try if you're having trouble finding a replacement UV bulb for your device online. One option is to check the manufacturer's website to see if they sell replacement bulbs directly. Many companies will also list authorized resellers on their website, so you may be able to find a replacement bulb from a trusted third-party seller.
Another option is to try searching for the bulb using the model number of your device. This will help ensure that you're getting a replacement bulb that is specifically designed to work with your device.
You can also try searching for the bulb using keywords related to the device, such as "UV water purifier bulb" or "UV air purifier bulb."
If you still can't find the right replacement bulb, you may want to consider contacting the manufacturer directly to inquire about replacement options. They may be able to provide you with the information you need or point you in the direction of a trusted reseller.
If online search not working you can try a local store that sell electronic part, Home improvement stores that carry a variety of lighting options may be able to help you find the UV bulb you need.
Please do let me know the model number or application the UV light is used for, so that i could provide specific recommendations.
Where can i get a replacement lamp uv-145 2.5w
Sealand Replacement Bulb for Green Killing Machine - Petco
www.petco.com/.../Sealand-Replacement-Bulb-for-Green-Killing-...
PetcoWater flows in direct contact with UV lamp, making it extremely efficient. The zigzag flow are designed for maximum sterilizing time. Totally self-contained replacement bulb assembly for AA 9Watt UV Sterilizer Kit. .... 2.8" L x 2.5" W x 16.5" H
UV light sources - Norland Products
https://www.norlandprod.com/lightsourc.html
The Norland collection of long-wave, ultraviolet light sources have been carefully ...LED UV Curing System emits a consistent and repeatable 2.5 W/cm squared ... lack of liquid light guides and replacement lamps brings to the forefront of UV ...
[PDF]MultiPole LED UV Curing System - Electro-Lite
2answers
Replace UV light Ecobox unit
Take the filters off and there should be a small tray that you pull out. The bulbs are in the tray
How do you replace the bulb in a freshair purifier
Make sure you have the starter use with replacement bulb. Usually comes with replacement bulb. Open the back of th unit by removing the cover.
My Ecoquest Fresh Air Purifier is giving me a warning to replace bulb. I don't see anywhere on the manual where the bulb is.
The bulb is in the RCI module for the version 2.0 & 2.1. It the part that is rectangular with a honeycomb grid on two sides. Your dealer should be able to help you get a replacement. If you need more help just leave a comment. Hope this helps you.
Where is a good place to buy replacement bulbs?
Try Healthy Technologies, Inc. - 1-877-710-0057.
EcoQuest Fresh Air Lamp replacement
Its probably the starter. Manual says to replace both lamp and starter at same time.
BULB AND LAMP
I can give you some possibilities. A loose connection, a broken or corroded wire and/or terminal end, dust or moisture on a circuit board, the plate needs cleaning, the contacts for the plate need cleaning, the bulb ballast needs to be replaced, the bulb may not be properly installed, the support posts for the plate need cleaning. These are all I can think of at the moment.
Top Germ Guardian Air Purifiers Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Germ Guardian Air Purifier Expert? Answer questions, earn points and help others
